[Topic Unique] [Alim] Corsair HX750 et HX850 !
Corsair HX750 et HX850 ! [Topic Unique] [Alim] - Alimentation - Hardware
Marsh Posté le 13-06-2009 à 12:21:42
        MAJ : 24.06.09
Bonjour à tous, :hello:
Intro :
Corsair revient au-devant de la scène avec une nouvelle génération d'alimentation, appartenant à la famille des célèbres HX. Les anciennent Corsair HX étaient des alimentations issues des Seasonic M12 ; en revanche, celles-ci sont fabriquées par CWT. Elles jouissent d'une très grande qualité de fabrication, d'une modularité et de tensions exemplaires ; sans citer les nombreux autres avantages.
Bref, deux nouvelles alimentations déclinées en 750 Watts (Corsair HX750) et 850 Watts (Corsair HX850) viennent grossir les rangs, mais pas les mains vides puisqu'elles apportent bon nombre de nouveautés intéressantes, dont la certification 80Plus Or !
Descriptif de Corsair :
Corsair Professional Series power supply units have been designed by Corsair and engineered to the highest quality standards to meet the demands of enthusiasts that expect the very best. The Corsair Professional Series HX750W PSU utilizes advanced DC-to-DC circuitry and meets 80 PLUS SILVER MAJ : 80Plus Or  certification standards for up to 90% energy-efficiency*, reducing wasted energy and lowering the amount of excess heat generated. Corsair Professional Series power supplies are built using industrial grade electrical components, ensuring the stable, clean and reliable voltages that are essential for high-end gaming PCs and workstations.
Corsair Professional Series power supplies boast an innovative cabling configuration that uses low-profile, flat modular cables that reduce air friction to help maximize airflow through the computer chassis. The modular design also simplifies installation as it allows unprecedented flexibility in using only those cables which are needed.
* Tested at room temperature, using a 50% load and 230V AC input.
Corsair HX750W Features:
Guaranteed to sustain its full rated wattage at an ambient temperature of 50°C
Up to 90% energy-efficiency under real-world load conditions*
Single +12V rail design providing up to 62A
Multi-GPU ready
105°C solid state capacitors
Active Power Factor Correction (PFC) with PF value of 0.99
Supports ATX12V 2.3 and EPS12V 2.91 standards. Backwards compatible with ATX12V 2.01
Auto switching circuitry for universal AC input from 90-264V
Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection provide complete component safety
Dimensions: 150mm(W) x 86mm(H) x 180mm(L)
MTBF: 100,000 hours
Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
Article introduisant les Corsair sur le marché (PC World) :
Deux nouvelles alimentations rejoignent le catalogue de Corsair.
Le fabricant Corsair annonce deux nouvelles alimentations, appartenant à la gamme professionnelle, qui ont de grandes chances de faire grand bruit, et ceci dans le bon sens. Pour rappel, les alimentations Corsair utilisent des blocs d’origine Seasonic et pour cette raison sont très appréciées par les utilisateurs.
Ces alimentations seront toutes deux certifiées 80+ Silver MAJ : 80Plus Or, c'est-à-dire qu’elles bénéficient d’un rendement de l’ordre de 85% à 90% voir éventuellement plus. Et elles seront déclinées en deux capacités : la HX850W qui disposera de 850 Watts et la HX750W de 750 Watts.
Elles disposeront d’un rail unique de 12V capable de supporter 62 A ou 70 A, en fonction du modèle. Et bénéficieront également de nombreuses protections contre la surintensité, la surtension, la surcharge, la sous-alimentation et les courts-circuits. Leurs condensateurs à électrolyte solide pourront quant à eux supporter des températures de 105°C.
Enfin, elles seront dotées des câbles suivants : 1x 20/24 broches ATX, 2x EPS/ATX 4/8 broches, 12x S-ATA, 2x floppy, 6x PCIe 6/8 broches (8x pour la HX850W) et 8x Molex (12x pour la HX850W).
Ces alimentations doivent arriver très prochainement à un prix encore non communiqué, mais elles jouiront d’une garantie de 7 ans !
Caractéristiques générales (Synthèse) :
Prise en charge de l'ATX12V v2.3 / 2.01 et de l'EPS 12V 2.91 standard
Ventilateur ultra silencieux de 140 mm à double roulement à billes pour une bonne aération
Économie énergétique supérieure à 80 % pour des charges de 20, 50 et 100% générant ainsi moins de chaleur et réduisant votre facture d'électricité
Correction du facteur de puissance active (99 %) pour une alimentation nette et fiable de votre système
Sortie CA universelle 90~264 V pour une analyse et une détection automatique du voltage
Rail simple +12 V pour une compatibilité maximale avec les composants dernier cri
Protection contre les surintensités/surtensions/surcharges, les sous-tensions et les courts-circuits pour une sécurité maximale des composants essentiels de votre système
Condensateurs de haute qualité pour une performance et une fiabilité sans précédent
Câbles extra long entièrement gainés adaptés aux châssis tour pleine taille
Dimensions HX750W : 150 mm (l) x 86 mm (P) X 180 mm (L)
TMBF : 100 000 heures
Note : De plus, certains utilisateurs pouvaient quelque fois trouver les cable légerement trop courts pour les très grands boitiers (avec rangement sur la partie arrière), hors pour ces deux nouveaux modèles profitent à présent de cables rallongés puisqu'il est à présent précisé : "Câbles extra long".
Photos : (voir aussi et surtout quelques posts plus bas...)
http://static1.imgrdc.com/composant/images/produits/big/CMPSU-750HXEU.jpghttp://media.ldlc.com/ld/products/00/00/70/58/LD0000705804_1.jpg
http://img.hexus.net/v2/news/corsair/corsair-hx750-new.jpg
Courbes :
http://www.corsair.com/products/hx750/hx750-noise-chart_th.gifhttp://www.corsair.com/products/hx750/hx750-efficiency-chart_th.gif
http://img.ncix.com/images/38649_1.jpg
Package : (voir 2 posts en-dessous)
Section TESTS :
Anglais :
Français : -
Section "Critiques Utilisateurs" :
MANUEL des HX750 & HX850
Bon voilà, nous touchons à la fin de ce premier post. Il n'y a plus qu'à attendre les tests du web et les tests des premiers utilisateurs dont je ferais parti ; la mienne devrait arriver dès lundi. :)
Leurs prix sont de 139€ pour la HX750 et de 159€ pour la HX850. ;)
Voili Voilou ! ;)
Message édité par the_bhaal le 24-06-2009 à 13:09:46
Topic Ventes - Bhaal -
Marsh Posté le 14-06-2009 à 17:58:16
T'es un boss  :jap: je squattaïl  :D
Marsh Posté le 14-06-2009 à 18:22:29
Salut TheBhaal!  :hello:
Les 2 graphiques sont trop petits pour pouvoir les lire, même si on sait qu'il s'agit respectivement du "noise-chart" et du "efficiency-chart".
Aussi, la série Professional HX inclut un modèle 450W. Les nouveaux modèles finissent par 50 (450, 750 et 850); les anciens par 20 (520 et 620).
Message édité par PitOnForum le 15-06-2009 à 01:04:55
Marsh Posté le 14-06-2009 à 20:09:50
Package :
1 x http://www.corsair.com/_images/products/hx_atx_24pin.jpg (ATX 24 pin & 20 pin compatible)
2 x http://www.corsair.com/_images/products/hx_eps-atx12v_8-4_pin.jpg (EPS/ATX12V 8-4 pin)
4 x http://www.corsair.com/_images/products/hx_pci-e_6plus2-pin.jpg (PCI-E 6+2 pin)
12 x http://www.corsair.com/_images/products/hx_sata.jpg (SATA)
8 x http://www.corsair.com/_images/products/hx_4-pin_peripheral.jpg (4 pin Peripheral)
2 x http://www.corsair.com/_images/products/hx_floppy.jpg (Floppy)
Message édité par the_bhaal le 14-06-2009 à 20:11:07
Marsh Posté le 14-06-2009 à 20:10:34
Salut les zigotos ! :hello:
Je vais voir si j'arrive à trouver ces graphiques en plus grands sur la toile, PitOnForum. ;)
En revanche, la HX450 faisait partie de la vague précédente, elle ne profite par exemple "que" de la certification "80 Plus Bronze" (au lieu du Silver) ou un ventilo de 120 mm au lieu d'un 140mm ; et il y a sûrement d'autres petits changements dans ce goût là... :)
Message édité par the_bhaal le 14-06-2009 à 20:13:21
Marsh Posté le 15-06-2009 à 01:11:58
PitOnForum a écrit :
page dédiée à HX450 sur le site de Corsair: http://www.corsairmemory.com/produ [...] fault.aspx (le HX450W est le plus récent de la série HX, il fut lancé le 26 novembre 2008: http://www.corsairmemory.com/news/ [...] ?id=759424 )
C'est comme Seasonic: différenciation qualtitative (marketing oblige) entre d'une part les modèles de fortes puissances et d'autre part ceux de moindres puissances...
Je me demande s'il y aura une version Pro HX650W et Pro HX550W pour combler le vide.
Message édité par PitOnForum le 06-07-2009 à 21:21:58
Marsh Posté le 15-06-2009 à 01:19:24
Les courbes en grand pour les modèles 750 et 850
noise-chart du Corsair Professional HX750W
http://www.corsair.com/products/hx750/hx750-noise-chart.gif
ventilation constante jusqu'au 70% de charge, soit 525Watts
noise-chart du Corsair Professional HX850W
http://www.corsair.com/products/hx850/hx850-noise-chart.gif
ventilation constante jusqu'au 70% de charge, soit 595Watts
efficiency-chart du Corsair Professional HX750W
http://www.corsair.com/products/hx750/hx750-efficiency-chart.gif
relevés des rendements à 20% de charge = 150Watts, à 50% de charge = 375Watts et à 100% de charge = 750Watts
le rendement maximal est atteint à 50% de charge = 375Watts
pas de données communiquées pour de faibles et très faibles charges, qui doivent sûrement s'effondrer
efficiency-chart du Corsair Professional HX850W
http://www.corsair.com/products/hx850/hx850-efficiency-chart.gif
relevés des rendements à 20% de charge = 170Watts, à 50% de charge = 425Watts et à 100% de charge = 850Watts
le rendement maximal est atteint à 50% de charge = 425Watts
Message édité par PitOnForum le 15-06-2009 à 22:04:21
Marsh Posté le 15-06-2009 à 01:31:46
à titre de comparaison, voici les courbes des modèles anciens, des 520 et 620:
http://www.corsair.com/_images/charts/hx520w_noise.jpg
http://www.corsair.com/_images/charts/hx620w_noise.jpg
http://www.corsair.com/_images/charts/hx520w_efficiency.jpg
http://www.corsair.com/_images/charts/hx620w_efficiency.jpg
Marsh Posté le 15-06-2009 à 01:33:44
Ah impeccable, merci. :)
Bonne question, mais je ne pense pas qu'ils combleront le vide dans l'immédiat, ils resteront plutôt sur les HX520 & HX620...
Marsh Posté le 15-06-2009 à 01:42:47
On voit que désormais la ventilation est gérée différemment.
Les nouveaux modèles maintiennent le plus possible le ventilateur à vitesse constante et le point culminant a drastiquement baissé, sans doute pour d'avantage de confort sonore. Par contre, il semble (encore faut-il que les protocoles soient identiques) que le seuil soit plus élevé (~24dBA contre ~20dBA), mais cela reste confortable.
Message édité par PitOnForum le 15-06-2009 à 01:43:23
Marsh Posté le 15-06-2009 à 03:13:09
Arf j'aime pas les cables assembler type "plat" du PCI-E je prefere en nappe ronde moi  :kaola:  :fou:
Ex HFR : Wilfried2828 -->>  Wilfried28_2  le retour...
Marsh Posté le 15-06-2009 à 12:05:18
Erf tout pareil, c'est la seule critique (Si ça peut en être une... :D ) que je peux avoir... cette histoire de câble plat...  :cry:
Marsh Posté le 15-06-2009 à 13:34:30
Ca prend de la place pour rien  :fou:  Ont dirrait de la nappe IDE :D
Marsh Posté le 15-06-2009 à 16:17:43
et voila un test sur la hx 850:
http://www.hardocp.com/article.htm [...] RodXNpYXN0
mais en anglais.
Marsh Posté le 15-06-2009 à 17:14:37
Et surtout inaudible à l'oreille humaine. ;)
C'est pourtant plus pratique à l'intégration.
Message édité par the_bhaal le 15-06-2009 à 17:15:14
Marsh Posté le 15-06-2009 à 22:23:25
il semble qu'avec les nouveaux HX Pro 750 et 850, Corsair fasse très fort
la marque nous a habitué à de la qualité et de la fiabilité, ce qui inspire d'ores et déjà confiance
surtout la nouvelle gestion de la ventilation (ventilateur à vitesse modérée et constante jusqu'à 70% de charge) augure un grand confort acoustique
puis la révision du câblage permettra tous les usages
et en plus les prix sont ici encore bien compétitifs
la concurrence devra redoubler d'efforts pour rester dans la course
aussi, je suis impatient de voir le nouveau Seasonic X-series
Message édité par PitOnForum le 22-06-2009 à 01:58:58
Marsh Posté le 16-06-2009 à 11:26:55
En effet les Seasonic X-series devraient être sympas aussi, mais à mon avis totalement disproportionnées au niveau du prix... :/
Bon, moi je vais récupérer la mienne aujourd'hui au relai Kiala, j'ai hâte. :)
edit : eh voilà, elle est en ma possession (pffiou, la boîte est énorme !). :)
edit 2 : seulement 8 cables molex ("4 pin Peripheral" ). C'est peu pour les seconds... :/
Message édité par the_bhaal le 16-06-2009 à 14:40:02
Marsh Posté le 16-06-2009 à 15:39:35
Eh merde, moi qui ai changé d'alim pensant que c'était mon alim qui créait un problème lors de l'arrêt et qui redémarrait automatiquement... Ben non c'était pas elle.
Du coup je n'aurais pas dû en acheter une nouvelle (et ça coûtera trop cher en FDP de la renvoyer). :(
En tout cas, mon Antec NeoPower était inaunible et la Corsair ne l'est pas...
Marsh Posté le 16-06-2009 à 16:51:40
Mais pourquoi est-elle si longue :(
J'ai le poignet loin derrière | Top hontes HFR | [VDS] Montres | [VDS] de l'histoire
Marsh Posté le 16-06-2009 à 18:18:08
Plus c'est long, plus c'est bon...
Marsh Posté le 16-06-2009 à 18:49:04
Les nouveaux Corsair Professional HX ne seraient pas si bien en silence?  [:chewyy]
Ce serait terriblement décevant.  :pfff:
Marsh Posté le 16-06-2009 à 19:39:15
C'était à côté de la tour et ventilo à côté de l'oreille. :D
Maintenant dans la tour, on l'entend plus. ;)
Bon j'ai pris plein de photos, je les publie tout à l'heure. :)
:lol:
Message édité par the_bhaal le 16-06-2009 à 19:39:39
Marsh Posté le 16-06-2009 à 20:19:19
Voilà les photos :
http://i88.servimg.com/u/f88/11/88/57/78/the_bh10.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh11.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh12.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh13.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh14.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh15.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh16.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh17.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh18.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh19.jpg
Message édité par the_bhaal le 16-06-2009 à 20:20:42
Marsh Posté le 16-06-2009 à 20:19:45
http://i88.servimg.com/u/f88/11/88/57/78/the_bh20.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh21.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh22.jpg
http://i88.servimg.com/u/f88/11/88/57/78/the_bh23.jpg
Marsh Posté le 17-06-2009 à 23:04:11
Dis-nous, The-Bhaal, as-tu testé un peu l'engin, l'as-tu poussé jusque dans ses retranchements? Cela donne quoi?
Marsh Posté le 17-06-2009 à 23:07:21
Je n'ai pas encore eu le temps de la tester pleinement, je suis en partiels en ce moment. ;)
Mais je publierai peut-être un test complet dans les prochains jours (pcworld ou matbe ou site perso)...
Marsh Posté le 18-06-2009 à 22:42:14
drapal
Marsh Posté le 19-06-2009 à 00:46:05
reçu hier et je dois avouer que j'en suis plutôt satisfait, acheté sur rueducommerce pendant que les frais de ports étaient offert pour remplacer une Seasonic S12-II 500.
l'alim est plutôt silencieuse quand on se trouve à 50cm du boitier sinon les cables plats je confirme que c'est beaucoup plus simple niveau intégrations mais ça c'est pareil que les anciens modèles.
Voici un petit screen du +12v fait à l'instant, par contre il faut tenir compte du fait que ma config est tout de même loin d'être une machine de guerre : Xeon X3350 (équivalant C2Q Q9450) + Geforce 8800 gts 512
http://img23.imageshack.us/img23/7190/2009061900h10volt12.png
Marsh Posté le 19-06-2009 à 01:23:24
Nan mais c'est bcp trop haut la, parfaitement stable mais bien trop haut. La limite de la norme c'est 13.10v non?
Edit: 11,4v mini et 12.6 maxi
Message édité par bncjo le 19-06-2009 à 12:19:57
Marsh Posté le 19-06-2009 à 07:48:48
Non il ne faut pas se fier au tensions annoncées par OCCT suivant le logiciel de base, Speed fan, Everest ou autres (à programmer dans les options) ces tensions diffèrent considérablement
Dommage que l'on ne puisse lancer OCCT sur un logiciel fiable (corespondant avec Multimètre) se rapportant à la marque de sa carte mère
PC Alert (par ex pour MSI) AsusProb pour Asus etc...
Message édité par D'JOE le 19-06-2009 à 07:51:54
Marsh Posté le 19-06-2009 à 14:58:54
J'ai profité de la promo ldlc sur les frais de port pour me prendre la HX850 :o
Notre loi se résume en ces mots : faites ce que vous avez à faire. La satisfaction s'obtient en utilisant le pouvoir pour changer le monde. Les moyens justifient la fin. Seul l'echec est inacceptable.
Marsh Posté le 20-06-2009 à 12:53:35
Difficile de trouver des avis sur ces deux alims :(
J'aimerais savoir si elles ont tendance à siffler comme les anciennes HX sur des plateformes i7 ? Des retours la dessus ?
++ Lp
Marsh Posté le 21-06-2009 à 12:03:53
http://img23.imageshack.us/img23/7 [...] volt12.png
En effet, il ne fauit surtout pas prendre en compte les valeurs de ce graphique réalisé avec OCCT (toujours en plein délire). La seule chose à prendre en compte est la parfaite linéarité du tracé. ;)
Pour la véritable valeur de la tension, il faut impérativement utiliser un voltmètre.
++ Lp
Elle viennent tout juste de sortir. ;)
Pour ma part, je ne suis pas sous i7, mais aucun sifflement (ouf!). Et pour le moment rien à signaler, elle est impeccable.
Le week-end prochain je devrais avoir le temps de m'attaquer à des tests de la bête...
Message édité par the_bhaal le 21-06-2009 à 12:04:37
Marsh Posté le 21-06-2009 à 16:15:16
article sur Corsair HX850W:
Hardwaresecrets.com / Corsair HX850W Power Supply Review / Gabriel Torres / 19-06-2009 / http://www.hardwaresecrets.com/article/741/
Passage intéressant:
Corsair HX750W, HX850W and HX1000W have nothing to do with other models from this same series. They use a complete different (and better, by the way) design using a DC-DC converter to generate its +5 V and +3.3 V outputs, like Antec Signature series and Seasonic M12D series. These HX models are manufactured by CWT, while other models from HX series are manufactured by Seasonic.
Message édité par PitOnForum le 21-06-2009 à 16:27:26
Marsh Posté le 21-06-2009 à 16:30:47
Intro :
Corsair revient au-devant de la scène avec une nouvelle génération d'alimentation, appartenant à la famille des célèbres HX. Pour rappel, les Corsair HX sont des alimentations issues des Seasonic M12 et donc jouissant d'une très grande qualité de fabrication, d'une modularité et de tensions exemplaires ; sans citer les nombreux autres avantages.
à corriger  ;)
Marsh Posté le 21-06-2009 à 20:03:00
bonjour a tous je suis nouveau sur ce forum, je vient d'installer une corsair hx 750w en remplacement de mon ancienne alim hyper hpu-4m670 et je doit dire que cette alim est vraiment superbe.
Marsh Posté le 22-06-2009 à 20:42:32
à corriger  ;)
Me revoilou ! ;)
Merci PitOnForum, c'est corrigé ! :hello:
Message édité par the_bhaal le 22-06-2009 à 20:44:42
Marsh Posté le 22-06-2009 à 22:54:02
[:al_bundy]
Marsh Posté le 23-06-2009 à 15:17:59
idem, j'ai commandé une HX750 samedi, elle arrive demain 24 !
Elle est surdimensionnée par rapport à ma config mais vu le temps que peu faire une alim, je prefère dépenser un peu plus. La garantie de 7 ans a fini de me convaincre.
Marsh Posté le 23-06-2009 à 20:39:59
eh voilà, ça passe en 80Plus Or....
http://www.puissance-pc.net/boitie [...] ?Itemid=52
Assurément ma prochaine alim cette HX850... :love:
