je comprend rien a se qui me dise pour le flashage svp
je comprend rien a se qui me dise pour le flashage svp - Matériels & problèmes divers - Hardware
Marsh Posté le 03-07-2003 à 11:46:56
voila document qui explique comment flasher ma carte Kt4V svp
aidez moi et dite moi les tru c a faire :??:
Award BIOS Flash Procedure
(Special Thanks to Forum Moderator Bas for his valuable contribution)
1. Check your BIOS for BIOS FLASH DISABLED and ENABLE it, some boards have this function.
For Example:
K7N420 Pro (MS-6373) - BIOS setup/Integrated Peripherals/BIOS Protect/Disabled
2. Know Your model number
a. Open your case and look for the MS-XXXX number on the motherboard between the PCI slots, also check the version number that is written there as well. (some motherboards are named like K7T Turbo, make sure you have the right version number)
b. Boot up your system & take a look at the top left screen during POST, you should see something like ?W6373MS v2.1 122101? This means the board is MS-6373 with BIOS version 2.1
Hint: Many systems are clearing this message very fast, the bios version is then unreadable, you can either press ?PAUSE? or disable the ?Quick Boot? in the BIOS setup.
3. Download the BIOS that matches your motherboard AND version number (some motherboards are named like K7T Turbo, make sure you have the right version number). BIOS can be found according to the CPU type of your board like if your CPU is Intel P4 478 type then look here
http://www.msi.com.tw/support/bios/socket_478.php
if you cannot find the BIOS that matches your board, try here http://www.msi.com.tw/support/bios/more.php
4. Extract the BIOS-archive that you have downloaded by double clicking to c:\test
5. Boot your system from a Win98 or WinME boot-floppy.
How to make boot floppy in case your don?t have it ready:
For Win9X, You can type [C:\ format a:/s] from the DOS prompt.
For WinMe, You can make a boot floppy from control panel--> add/remove program-->make boot floppy. Remove autoexec.bat & config.sys file if there's any.
For Win2000, there's no way to make boot floppy, so you have to either use Win9X or WinME boot floppy.
For WinXP, you can make a DOS boot disk. Go to Your Computer, right click drive A:, select Format, select copy system files.
7. When you get the A:\ prompt, type the following sequence:
C: <enter>
cd\test <enter>
C:\test> awdfl783m BIOS file
(to save or not to save old BIOS is the user?s decision)
8. Reboot your system when prompted
P.S. If your system doesn't boot after you flashed, please refer to the BIOS recovery method as described http://www.msi.com.tw/support/bios/note.htm
AMI BIOS Flash Procedure
For Example:
K7T266 Pro (MS-6380) -BIOS setup/chipset setup/BIOS protection/disabled
b. Boot up your system & take a look at the top left screen during POST, you should see something like ?A6380MS v1.7 122101? This means the board is MS-6380 with BIOS version 1.7
C: <enter>
cd\test <enter>
C:\test> amifl827 BIOS file
Flashing the BIOS for Non-FAT file system (Thanks to Forum Moderator Assaf for his valuable contribution)
1.Check your BIOS for BIOS FLASH DISABLED and ENABLE it, some boards have this function.For Example:
2.Know Your model number
b. Boot up your system & take a look at the top left screen during POST, you should see something like "A6380MS v1.7 122101" This means the board is MS-6380 with BIOS version 1.7
3.Download the BIOS that matches your motherboard AND version number (some motherboards are named like K7T Turbo, make sure you have the right version number). BIOS can be found according to the CPU type of your board like if your CPU is Intel P4 478 type then look here
<http://www.msi.com.tw/support/bios/socket_478.php>
if you cannot find the BIOS that matches your board, try here <http://www.msi.com.tw/support/bios/more.php>
4.Extract the file you have downloaded to a floppy (not the win ME/98 startup floppy) by double clocking the file in windows mode and supplying the path a:\
5.Boot the computer using a windows ME or windows 98 startup disk. It must be one of these! A plain boot disk will not be good enogh.
If you do not have Windows ME or 98 to create the floppy you can make one on a friend's computer.
6.When boot is done there will be a message on the screen showing :"Diagnostic tools were successfully loaded to drive" followed by a single letter.
This letter is the leter assigned to the RAMDRIVE. This RAMDRIVE is a virtual drive in the system memory and can be accessed and controlled like any other drive with DOS commands such as:
MD - Make Directory
Copy - copy a file
Deleate - Deleate a file
There is one important difference which is that being in the system memory this drive is wiped once the computer is restarted or shut down.
7.Replace the startup floppy with the one containing the flash utility and bios ROM files previously extracted in windows.
8.Copy the 2 files to the RAMDRIVE by using the DOS command copy.
Here is an example, in this example the flash utility is AWFL814B.EXE ,the ROM file is  w6373nms.220  and the RAMDRIVE letter assignment is D
copy awfl814b.exe d:\
copy w6337nms.220 d:\
9.Change the current working directory to the RAMDRIVE root directory, with the example case of the RAMDRIVE being drive D this is done by simply done with the command d:
10.Execute the flash utility with the ROM file as a command line argument, with this example:
awfl814b w6373nms.220
If you wish to save the current bios you must specify the full path a:\filename. Specifying only a file name will save the bios to the RAMDRIVE which will be wiped after restarting the computer and the file will not be saved.
a:\bios.old is an example of the correct way to save the bios.
11.Reboot your system when prompted
12. If your system doesn't boot after you flashed, please refer to the BIOS recovery method as described
Marsh Posté le 03-07-2003 à 11:48:07
garçon, la même chose !
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
Marsh Posté le 03-07-2003 à 11:56:17
pour le flashage d'habitude c'est, création de disquette bootable, tu y mets le programme de flash + le bios
tu bootes sur la disquette nouvellement créée, tu lances le programme de flashage en mode commande, dedans tu lui indiques le nom du fichier complet du bios, tu suis les instructions, tu redémarres, c'est bon.
peut etre que la tienne utilise une procédure différente, mais ça m'ai jamais arrivé sur ttes les cartes mères que j'ai flashé
"On reconnaît le bonheur au bruit qu'il fait quand il s'en va" Jacques Prévert
Marsh Posté le 03-07-2003 à 12:16:29
oki oki et comment on fait un disquette bootable? :??:  et aussi le bios j ai un fichier nommé a6712vms.180 c lui le bios que je met ds la disquette ? et c tout?
Marsh Posté le 03-07-2003 à 12:17:41
car la je vien de dl un un new bios avec msi live monitor et ce fichier c carement un install sa le fait pas tout seul ce truc avec msi live monitor car c un fichier install et la y demande de l installer ou pas je fai koi?
Marsh Posté le 03-07-2003 à 13:22:29
y a quelqun?? :??:
Marsh Posté le 03-07-2003 à 16:55:37
http://forum.hardware.fr/forum2.ph [...] subcat=253
Mais combien de topic tu as mis sur le forum pour le même problème, j'en ai déja vu 2.
Marsh Posté le 03-07-2003 à 17:38:28
2 peut etre car personne ne repond :fou:
Marsh Posté le 03-07-2003 à 18:23:05
alors il faut upper
up  :bounce:
Hard work may pay off later, but lazyness pays off NOW. I work hard on hardly working
Marsh Posté le 03-07-2003 à 18:45:38
Voila une traduction :
Flasher le BIOS pour un système qui n'est pas en FAT.
1. Vérifier dans le BIOS si il y a une valeur BIOS FLASH DISABLED et mettez la à ENABLE, certaines cartes possèdent cette fonction.
Par exemple K7T266 Pro (MS-6380) - Dans le BIOS setup/chipset setup/BIOS protection/disabled (ça, c'est le cheminement pour arriver à cette valeur).
2. Connaître le numéro du modèle (de la carte mère).
a. Ouvrez votre boîtier et regardez entre les slots PCI le numéro qui a la forme MS-XXX, regardez le numéro de version qui est aussi à cet endroit. (Certaines cartes mères ont un nom en K7T Turbo, soyez sûrs du numéro de version)
b. Démarrez votre système et regardez en haut à gauche de votre écran durant le POST (= affichage des infos relatives au BIOS), vous devriez voir quelque chose qui ressemble à "A6380MS v1.7 122101". Cela signifie que la carte est une MS-6380 avec une version de BIOS 1.7
Astuce : Beaucoup de systèmes n'affiche pas cela très longtemps, la version de BIOS est alors impossible à lire, vous pouvez au choix appuyer sur la touche "PAUSE" ou dans le BIOS desactiver l'option "Quick Boot"
3. Téléchargez le BIOS (ainsi que l'utilitaire de flashage de BIOS) qui correspond à votre carte mère ET au numéro de version (Certaines cartes mères ont un nom en K7T Turbo, soyez sûrs du numéro de version). Le BIOS peut être trouver grâce au type de CPU installé sur votre système si votre CPU est du type Intel P4 478, allez voir
à cette adresse <http://www.msi.com.tw/support/bios/socket_478.php>
Si vous ne trouvez pas de BIOS qui correspond à votre carte mère, essayez ce lien <http://www.msi.com.tw/support/bios/more.php>
4. Décompressez le fichier que vous avez téléchargé sur une disquette (mais pas sur la disquette de BOOT créée avec ME ou 98) en double-cliquant sur le fichier lorsque vous êtes sous Windows et en indiquant le chemin vers a:\
5. Démarrez votre ordinateur en utilisant la disquette de BOOT créée avec ME ou 98. Il faut absolument utiliser une disquette de ce type, tout autre disquette de boot ne fait pas l'affaire.
Si vous n'avez pas windows ME ou 98 pour créer cette disquette, demandez à un copain.
6. Quand le démarrage sera fini, il y aura un message affiché à l'écran : "Les outils de diagnostic ont été correctement chargés " suivi par une lettre.
Cette lettre est celle qui a été assignée au RAMDRIVE. Ce RAMDRIVE est un lecteur virtuel créé dans la mémoire système, on peut y accéder et y effectuer des opérations comme sur n'importe quel lecteur grâce aux commandes DOS du type :
MD - pour créer un répertoire
COPY - pour copier un fichier
DELETE (ou DEL) - pour effacer un fichier
Il existe une différence importante avec ce RAMDRIVE par rapport aux autres lecteurs, c'est que celui-ci disparaît quand l'ordinateur est redémarré ou arrêté.
7. Permutez le disque de BOOT avec celui qui contient l'utilitaire servant à flasher votre BIOS et le fichier de votre nouveau BIOS.
8. Copiez ces deux fichiers sur le RAMDRIVE en utilisant la commande COPY du DOS.
Voici un exemple, dans cet exemple l'utilitaire servant à flasher votre BIOS se nomme AWFL814B.EXE, le fichier de votre nouveau BIOS w6373nms.220 et D correspond à la lettre du RAMDRIVE
9. Changez de répertoire de travail en allant sous le répertoire racine du RAMDRIVE, en suivant l'exemple donné (lettre D pour le RAMDRIVE), vous pouvez effectuer cette opération en tapant simplement d:
10. Exécuter l'utilitaire de flash de BIOS avec comme argument le nom du fichier de votre nouveau BIOS, exemple :
Si vous souhaitez sauvegarder votre BIOS actuel, vous devez spécifier le chemin complet a:\nom_du_fichier. Si vous ne spécifiez qu'un nom, votre BIOS sera sauvegardé sur la RAMDRIVE et sera effacer après avoir redémarré l'ordinateur et ainsi le fichier ne sera pas sauvegardé.
a:\bios.old est un exemple de la manière correcte de procéder pour sauvegarder le BIOS.
11. Redémarrez votre système quand le prompt s'affiche.
