Snif, score de mer.. , ya qq chose que je comprends pas :( - Bench - Hardware
Marsh Posté le 04-02-2003 à 01:41:51
qq details au fait de 3dmark :
DISPLAY
Platform NVIDIA GeForce4 MX 440
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate 60 Hz
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 5105
Game 1 - Car Chase - Low Detail 92.9 fps
Game 1 - Car Chase - High Detail 39.3 fps
Game 2 - Dragothic - Low Detail 87.9 fps
Game 2 - Dragothic - High Detail 41.1 fps
Game 3 - Lobby - Low Detail 85.5 fps
Game 3 - Lobby - High Detail 41.7 fps
Game 4 - Nature Not supported by hardware
Fill Rate (Single-Texturing) 362.9 MTexels/s
Fill Rate (Multi-Texturing) 692.4 MTexels/s
High Polygon Count (1 Light) 28.8 MTriangles/s
High Polygon Count (8 Lights) 5.9 MTriangles/s
Environment Bump Mapping Not supported by hardware
DOT3 Bump Mapping 56.5 fps
Vertex Shader 38.4 fps
Pixel Shader Not supported by hardware
Advanced Pixel Shader Not supported by hardware
Point Sprites 8.0 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family AMD Athlon(tm) XP 2100+
Internal Clock 1.74 GHz
Internal Clock Maximum 1.74 GHz
External Clock 133 MHz
Socket Designation Socket 7
Type <unknown>
Upgrade ZIF Socket
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version AMD Athlon(tm) XP
CPUID 0x00000662
CACHES
Level 1
Capacity 128 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type External
DIRECTX INFO
DirectX Version 8.1
DIRECTDRAW INFO
DirectDraw Version 5.1.2600.0
DISPLAY DEVICES
Description Pilote d'affichage principal
Manufacturer NVIDIA
Name NVIDIA GeForce4 MX 440
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 62 MB
Display Driver nv4_disp.dll
Display Driver Version 6.13.10.4072
Driver WHQL Certified Yes
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 2
Vertex Shader Version 1.1
Pixel Shader Version N/A
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0171
Sub-System ID 0x00000000
Revision 0xa3
DISPLAY MODES
Resolution 320x200x16-bit RGB [565] @ 60 Hz
Resolution 320x240x16-bit RGB [565] @ 60 Hz
Resolution 400x300x16-bit RGB [565] @ 60 Hz
Resolution 480x360x16-bit RGB [565] @ 60 Hz
Resolution 512x384x16-bit RGB [565] @ 60 Hz
Resolution 640x400x16-bit RGB [565] @ 60 Hz
Resolution 640x480x16-bit RGB [565] @ 60 Hz
Resolution 800x600x16-bit RGB [565] @ 60 Hz
Resolution 848x480x16-bit RGB [565] @ 60 Hz
Resolution 1024x768x16-bit RGB [565] @ 60 Hz
Resolution 1152x864x16-bit RGB [565] @ 60 Hz
Resolution 1280x720x16-bit RGB [565] @ 60 Hz
Resolution 1280x768x16-bit RGB [565] @ 60 Hz
Resolution 1280x960x16-bit RGB [565] @ 60 Hz
Resolution 1280x1024x16-bit RGB [565] @ 60 Hz
Resolution 1360x768x16-bit RGB [565] @ 60 Hz
Resolution 1600x900x16-bit RGB [565] @ 60 Hz
Resolution 1600x1024x16-bit RGB [565] @ 60 Hz
Resolution 1600x1200x16-bit RGB [565] @ 60 Hz
Resolution 320x200x32-bit RGB [888] @ 60 Hz
Resolution 320x240x32-bit RGB [888] @ 60 Hz
Resolution 400x300x32-bit RGB [888] @ 60 Hz
Resolution 480x360x32-bit RGB [888] @ 60 Hz
Resolution 512x384x32-bit RGB [888] @ 60 Hz
Resolution 640x400x32-bit RGB [888] @ 60 Hz
Resolution 640x480x32-bit RGB [888] @ 60 Hz
Resolution 800x600x32-bit RGB [888] @ 60 Hz
Resolution 848x480x32-bit RGB [888] @ 60 Hz
Resolution 1024x768x32-bit RGB [888] @ 60 Hz
Resolution 1152x864x32-bit RGB [888] @ 60 Hz
Resolution 1280x720x32-bit RGB [888] @ 60 Hz
Resolution 1280x768x32-bit RGB [888] @ 60 Hz
Resolution 1280x960x32-bit RGB [888] @ 60 Hz
Resolution 1280x1024x32-bit RGB [888] @ 60 Hz
Resolution 1360x768x32-bit RGB [888] @ 60 Hz
Resolution 1600x900x32-bit RGB [888] @ 60 Hz
Resolution 1600x1024x32-bit RGB [888] @ 60 Hz
Resolution 1600x1200x32-bit RGB [888] @ 60 Hz
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 32-bit RGB [888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit RGB [555]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
Pixel Format 8-bit Indexed()
Pixel Format FourCC [DXT1]
Pixel Format FourCC [DXT2]
Pixel Format FourCC [DXT3]
Pixel Format FourCC [DXT4]
Pixel Format FourCC [DXT5]
3D Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, Mipmap LOD Bias Adjustment, Projected Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.04.2600.0
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter AC3 Parser Filter
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter Color Space Converter
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter DivX Decoder Filter
Filter DivX MPEG-4 DVD Video Decompressor
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter IVF source filter
Filter Indeo® audio software
Filter Indeo® video 4.4 Decompression Filter
Filter Indeo® video 5.10 Decompression Filter
Filter Internal Script Command Renderer
Filter Line 21 Decoder
Filter Line 21 Decoder 2
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Audio Decoder
Filter MPEG Layer-3 Decoder
Filter MPEG Video Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microsoft MPEG-4 Video Decompressor
Filter Microsoft Screen Video Decompressor
Filter Multi-file Parser
Filter NSC file Parser
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter Video Port Manager
Filter Video Renderer
Filter WM ASF Reader
Filter WM ASF Writer
Filter WMP CD Filter
Filter WST Decoder
Filter Wave Parser
Filter Windows Media Audio Decoder
Filter Windows Media Multiplexer
Filter Windows Media Pad VU Data Grabber
Filter Windows Media Update Filter
Filter Windows Media Video Decoder
Filter Windows Media source filter
Filter XML Playlist
MEMORY INFO
Total Physical Memory 1 GB
Free Physical Memory 805.72 MB
Total Pagefile Memory 2.47 GB
Free Pagefile Memory 2.34 GB
MEMORY ARRAYS
Max Module Capacity 1.50 GB
Location System Board
Use System
Supported Error D&C None
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 512 MB
Form Factor DIMM
Frequency 0 Hz
Slot A0 [Bank0/1]
Manufacturer
Type <unknown>
Type Details <unknown>
Enabled Size 512 MB
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot A1 [Bank2/3]
Manufacturer
Type <unknown>
Enabled Size 512 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0 bytes
Form Factor DIMM
Frequency 0 Hz
Slot A2 [Bank4/5]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer
Model nVidia-nForce
Version N/A
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Release Date 09/30/2002
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 1
Designation PCI0
Type PCI
Characteristics 5.0V, PME Signal
Data Bus Width 32
Details Available, Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 2
Designation PCI1
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 3
Designation PCI2
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 4
Designation PCI3
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 5
Designation PCI4
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation AGP
Type AGP
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
SYSTEM DEVICES
Description Pont CPU hôte standard PCI
Manufacturer (Périphériques système standard)
Vendor ID 0x10de
Device ID 0x01a4
Subsystem ID 0x00000000
Revision 0xb2
Description NVIDIA nForce 420 Memory Controller (DDR)
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ab
Subsystem ID 0x0c1110de
Revision 0xb2
Description NVIDIA nForce 220/420 Memory Controller
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ac
Revision 0xb2
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ad
Revision 0xb2
Description Pont ISA standard PCI
Vendor ID 0x10de
Device ID 0x01b2
Revision 0xc3
Description NVIDIA nForce PCI System Management
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01b4
Revision 0xc1
Description NVIDIA nForce AGP Host to PCI Bridge
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01b7
Revision 0xb2
Description Pont PCI vers PCI standard PCI
Vendor ID 0x10de
Device ID 0x01b8
Revision 0xc2
Revision 2.0
Rate 1x, 2x, 4x (4x enabled)
Aperture Size 0 bytes
Sideband Addressing supported (disabled)
Fast Write supported (enabled)
MONITOR INFO
MONITORS
Name Panneau plat numérique (1600x1200)
Manufacturer (Types d'écrans standard)
Max Width 0
Max Height 0
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack
Locale FR
Desktop Width 1280
Desktop Height 1024
Desktop BPP 32
HARD DISK INFO
HARD DISKS
Name IC35L080 AVVA07-0 SCSI Disk Device
Manufacturer (Lecteurs de disque standard)
Capacity 76.69 GB
Model IC35L080 AVVA07-0 SCSI Disk Device
Interface Type SCSI
Capacity 76.69 GB
Interface Type SCSI
Name Maxtor 6 E030L0 SCSI Disk Device
Capacity 28.63 GB
Model Maxtor 6 E030L0 SCSI Disk Device
Interface Type SCSI
Marsh Posté le 04-02-2003 à 01:48:54
hum je sais pas je sais qu'il y a 2 ans lorsque je m'interessais a ces tests, j'avais une carte 3dfx et un pauvre 1*Ghz et j'etais pas très loin !!! ![]()
Marsh Posté le 04-02-2003 à 01:52:33
fait une recherche sur la base de donné de mad onion tu va bien voir ou tu te situe ![]()
Marsh Posté le 04-02-2003 à 01:52:39
D'accord avec Unreal07, c'est ta carte qui limite. Essayes avec une ti 4200, tu verras la différence
Marsh Posté le 04-02-2003 à 01:53:47
CG une pauvre noname Geforce 4 MX 440 64 MO AGP 4x.
bah voila t'as la reponse a ta question
... désolé... ![]()
Marsh Posté le 04-02-2003 à 01:55:51
dites moi juste que j'ai eu raison de prendre ca plutôt que ma ex geforce 2 GTS hercule 64Mo ![]()
Marsh Posté le 04-02-2003 à 01:57:40
| matos666 a écrit : dites moi juste que j'ai eu raison de prendre ca plutôt que ma ex geforce 2 GTS hercule 64Mo |
hum...
perso jaurai pris la GTS !!
Marsh Posté le 04-02-2003 à 02:01:10
en fait (j'ai un topic sur le silence ou le 2d 3d); j'ai cette gforce 2 et cette gforce 4, cependant la gforce 2 a un ventillo qui reveillerais un cimetiere, et c donc pour ca que j'ai passé à la 4, en plus certains vendeurs de ordi.... m'ont news generationnnn so new perforationnnnnnn
Et comme d'autre vendeur de over.... m'ont dis ah nononon pas de zalman sur ta gts ca va griller alors j'ai mis ma G4
j'ai eu tord ?
Marsh Posté le 04-02-2003 à 02:02:52
en + bcp m'ont dis qu'elle serait mieux :
http://forum.hardware.fr/forum2.ph [...] at=109#bas
Marsh Posté le 04-02-2003 à 02:06:14
pour le zalman je sais pas trop car cest vrai elle chauffe bcp
mais moi jai eu entre les main une GTS creative et un PRO asus
je peu te dire que la creative est tres silencieuse meme plus que ma Sapphire 9500np
c'est quand meme pas mal équivalent. mais pour la "nouvelle" génération de la GF4 mx
j'y crois pas trop...
vaut mieu supporter une nouvelle technologie a 10fps ou pas la supporté du tout ?
Marsh Posté le 04-02-2003 à 02:15:35
mouais je me tate a remettre l'ancinne et retester 3dmark juste pour le fun mais j'ai peur que ca fout le bordel dans ma config ![]()
Marsh Posté le 04-02-2003 à 04:18:11
Ton score est un peu faible...tu devrais plutot taper dans les 6000 points...Par ailleurs,il ne faut pas exagerer...une MX 440,c''est quand meme clairement mieux qu'une GTS...Meme si,c'est vrai,il y a mieux évidemment...
Marsh Posté le 04-02-2003 à 11:20:36
BOn je viens de faire le test , j'ai remis ma GTS, et en effet il y a une bonne difference !!!
Mon score est là de 4200 points, bon ok ca prouivebien que la Gf4 est meixu mais alors quel score faible car à part ma CG ma config est pas trop mal
Marsh Posté le 05-02-2003 à 12:08:30
hum alors là c le pompom, j'ai essayé ca :
KG7 + 2*256 PC2100 + AMD2100+ ma merde de G4 MX et j'ai 4700 a pein
Bon je crois que je vais changer de carte
je vais certainnement prendre une leadtek 64MO winfast A250, car c'etait la meilleur avec la suma des 4200 ??
Marsh Posté le 05-02-2003 à 15:16:30
Bon je viens de me prendre la leadtek A280 (64Mo AGP 8x et TVOUT) , je sais j'ai une carte qui gère le 4x mais je suis prevoyant ne changeant pas de carte tout les 6 mois
je l'install avec les detonnator 41.09 et mon score de base sans overclocker est de 8410 points un petit peu mieux quand même, c vrai qu'elle est pas trop mal mais alors le bruit du ventillo !!!
donc ABIT KG7 + 2*256 DDR2100 noname + detonnator 41.09 + µP AMD 2100+ tout sans @clok, je vais aller voir leur site pour voir si au moins suis dans la moyenne merci à tous.
Marsh Posté le 05-02-2003 à 15:20:58
J'ai un 2000+ ± 1,67ghz
1 x 512 PC2700 Kingston (Puces Windbond)
TI4200 64mo de leadtek (A250) aux fréquences par défault
Et 10385 pts
Marsh Posté le 05-02-2003 à 15:35:04
oui c mieux mais bon je sais pas comment optimiser ma KG7 de plus j'ai mis les dernier driver VIA et j'ai cru avoir lu qu'il fallait pas installer le drivers AGP info ou intox de plus je pense que sous win xp pro il doit y avoir qq param à changer
tu confirmes ?
Marsh Posté le 05-02-2003 à 15:52:49
| matos666 a écrit : Ma config : |
133Mbits/s
sinon tu va plus vite que le bus pci ![]()
Marsh Posté le 05-02-2003 à 15:54:31
exact mais du coup je la vends cette carte mère et je garde ma KG7
donc je reste en 12.5Mo/s ![]()
Marsh Posté le 04-02-2003 à 01:37:47
Ma config :
CM ABIT NV7-133R
µP AMD XP 2100+
2 barrettes de 512Mo PC2100
disque systeme 30Go 133MO/s Maxtor (+ 2 80GO ibm mais je pense que ca c pas important)
Me drivers de cm sont à jour avec dernier bios, j'ai les dernier detonnator pour ma gforce
j'ai Win XP pro.
Mon score brut là (pas de reglage de driver de CG, pas @, pas de changement de param sur 3dmark) : 5105 !!!!
ya pas un bins ?
