Pb gravure avec plextor PX-800A - Matériels & problèmes divers - Hardware
Marsh Posté le 30-09-2007 à 16:35:45
Personne n a de sooution a mon pb ?
Pour pouvoir vous aider, voici une suavegarde du log d une gravure foiree :
Ludovic
1A23-0097-1002-9816-9862-3693
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 13:06:00
ahead WinASPI: File 'D:\Program Files SATA 2\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/2003 15:25:04
Nero version: 6.0.0.11 (Nero Express)
Recorder: <PLEXTOR DVDR PX-800A> Version: 1.00 - HA 2 TA 1 - 6.0.0.11
Adapter driver: <JRAID> HA 2
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PLEXTOR DVDR PX-800A >Version: 1.00 - HA 2 TA 1 - 6.0.0.11
=== Scsi-Device-Map ===
CdRomPeripheral : ELBY DVD-ROM 1.0 ElbyVCD Port 0 ID 0 DMA: Off
DiskPeripheral : WDC WD740GD-00FLA1 iaStor Port 1 ID 0 DMA: On
DiskPeripheral : Volume0 iaStor Port 1 ID 1 DMA: Off
CdRomPeripheral : PLEXTOR DVD-ROM PX-130A 1.03 JRAID Port 2 ID 0 DMA: Off
CdRomPeripheral : PLEXTOR DVDR PX-800A 1.00 JRAID Port 2 ID 1 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 2046MB (2095500kB)
Free physical memory: 1562MB (1600064kB)
Memory in use : 23 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.9.2007
ISO compilation
16:33:11 #1 Text 0 File Isodoc.cpp, Line 5771
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
16:33:11 #2 Text 0 File Reader.cpp, Line 118
Reader running
16:33:11 #3 ISO9660GEN -11 File geniso.cpp, Line 3854
First writeable address = 0 (0x00000000)
16:33:11 #4 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-at-once, using DVD media
16:33:44 #5 Text 0 File DlgWaitCD.cpp, Line 228
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2154685 (478:49.10)
16:33:44 #6 Text 0 File DlgWaitCD.cpp, Line 233
Write in overburning mode: FALSE
16:33:44 #7 Text 0 File DlgWaitCD.cpp, Line 1722
Recorder: PLEXTOR DVDR PX-800A, Media type: DVD+RW
Disc Manufacturer ID: MKM, Media Type ID: A02, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
16:33:44 #8 Text 0 File ThreadedTransferInterface.cpp, Line 768
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2154686 (2154686) = #2154686/478:49.11
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2154686 blocks [PLEXTOR DVDR PX-800A ]
16:33:44 #9 Text 0 File ThreadedTransferInterface.cpp, Line 937
Prepare recorder [PLEXTOR DVDR PX-800A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4413104128, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2154686 | lead-out | 1 | 0x00 | 0x41
16:33:44 #10 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
16:33:44 #11 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
16:33:44 #12 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 2.4x (3 312 KB/s)
16:33:44 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2130
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
16:33:44 #14 Text 0 File Cdrdrv.cpp, Line 7906
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 01 4D 4B 4D 00 00 00 - 00 00 41 30 32 00 39 23 ..MKM.....A02.9#
00 94 79 64 02 20 00 9C - 7A 6C 02 20 00 9A 7B 68 ..yd....zl....{h
02 20 12 12 10 E0 00 F0 - 00 00 00 00 00 00 00 01 ................
16:33:44 #15 Phase 98 File dlgbrnst.cpp, Line 1843
Start formatting disc before burning
16:33:44 #16 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 22:34,397 (1354397ms) -> OK
16:33:46 #17 Phase 100 File dlgbrnst.cpp, Line 1843
Formatting disc was successful
16:33:46 #18 Phase 65 File dlgbrnst.cpp, Line 1843
16:34:02 #19 SCSI -500 File Cdrdrv.cpp, Line 1205
SCSI Exec, HA 2, TA 1, LUN 0, buffer 0x0013B474
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x55 0x10 0x00 0x00 0x00 0x00 0x00 0x00 0x3C 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
ModeSel: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x05 0x32 0x02 0x04 0x08 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x96
0x00 0x00 0x
16:34:02 #20 Text 0 File DVDPlusRW.cpp, Line 553
Start write address at LBA 0
DVD high compatibility mode: Yes
16:34:02 #21 CDR -500 File ThreadedTransferInterface.cpp, Line 1534
SCSI command aborted
16:34:02 #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1534
Could not perform start of Disc-at-once
16:34:02 #23 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
16:34:02 #24 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 2.4x (3 312 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 27/07/2007 01:06:18
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 13:06:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 27/07/2007 01:06:18 (Prassi/Veritas driver for win 2K)
File 'Drivers\jraid.sys': Ver=1.17.13.01 built by: WinDDK, size=44928 bytes, created 16/02/2007 04:27:10 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Marsh Posté le 30-09-2007 à 21:18:48
Je suis alle faire un tour dans l utilitaire nero info tool, et le chipset que j utilise n est pas a base de nvidia, mais de Jmicron (JMB 36X raid driver). Le probleme d incomptatilibe avec un chipset nvidia n est donc pas fonde puisque je n utilise pas ce type de chipset !
Du coup, j ai essaye de desinstalle les drivers de ma CG pour essayer (une 8800 GTS), redemarre, et reinstaller les drivers a partir du cd du constructeur, et le message affiche par nero a change ! (rien que ca !). Maintenant, le programme affiche le message : "could not perform start of disc at once". Quelqu un a une idee sur tout ca ?
Marsh Posté le 02-10-2007 à 18:19:02
J ai essaye plusieurs test, mais a rien a faire le probleme persiste, nero m indique toujours "commande SCSI interrompue".
J ai donc continue mes recherches sur le net, et j ai trouve une reponse sur un autre forum, voici ce qui etait marque :
bonjour,
Impossible d'effectuer la fonction Disc at once....
essayez ceci:
Pour faire avancer le schimilimilick, voici xomment j'ai résolu ce problème :
"Sur ma carte mère (ASUS P5B) l'IDE PATA est géré par une puce tierce (non intégrée au chipset INTEL) de marque Jmicron. Comme tout un chacun, j'ai installé tous les pilotes présents sur le CD fourni. Et paf voilà que NERO refuse de graver en disc-at-once et plus précisemment comme signalé plus haut en multi session.
Après moultes essai et autres bidouillage, j'ai viré le pilote propre au controleur Jmicron (Dans le gestionnaire de périphérique il suffit de supprimer le controleur) et j'ai forcé la réinstallation du pilote Microsoft qui s'appelle "Contrôleur IDE standard double canal PCI" et hop, la gravure remarche normalement. "
Par contre, le controleur Jmicron n apparait pas texto dans mon gestionnaire de periherique, sous quel nom se cache t il ? (ma CM en est pourvue car c est une gigabyte P35C-DS3R). Dans mon gestionnaire de periph au niveau des controleurs, j ai controleur de lecteur de lecteur de disquette, controleur audio video et jeu, controleur de bus USB, et controleur SCSI et raid. Et dans le dernier, il y a comme sous categorie Gigabyte GBB36X Controller, et Intel ICH9R Sata Raid Controller. Lequel choisir ?
Et le pire, c est que le controleur ATA/ATAPI IDE n apparait pas dans mon gestionnaire de peripherique alors que je n ai fait aucunes modifs, je ne comprends plus rien !!!
D avance merci pour votre aide !!!
Marsh Posté le 03-10-2007 à 13:51:59
Tu n'as pas la catégorie Contrôleurs ATA/ATAPI IDE ? ![]()
Marsh Posté le 05-10-2007 à 18:15:17
Oh, un etre humain !!!
Merci d avoir eu le merite d etre le seul a te manifester Stiktougaizeur, mais en fait, j ai reussi a resoudre le probleme pour ceux que ca interesse :
Le probleme vient effectivement du chipset Jmicron car lors de l installation des differents pilotes de la CM (Gigabyte P35C-DS3R), le controleur Gygabyte GBB36X a tout simplement pris la place du controleur ATA/ATAPI IDE dans le gestionnaire de peripherique ! Pourquoi ? Commen ? Je ne sais pas. Cela explique donc pourquoi la lecture des CD/DVD fonctionnait, mais aucunes gravures ! Solution : Faire clic droit sur le controleur en question dans le gestionnaire de peripherique, puis choisir mettre a jour le pilote, ensuite installer a partir d une liste ou d un emplacement specifie (utilisateurs experimentes), et choisir le pilote dedie au controleur ATA/ATAPI IDE pour tout remettre en ordre ! Et si la CM vous demande a n importe quel moment de reinstaller le chipset de Gigabyte, ignorez sous peine de refoutre le bordel ! N oubliez pas de redemarre pour prendre en compre les changements, et le tour est joue !
Je tiens egalement a remercier l ensemble des personnes du forum pour leur aide tres precieuse !
A bon entendeur salut !
Marsh Posté le 10-10-2007 à 13:31:53
bah tu sais des fois personne ne trouve une solution...ça peut arriver...on est tous humains (enfin j'espère)...qui n'a pas passé le test du Gom Jabbar ? ![]()
Marsh Posté le 27-07-2008 à 00:44:33
Salut ludokaz69
Je dois te dire une chose Bravo et encore Bravo, J'ai fouillé partout sur le net pendant plus de 2 jours et finalement je suis tombé sur ton poste. J'ai fais ce que tu as dis et au miracle ça marche.
Je ne sais pas si tu verras ce topic de nouveau mais sache que tu as toute ma reconnaissance et mes remerciments pour avoir résolu ce problème. En effet chez moi aussi j'avais les pilotes JMicron qui s'est installé à la place des pilotes IDE. La conséquence ne se voiyait pas en lecture, mais en ecriture c'est autre chose. J'avais des problèmes de gravure avec Nero. A chaque fois j'ai eu l'erreur suivant: SCSI Command aborted avec bien sur l'echèque de la gravure.
Finalement tous est bien rentré dans l'ordre depuis que j'ai fait la manip que tu as dis.
Je suis contente de voir qu'il y a d'autre personnes qui pensent comme moi. En effet moi quand j'ai un problème, je pose une question et si jamais je n'ai pas eu de réponse, mais qu'entre temps j'ai trouvé la solution, je n'hésite pas à la poster pour que cela puisse aider les autres.
Donc encore merci
Marsh Posté le 30-09-2007 à 15:02:14
Salut a tous !
. Pourtant, je n ai fait aucunes MAJ manuelles (peut etre les automatiques)
. J ai essaye de desinstaller Nero/graveur puis de reinstaller le tout, rien a faire le probleme persiste !
Voila, depuis quelques jours je n arrive plus a graver un seul DVD sans qu il foire au bout de 5 min (25 % environs sous nero) car le logiciel m indique "SCSI command aborted". J ai cherche differentes infos sur le net, et il parait que le probleme viendrait d un incomptatibilite avec les pilotes nvidia
Voici quelques infos sur ma config :
CM Gigabyte P35C-DS3R
Proc E6850
CG Twintech 8800 GTS 320 Mo
Nero version 6.0.0.11
Ayant pas mal de DVD a graver, d avance merci pour votre aide !!!
