Salut,j'ai un soucis avec ma nouvelle ram ( G-Skill Ripjaws 2x4 go 10600) J'ai un bluescreen :
The IO manager has detected a violation by a driver that is being verified. The faulty driver that is being verified must be debugged and replaced with a working version.
If this first timeyou've seen this error screen,restart your computer.If this screen appears again,follow these steps : Check to make sure any new hardware or software is properly installed. If this is a new installation ask your hardware or software manufacturer for any windows update you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information :
*** STOP: 0x000000C9 (0x000000000000023E, 0xFFFFF88001A37308 *là les 2 autres erreurs sont pas complète sur la photo )
***dtsoftbus01.sys - Adress FFFFF88001A37308 base at FFFFF880001A36000, *pareil,la photo a mal été cadrée c'est pas lisible *
Marsh Posté le 04-08-2011 à 19:47:13
Merci d'avance.
