[PROJECT]Overdose Case - mini-itxcase dedicated to watercooling
Overdose Case - mini-itxcase dedicated to watercooling [PROJECT] - Boitier - Hardware
Marsh Posté le 17-11-2016 à 11:41:45
Hi to all Water-cooling enthusiast,
![http://i.imgur.com/CGAUwksm.jpg http://i.imgur.com/CGAUwksm.jpg](http://i.imgur.com/CGAUwksm.jpg)
![http://i.imgur.com/vWvvvOWm.jpg http://i.imgur.com/vWvvvOWm.jpg](http://i.imgur.com/vWvvvOWm.jpg)
![http://i.imgur.com/qAUeaPGm.jpg http://i.imgur.com/qAUeaPGm.jpg](http://i.imgur.com/qAUeaPGm.jpg)
![http://i.imgur.com/D65BxLDm.jpg http://i.imgur.com/D65BxLDm.jpg](http://i.imgur.com/D65BxLDm.jpg)
I would like to present our project of mini-itx watercooling case.
It's started more than year ago while searching for perfect mini-itx fully watercooling solution.
Since then we have tried various of configs and setups to find the best match.
The result is case which support 360 radiator(up to 60mm thickness) and dedicated pump/res mountings.
SFX power supply and graphics card up to 302mm
Would like to now French hardware enthusiast opinion on this.
If anyone will like it, we can try crowdfunding this project.
We currently await final build of local manufaktur, as main goal was to manufcturer such case in Europe(Poland to be exact)
Final build will look like this:
full gallery here:http://imgur.com/a/hvDi8
Already have the working first prototype(atx psu version):
Have tested already the components and beutifully finished 5mm plexi:
Working prototype build(atx version):
https://www.youtube.com/watch?v=oQdK1rFsWvM
Some case details:
Case size is as follows:
Length:415 mm
Width:258 mm
Height: 221 mm plus feet
Various pumps support with horizontal and vertical bracket:
Side radiator (3x120mm)maximum dimensions:
Length : 415mm
Width: 135 mm
Thickness: 60 mm
SFX POWER SUPPLY:
total height space is 189 mm
recommended length will be 150mm to have space for connectors and cables.
On the way to this project we have tested various setups to find the one that suit best for SFF system with full watercooling:
We have scratch build horizontal and vertical oriented one build, even tried flexi pcie extender.
Will all the try and error the horizontal version with vertical mounted SFX psu won
What do you guys think? please share your opinion ....
thanks,
wojtek
