probleme copie de dvd
probleme copie de dvd - Matériels & problèmes divers - Hardware
Marsh Posté le 20-08-2006 à 18:15:14
salut.
j'ai un probleme pour fait une copie de dvd
j'ai un pc lifetec airxl
j'utilise dvdshrink_3.2.0.16 et Nero.v6.6.1.4
lorsque je lance dvd shrink il encode le dvd
puis a la fin de l'encodage au momment de la gravure il affiche
ERREUR DE GRAVURE
"error:\ncannot connect trf
1A23-0809-9130-2375-9529-1341
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder:             <PIONEER DVD RW  DVR-108> Version: 1.14 - HA 1 TA 0 - 6.6.1.4
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2000kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
CdRomPeripheral      : PIONEER DVD RW  DVR-108          atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : IDE DVD-ROM 16X                  atapi Port 0 ID 1  DMA: On
DiskPeripheral       : WDC WD2500JD-00HBB0              atapi Port 1 ID 0  DMA: On
=== CDRom-Device-Map ===
PIONEER DVD RW  DVR-108    I:   CDRom0
IDE DVD-ROM 16X            J:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 511MB (523756kB)
Free physical memory: 198MB (202984kB)
Memory in use       : 61 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.8.2006
NeroAPI
18:03:18 #1 Phase 112 File APIProgress.cpp, Line 275
 DVD-Video files reallocation started
18:03:18 #2 Phase 114 File APIProgress.cpp, Line 275
 DVD-Video files reallocation completed (no file modified)
18:03:18 #3 Phase 111 File APIProgress.cpp, Line 275
 DVD-Video files sorted
18:03:18 #4 NEROAPI 7 File Burncd.cpp, Line 3095
 Error:\nCannot connect TRF.
18:03:18 #5 Text 0 File AudioCompilationImpl.cpp, Line 867
 DRM: DRM burn session terminated.
18:03:18 #6 Text 0 File AudioCompilationImpl.cpp, Line 896
 DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 17/11/2005 18:19:28 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) [/#ff1c00]"[/#ff1c00]
d'ou vient le probleme : logiciel ,materiel ??????
Marsh Posté le 20-08-2006 à 21:09:32
Thermaltake Xaser VI :: Asus P5N-e SLi - Intel Core 2 Duo E8600 3.33Ghz - 4 Go DDR2 PC-800 Corsair TwinX - Disques : WD500Go SATA + WD500Go SATA + WD500Go SATA + WD320Go + WD320Go IDE - HIS HD4870 ICEQ4+ Turbo 1go - Asus HD3450 256 Mo - Ecrans : 3 x ACER
