Pleins de reboot sans messages
Pleins de reboot sans messages - Matériels & problèmes divers - Hardware
Marsh Posté le 04-06-2006 à 17:21:29
Voici depuis quelques temps que mon pc reboot sans cesse sans messages particulier, j'ai donc avec le logiciel Windbg regarder le Fichier minidump, je vous fais un copier/coller de ce qu'il dit, si quelqu'un aurait l'aimabilité de me dire ce qui pose donc ce pb de reboot régulier.
Merci d'avance
Microsoft (R) Windows Debugger  Version 6.6.0003.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Documents and Settings\HP_Administrateur\Mes documents\Mes fichiers reçus\Mini060406-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
Debug session time: Sun Jun  4 13:57:51.423 2006 (GMT+2)
System Uptime: 0 days 0:17:04.998
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image WlanUIG.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for WlanUIG.sys
*** ERROR: Module load completed but symbols could not be loaded for WlanUIG.sys
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 100000D1, {7b5c8f24, 2, 1, f699ad95}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Probably caused by : hardware ( WlanUIG+3ed95 )
Followup: MachineOwner
