est ce que quelqu'un peut m'expliquer clairement ou je dois faire la modif dans quel fichier
Toshiba notebook BIOS password backdoor This method works on all older models. Newer models
This is what you need:
1. Your notebook 2. An empty formatted diskette (720 kb or 1,44 mb) 3. A second computer (e.g. a DOS desktop PC) 4. A hex-editor (e.g. Norton DiskEdit or HexWorks)
This is what you have to do:
1. Start the desktop PC and start the hex-editor 2. Put the disk in drive A: 3. Change the first five bytes of sector 2 (boot sector is sector 1) to: 4B 45 59 00 00 4. Save it! Now you have a KEYDISK 5. Remove the disk from drive A: 6. Put the disk in the notebook drive 7. Start the notebook in Boot Mode (push the reset button) 8. Press Enter when asked for Password: 9. You will be asked to Set Password again. Press Y and Enter. 10. You now see the BIOS configuration where you can set a new password.
Marsh Posté le 25-02-2006 à 14:28:53
dans quel fichier
1. Your notebook
And that's all!
ylogg
