écran bleu
écran bleu - Matériels & problèmes divers - Hardware
Marsh Posté le 22-02-2014 à 11:32:17
Bonjour, j'ai toujours un écran bleu et j'aimerais savoir d’où il vient avec WhoCrashed j'ai ça.
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 22/02/2014 10:20:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022214-17269-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0x22C9ED)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF960002FC9ED, 0xFFFFF88008B5C110, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\win32k.sys
product: Système d’exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Pilote Win32 multi-utilisateurs
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Merci.
Marsh Posté le 23-02-2014 à 19:35:08
d'autre pfff
On Sun 23/02/2014 18:32:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022314-7347-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0x27C124)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF9600035C124, 0xFFFFF8800ABDFA10, 0x0)
On Sun 23/02/2014 11:42:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022314-6552-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0xC4283)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF960000E4283, 0xFFFFF88008A0C000, 0x0)
Marsh Posté le 25-02-2014 à 10:04:09
encore un c'est vraiment chiant.
On Tue 25/02/2014 08:59:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022514-8845-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF9600023C9ED, 0xFFFFF8800916E110, 0x0)
Marsh Posté le 25-02-2014 à 11:12:15
C'est toujours l'erreur 0xC0000005, pas la peine d'en poster une chaque jour.
Tu pourrais voir avec CCleaner si tu n'as pas d'erreur de registre.
Derniers programmes installés? Ça peut aussi être causé par un bug de Visual C++.
Marsh Posté le 25-02-2014 à 12:20:49
Aucune erreur de registre, Je l'avais sur mon ancien seven et j'ai formaté j'en es eu un direct après la réinstallation. Sur mon premier écran bleu j'avais ça http://nsa20.casimages.com/img/201 [...] 938576.jpg
Marsh Posté le 25-02-2014 à 12:40:27
Quel SSD as-tu?
essaye de désinstaller SSDFresh.
Marsh Posté le 25-02-2014 à 12:43:19
Mon ssd, Samsung SSD 840 PRO 128 Go.
Je l'es désinstaller.
Message édité par Profil supprimé le 25-02-2014 à 12:44:08
Marsh Posté le 25-02-2014 à 12:48:51
Je n'ai aucune idée que c'est ça, c'est juste que je connaissais pas ce truc.
J'ai aussi le même Samsung sur le PC de Madame, je me contente de passer Magician de temps en temps.
Marsh Posté le 25-02-2014 à 12:58:08
C’était pour optimiser le ssd.
Marsh Posté le 13-03-2014 à 14:41:18
Moi le problème là vient par exemple, lorsque je quitte un jeux du plein écran direct après l’écran bleu. J' en ai tous les jours presques.
Marsh Posté le 13-03-2014 à 16:15:45
As tu installé un nouveau périphérique récemment?
Marsh Posté le 20-03-2014 à 08:47:29
L'écran bleu écran bleu system service exception, par exemple c'est surtout quand je lance un jeux en plein écran ou je quitte le jeux, un pote m'a conseillé de passer avec TuneUp en mode turbo en ayant tous activer pour lui avant de jouer ça marche.
Pas grave que se sont en style classique vu qu'on est en plein écran le temps d’être sur le jeu. Mais j'ai même eu l'écran bleu au moment ou je suis passer du mode normal au mode turbo.
