ALERTE mega problème, et urgent !! plus de bios ! - Matériels & problèmes divers - Hardware
Marsh Posté le 05-09-2012 à 15:36:00
Il y a deja plusieurs reponses sur ce type de probleme, le flash du bios a foiré, il faut essayer d'utiliser le bios de secours si ta carte en a un.
Marsh Posté le 05-09-2012 à 15:53:11
Voici quelques topics traitant du sujet
http://forum.hardware.fr/hfr/Hardw [...] 4874_1.htm
http://forum.hardware.fr/hfr/Hardw [...] 5282_2.htm
[EDIT] et celui la http://forum.hardware.fr/hfr/Hardw [...] 5988_1.htm
Marsh Posté le 05-09-2012 à 16:11:05
Sur ta CM tu as CrashFree BIOS 3 (permet de restaurer BIOS d'origine), tout est expliqué dans les autres topics :
voici la procedure (en anglais)
The ASUS CrashFree BIOS 3 utility is an auto recovery tool that allows you to restore the BIOS file when it fails or gets corrupted during the updating process. You can restore a corrupted BIOS file using the motherboard support DVD or a USB flash drive that contains the BIOS file.
The BIOS file in the motherboard support DVD may be older than the BIOS file published on the ASUS official website. If you want to use the newer BIOS file, download the file at support.asus.com and save it to a USB flash drive.
Recovering the BIOS
To recover the BIOS:
1. Turn on the system.
2. Insert the motherboard support DVD to the optical drive, or the USB flash drive
containing the BIOS file to the USB port.
3. The utility automatically checks the devices for the BIOS file. When found, the utility reads the BIOS file and enters ASUS EZ Flash 2 utility automatically.
4. The system requires you to enter BIOS Setup to recover BIOS setting. To ensure system compatibility and stability, we recommend that you press <F5> to load default BIOS values.
DO NOT shut down or reset the system while updating the BIOS! Doing so can cause system boot failure!
Marsh Posté le 05-09-2012 à 16:14:31
mon pc s'allume il tourne et ne s'étein pas . les topics que tu ma donner n'ont pas l'air d'etre similaire a mon problème... le pc tourne mais absolument rien a l’écran....
Marsh Posté le 05-09-2012 à 16:15:36
que dalle même pas une demie ligne .je suis dans une belle merde .
Marsh Posté le 05-09-2012 à 16:22:53
en fait le probleme est similair du fait que le flash a foiré, donc regarde le dernier topic, on explique comment utiliser le BIOS de secours.
Après si tu veux pas essayer, ben je passe mon tour.
Marsh Posté le 05-09-2012 à 16:24:14
à tout hasard as tu fais des tests basiques style clear cmos ou retirage pile ?
Marsh Posté le 05-09-2012 à 16:26:56
j'ai retirer la pile , je suis en train de faire le clear cmos.. sans grand espoir
jespere surtout ne pas me planter de jumper ....
Marsh Posté le 05-09-2012 à 16:31:54
si tu as déja fait la manip de retirer la pile inutile de faire un clear cmos ![]()
Marsh Posté le 05-09-2012 à 16:34:04
ca ne marche pas jai fait ce qui est indiquer ici http://www.overclocking-pc.fr/foru [...] te-m%E8re) ... et rien
Marsh Posté le 05-09-2012 à 16:34:50
la vache je suis dans la mmm .... en beauter
... y'a aucune solution ? ???
Marsh Posté le 05-09-2012 à 16:40:48
ben tu utilises cette procedure ecrite plus haut :
Marsh Posté le 05-09-2012 à 16:44:45
en gros ce log lié a la carte mere est cencer reconnaitre le bios de ma clié usb formater en fat 32
et bien jai rienn a l'ecran
Marsh Posté le 05-09-2012 à 16:45:26
il faudrait que tu regardes dans le manuel de CM pour le nom exact, cela depends des modeles.
Marsh Posté le 05-09-2012 à 16:48:27
suis la procédure avec un DVD et débranches tous les autres périphériques/DDs seul doit rester le lecteur DVD
Marsh Posté le 05-09-2012 à 16:50:43
lorsque je mets le logiciel avec les drivers il ne se passe rien ..
Marsh Posté le 05-09-2012 à 16:52:22
jai tout débrancher disque dur et tout perif il ne reste que mon lecteur dvd
Marsh Posté le 05-09-2012 à 16:59:43
tu as attendu, avant d'eteindre? voici la procedure en FR :
1- formater la en FAT ou FAT32
2- mettez le fichier P5KD.rom du cd de la mobo (le nom peu changer en fonction des mobo) sur la clef vierge
3- ajoutez le bios a upgrader
4- inserer la clef et demarez l ordinateur
5- attender, il va reprogrammer l eeprom
6- rebooter l ordinateur, le tour est joué
Marsh Posté le 05-09-2012 à 17:03:37
le fichier .rom tu l'as recuperé sur le site d'Asus ou sur le CD de ta CM?
Marsh Posté le 05-09-2012 à 17:06:20
en gros jai mis la mise a jours du bios sur usb en fat 32, allumer tenter la manip avec les touche au cas ou et sans . j'attends et rien ne se passe ecran noir . et rien que dalle , lors de la mise a jours le logiciel completement merdique d'asus n'a pas reussi a suprimé les donner de l'eprom.
Marsh Posté le 05-09-2012 à 17:18:13
Attention, cela ne fonctionne pas à 100% via USB.
La solution qui fonctionne à 100% c'est via CD.
Si tu as encore le CD/DVD livré avec ta carte mère, ça devrait suffir.
Sinon, graver sur DVD, le fichier téléchargé depuis le site web d'Asus.
Plus d'info sur ce topic: http://forum.hardware.fr/hfr/Hardw [...] m#t8399771
Marsh Posté le 05-09-2012 à 17:24:52
je n'est pas de graveur... je suis sur un netbook . en gros je lallume avec le cd asus rien ... il se peut que la puce soit morte ? quelle sont les chance de retrouvver le bios ? en sachant que a l'origine j'ai le bios 304 qui n'existe pas sur le site d'asus .... je suis un peut assommé a vrai dire, meme avec asrock je n'est jamais euh de problème ....
Marsh Posté le 05-09-2012 à 17:30:07
Il faudrait avoir la doc de ta carte mère et voir s'il y a une procédure d'urgence de flashage bios autre que Crashfree Bios car possible que tu n'aies pas cette fonctionnalité (ce serait étonnant tout de même)
Mais il existe peut-être une autre méthode (via des appuis touche clavier par ex).
Peux tu lire le CD d'Asus sur le netbook ?
Y a t-il un fichier ayant une extension .ROM dans la racine du CD ?
Marsh Posté le 05-09-2012 à 17:33:29
malheureusement non je ne peu pas lire ce satané cd rom .. en gros j'ai perdu tout mon taf ... car même si je change de carte mère il faut tout réinstallé ...
bon ... BON BON mouaip ...
Marsh Posté le 05-09-2012 à 17:36:55
J'ai téléchargé ta doc (version anglaise plus complète).
CrashFree Bios en version 3 est bien inclus.
Procédure depuis le DVD (fourni avec la carte mère)
- allumer le PC
- insérer le DVD
- le message "Bad BIOS checksum. Starting BIOS recovery...." doit s'afficher
- le message 'Reading file "P5QSE.ROM". Completed. puis 'Start flashing ....' doit s'afficher.
- redémarrer le PC
Question bête. Ton écran est bien toujours branché à la carte vidéo ?
Marsh Posté le 05-09-2012 à 17:38:26
ReplyMarsh Posté le 05-09-2012 à 17:41:35
| herculanum a écrit : ps : je n'est plus le manuel de la cm . |
Suis tout simplement ce que j'ai écris plus haut.
sinon manuel téléchargeable depuis : http://www.asus.com/Motherboards/I [...] /#download
Marsh Posté le 05-09-2012 à 17:43:27
wgromit désoler mais ca ne fonctionne pas, rien ne s'affiche et rien ne se passe.
Marsh Posté le 05-09-2012 à 17:48:05
a savoir également que mon bios ne se trouve plus sur le net... la version 304
Marsh Posté le 05-09-2012 à 17:48:55
Tu entends bien le DVD tourner ?
Tu es sur que l'écran est Ok ? (câble, alimentation, ...)
Des voyants spécifiques s'allument sur la carte mère ?
Pas de bips ?
Marsh Posté le 05-09-2012 à 17:58:34
alors le cd tourne, tout les cables sont ok. pas de bip ou autres voyants. c'est un peu comme si il tournait a vide. en ce qui concerne l'ecran ras. quelqu'un a t'il une corde ?
Marsh Posté le 05-09-2012 à 15:24:12
salut a vous tous , j'ai une carte mère asus p5q se2, que j'ai voulus mettre a jours via asus update, tout ce passait bien jusqu'au moment ou le logiciel n' a pas pu suprimer une partie du bios.. ou je ne sais quoi, lorsque je relance ,il ne demarre plus ... le logiciel ne detecte plus de bios ! je fais quoi ? comment ? je n'est jamais eu a faire a ce genre de problème ??? !!!
aie aie .. et dire que je dois taffer sur le pc comme un malade dès demain !!!
