[Topic Unique] Seasonic X900
Seasonic X900 [Topic Unique] - Alimentation - Hardware
Marsh Posté le 18-12-2007 à 09:05:46
Bonjour et bienvenue sur le topic unique consacré à la Seasonic X900 :)
Voici ses caractéristiques qui sont vraiment propres à la marque :wahoo: :
• Super high efficiency for energy savings, up to 88% efficiency
• 3% line regulation for +12v rails for maximum stability, security and performance.
• Multiple 12V outputs with enhanced +12V current capability to broaden utilization capabilities.
• High reliability aluminium electrolytic capacitors for increased product life and reliability.
• Active power factor correction [99% PF] for reduced line noise and power distortion.
• Advanced dual forward converter circuit design for added reliability and efficiency.
• Smart and silent fan control [S2FC], one of the best-performance noise controllers available on the market.
• 8cm double ball bearing fan for increased lifetime.
• 4x PCI-Express connectors to support high-end graphic cards. With 6p to 8p PCI-E adapters x2
• All in one DC cabling to support PC, IPC, workstations, servers and dual CPU systems.
• Patented easy swap peripheral connectors for easy plug and unplug connection.
• Total protection with Over Voltage, Over Power and Short Circuit protection.
• Fixed 220V AC input.
• >100,000 hours MTBF, excluding fan.
• RoHS compliant.
• PFC harmonics compliant, EN61000-3-2: 2000
• EMI/ EMC: CE, C-tick & safety approvals: CB, TUV & Semko
Le bloc plus en détail avec les caractéristiques :
http://www.overclock3d.net/gfx/articles/2007/09/22163842650l.jpg
Voici la boîte :
http://www.overclock3d.net/gfx/articles/2007/09/22192030421l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/22192031286l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/22192032355l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/22192033997l.jpg
...ainsi que le bundle lui aussi très imposant :
http://www.overclock3d.net/gfx/articles/2007/09/23212952596l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/23212954443l.jpg
Voici la X900... et son 80mm
http://www.overclock3d.net/gfx/articles/2007/09/24114928382l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/24114930770l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/24134428385l.jpg
Messatsu !
Marsh Posté le 18-12-2007 à 09:12:06
http://www.overclock3d.net/gfx/articles/2007/09/24134429615l.jpg
Les composants internes :
http://www.overclock3d.net/gfx/articles/2007/09/24142650549l.jpg
Nous avons donc droit à un assemblage assez soigné comme vous allez le voir dans les photos ci-dessous :
http://www.overclock3d.net/gfx/articles/2007/09/24183819810l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/24183820125l.jpg
Le 80mm est un ADDA, marque utilisée pour toutes les Seasonic :
http://www.overclock3d.net/gfx/articles/2007/09/25180022733l.jpg
Voici les caractéristiques du 80mm :
Model: AD0812UB-A71GL
• Size (mm): 80x80x25
• Bearing: BALL
• Speed (RPM): 3900
• Airflow (CFM): 50.0
• Noise (dBA): 41.0
Les câbles :
http://www.overclock3d.net/gfx/articles/2007/09/25183542237l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/25183543144l.jpg
http://www.overclock3d.net/gfx/articles/2007/09/25190506941l.jpg
Messatsu !
Marsh Posté le 18-12-2007 à 09:21:39
Le 24 pins pour la carte mère :
http://www.overclock3d.net/gfx/articles/2007/09/25194053920l.jpg
... et les 8 pins :
http://www.overclock3d.net/gfx/articles/2007/09/25194054468l.jpg
Passons sans plus tarder aux tests :
http://www.overclock3d.net/gfx/articles/2007/09/25220530248l.gif
http://www.overclock3d.net/gfx/articles/2007/09/25210328714l.gif
http://www.overclock3d.net/gfx/articles/2007/09/25210328456l.gif
L'agencement des composants contribue à avoir des températures relativement basses.
Le bruit :
en idle :
http://www.overclock3d.net/dwn/art [...] 650900.wav
à 50% de Load :
http://www.overclock3d.net/dwn/art [...] 650962.wav
 et à 100% load : si vous tenez à vos oreilles ne cliquez pas sur le lien !!
http://www.overclock3d.net/dwn/art [...] 714534.wav
Conclusion :
Les avantages du bloc :
-alim ultra stable
-4 connecteurs PCI Express 6 pins et 2 connecteurs PCI Express 8 pins
-Silencieuse jusqu'à 50% de load
L'inconvénient du bloc :
-trèèèèèèèès bruyante à 100% de load : l'enregistrement parle de lui-même.
Messatsu !
Marsh Posté le 18-12-2007 à 17:33:47
il ce sont pas fouler pour le packaging et pour l'esthetisme de l'alim en tout cas... :sweat:
Message édité par Cizia le 18-12-2007 à 17:34:08
Marsh Posté le 18-12-2007 à 18:04:14
Surtout pour une alimentation 900w ce qui sert completement a rien a l'heur actuel.
Marsh Posté le 18-12-2007 à 18:51:27
completement a rien...
tu a qu'a avoir un crossfire de r600 oc+mechant quad oc et gross config(dd,ventilo,etc..)
les 900w,c'est encore beaucoup mais la il sont bien entamer!:D
Marsh Posté le 18-12-2007 à 18:58:31
Un ventilo de 80 pourquoi pas un de 120 mm!
Feed-Back
Marsh Posté le 18-12-2007 à 22:33:57
justement c'est même crade ! :fou:
Messatsu !
Marsh Posté le 18-12-2007 à 22:45:38
drapal en tout cas !!!
Marsh Posté le 18-12-2007 à 23:59:38
elle ressemble trait pour trait a une PCPower&Cooling Silencer 750w , et meme aussi a ma 610w .. :o , j'ai les meme trous d'aerations ( devant derriere et cotés ) sur ma 610 :D
UT99 singleplayer : Project Zephon
Marsh Posté le 19-12-2007 à 09:09:47
pas de doute le 80mm est à 3900rpm à 100% de load : serait-ce la preuve que seasonic est horrible dans les grosse alims à l'inverse de coolermaster qui lui est justement mauvais dans les alims standard  et est dans le top dans les grosses alims (cf les Real Power 850 et 1000 watts ). La plus grosse seasonic top est la 700 watts. Les gens vont arrêter de jurer que par seasonic maintenant. :sarcastic:
Message édité par Fssabbagh le 20-12-2007 à 10:40:28
Messatsu !
Marsh Posté le 21-12-2007 à 10:08:24
Vive les facture edf avec ces alim
Marsh Posté le 21-12-2007 à 10:16:42
pas forcément, quand tu prends par exemple une 1000 watts, ça va dépendre de tes composants qui n'auront pas forcément besoin de 1000 watts pour tourner. C'est pour cela que prendre une grosse alim pour une petite config ne servira à rien parce que sur les 1000 watts tu n'en aura réellement que pour 400 watts réels, le reste n'étant pas exploité et donc inutile car inutilisé ;)
Message édité par Fssabbagh le 21-12-2007 à 10:17:08
Messatsu !
Marsh Posté le 11-01-2008 à 19:46:04
Seasonic a anooncé à la presse qu'ils étaient "forcés" de sortir la x900 pour ne pas être hors cours dans "la course stupide aux watts"
Messatsu !
Marsh Posté le 13-01-2008 à 02:10:07
ca m'enerve tellement que j'ai envie de leur demander une explication et vous avez vu un peu son prix ??? :fou:
Message édité par Fssabbagh le 13-01-2008 à 02:10:34
Messatsu !
Marsh Posté le 18-02-2008 à 14:16:13
hypothese : sesonic sait tres bien que peu de monde vont acheter une alim de 900 watts parce qu'ils savent que les geeks regardent les tests. Ils sont en train de suivre la tendance du marche tout en sachant de facon pertinente que personne ne va l'acheter. Et comme personne ne va l'acheter ils ne vont pas faire un produit soigne voila tout. :hello: enfin pour le prix l'explication logique est que seasonic restes fidel a sa politique tarifaire que le produit soit pourri ou pas
Message édité par Fssabbagh le 18-02-2008 à 14:17:25
Messatsu !
Marsh Posté le 18-02-2008 à 14:20:38
J'ai un pote qui la possède depuis le début de ca sortit ! Il l'avait payé 289€ il me semble et elle tourne encore malgré les SLI de Ultra ou plus recament les QX9650 OC et le CrossX HD3870X2 !
Elle est vraiment pas mal comme alim mais coute trop cher par rapport à la concurrence :sweat:
• Asus ROG STRIX B550-E - AMD Ryzen 7 5800X3D - 32Go Corsair Vengeance - Sapphire Nitro+ RX7900XT - 3 x SSD - Corsair RM850x V3 - Corsair 5000X - H150i Capellix •
Marsh Posté le 18-02-2008 à 23:29:57
+1 pour la mocheté de la l'alim
je prefere de tres loin ma zalman 850hp :)
Feed back / Ach-Vente
Marsh Posté le 18-02-2008 à 23:49:20
Boarf une fois dans le boitier tu voit plus ca tête hein ;)
Marsh Posté le 18-02-2008 à 23:55:30
ha frenchement moi dans mon mozart ho que oui on la vois :D apres c'est sur que dans certain boitié l'alim n'est quasiment pas visible donc moche ou pas c'est la meme chose.
Mais bon ca me dérange quand meme qu'une alim qui coute la peau des ... n'est pas un minimum d'estétisme.
Marsh Posté le 20-02-2008 à 14:05:15
c'est surtout le foutu 80mm :kaola:
Messatsu !
Marsh Posté le 20-02-2008 à 14:44:14
toi t'as rien compris :D  :love:
http://www.matbe.com/articles/lire [...] /page4.php
http://www.matbe.com/images/biblio/art_comparatif-d-alimentations/000000056328.png
Sur le graph ici on voit clairement que c'est la realpower 850W qui est la meilleure en consommant seulement 494W alors que la raptox 550W en demande 630W :ouch:
Conclusion, plus l'alim est de bonne qualité, moins elle consommera à config PC égale.
Et ça chauffera moins aussi  ;)
Message édité par tomass le 20-02-2008 à 14:51:59
"Toute compétition est un suicide ; Plus on est conformiste, et plus on est dangereux" © Albert Jacquard / "Je crains le jour où la technologie remplacera les interactions humaines. Nous aurons alors créé une génération d'idiots". © Albert Einstein
Marsh Posté le 21-02-2008 à 09:58:02
en fait c'est parce qu'elle consommera moins qu'elle chauffera moins :
tu prends une 900 watts au rendement de 80% théoriques :
ça te fait 720 watts qui alimentent le pc le reste étant un rejet sous forme de chaleur. Il est donc vital que les alims possèdent un bon rendement car qui dit rendement élevé dit meilleure stabilité, moins de bruit et moins de chaleur produite
Un tri-sli de Ultra tourne à 782watts en charge :pt1cable:
http://www.hardware.fr/medias/photos_news/00/21/IMG0021926.gif
Messatsu !
Marsh Posté le 16-03-2008 à 01:04:04
http://www.matbe.com/images/biblio [...] 056328.png
Je savais pas que la thermaltake avait un rendement aussi excellent. Je suis quand même étonné de la médiocrité du modèle 900 de chez seasonic (en terme de bruit :/). Surtout par rapport a leur positionnement tarifaire.
Message édité par Agent heavy le 16-03-2008 à 01:08:44
Marsh Posté le 17-03-2008 à 10:51:02
On va se refrouper pour leur faire la morale : ramenez les rpg au cas ou :D
et oui la Toughpower est excellente : j'ai pris la 750 watts modulaire pour 120 euros seulement !!!!
Message édité par Fssabbagh le 17-03-2008 à 10:51:33
Messatsu !
Marsh Posté le 17-03-2008 à 14:37:45
Je l'avais acheté aussi sur un site peu connu d'ailleurs a ce prix. Dommage qu'elle fasse un peu de bruit en charge.
Marsh Posté le 04-04-2008 à 13:48:42
c'est dommage que seasonic casse son image avec cette m.. d'alim :pfff:
Messatsu !
Marsh Posté le 06-05-2008 à 22:43:01
Faut pas dire de bêtises !
Si cette alim est bruyante, la qualité de l'électronique sesonic est là ainsi que la sobriété (l'esthétique d'une alim heu osef quoi...)
Oser dire que cette alim est une merde, faut pas exagérer !
Marsh Posté le 04-11-2008 à 15:08:48
ok mais vlà le bruit aussi. :pfff:
Messatsu !
