Pc qui redemarre tout seul pendant les jeux - Alimentation - Hardware
Marsh Posté le 17-10-2016 à 15:27:51
Il te faut un soft comme Hwmonitor (gratuit).
Marsh Posté le 17-10-2016 à 15:34:59
ok je teste ça et je poste la réponse
dois je le tester pendant le jeu ?
Marsh Posté le 17-10-2016 à 15:40:57
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.0.0
Monitoring
Mainboard Model B85M-D3H (0x000001E8 - 0x009EE5F6)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 28 01 00 00 40 F3 10 00 00 00 40 80 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 30 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 09 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A30
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 0.78 Volts [0x41] (CPU VCORE)
Voltage 1 3.38 Volts [0xAB] (VCC3)
Voltage 2 12.10 Volts [0xA8] (+12V)
Voltage 3 3.36 Volts [0xA8] (+VCC)
Voltage 4 0.82 Volts [0x44] (vAXG)
Voltage 5 1.76 Volts [0x93] (CPU VTT)
Voltage 6 1.38 Volts [0x73] (DRAM)
Voltage 7 3.38 Volts [0x8D] (+3.3V)
Temperature 0 25 degC (77 degF) [0x19] (TMPIN0)
Temperature 2 22 degC (71 degF) [0x16] (TMPIN2)
Fan 0 745 RPM [0x38A] (CPU FAN)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 10 00 00 FF FF 00 00 00 80 60 02 30 8A FF FF
10 FF FF FF 77 C7 82 80 80 03 FF FF FF FF FF FF FF
20 41 AB A8 A8 44 93 73 8D 86 19 7F 16 BA 00 3C 3C
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 FF FF FF FF
50 FF D8 7F 7F 7F 40 00 00 90 5C 3D 12 65 00 00 00
60 00 14 41 46 1C 03 00 FF 00 14 32 46 1C 03 00 FF
70 00 14 32 46 1C 03 00 FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF 02 30 01 02 01 E4 E0 A8
90 FF 00 00 00 FF 00 00 00 40 97 00 00 40 F8 C1 C2
A0 BA 81 81 81 81 81 81 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 28 degC (82 degF) [0xBC2] (TZ00)
Temperature 1 30 degC (85 degF) [0xBD6] (TZ01)
Hardware monitor Intel I/O
Clock Speed 0 598.59 MHz [0x256] (Graphics)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.88 Volts [0x36B] (VIN0)
Power 0 10.95 pc (GPU)
Temperature 0 32 degC (89 degF) [0x20] (TMPIN0)
Fan 0 996 RPM [0x3E4] (FANIN0)
Fan PWM 0 30 pc [0x1E] (FANPWMIN0)
Clock Speed 0 772.03 MHz [0x304] (Graphics)
Clock Speed 1 810.00 MHz [0x304] (Memory)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
Perf timer 3.313 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core i5 4670K
Codename Haswell
Specification Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84.0 Watts
Tjmax 100.0 °C
Core Speed 3691.3 MHz
Multiplier x Bus Speed 37.0 x 99.8 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 34x
Max turbo ratio 38x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 38x
Ratio 2 cores 38x
Ratio 3 cores 37x
Ratio 4 cores 36x
TSC 3392.0 MHz
APERF 3591.0 MHz
MPERF 3392.0 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 29 degC (84 degF) (Core #0)
Temperature 1 30 degC (86 degF) (Core #1)
Temperature 2 30 degC (86 degF) (Core #2)
Temperature 3 29 degC (84 degF) (Core #3)
Temperature 4 30 degC (86 degF) (Package)
Voltage 0 1.08 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 0 16.12 W (Package)
Power 1 5.39 W (IA Cores)
Power 2 0.55 W (GT)
Power 3 10.18 W (Uncore)
Power 4 6.86 W (DRAM)
Clock Speed 0 3691.29 MHz (Core #0)
Clock Speed 1 3691.29 MHz (Core #1)
Clock Speed 2 3791.05 MHz (Core #2)
Clock Speed 3 3591.52 MHz (Core #3)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020205h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x06100800 0x7FDAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B6FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x000027AB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x35692029 0x3736342D 0x43204B30 0x40205550
0x80000004 0x342E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012200
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x24252626
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88460000
MSR 0x000001FC 0x00000000 0x0000005F
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x00001F40
MSR 0x00000610 0x0000FFD0 0x0000EA82
MSR 0x00000611 0x00000000 0x01DEB5C5
MSR 0x00000639 0x00000000 0x012CA451
MSR 0x00000641 0x00000000 0x000BF822
MSR 0x00000619 0x00000000 0x006640C0
MSR 0x00000614 0x00000000 0x000002A0
MSR 0x0000019C 0x00000000 0x88470000
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x0000236F 0x00002600
MSR 0x00000199 0x00000000 0x0000FF00
Storage
Drive 0
Device Path \\?\scsi#disk&ven_wdc&prod_wd5000aakx-00erm#4&38fbd192&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name WDC WD5000AAKX-00ERMA0
Capacity 465.8 GB
SMART Support Yes
Volume d:\, 465.8 GBytes (18.4 percent available)
Drive 1
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_840_evo_120g#4&38fbd192&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name Samsung SSD 840 EVO 120GB
Capacity 111.8 GB
SMART Support Yes
Volume c:\, 111.3 GBytes (12.0 percent available)
USB Devices
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x046D, product=0xC246
USB Device Périphérique USB composite, class=0x00, subclass=0x00, vendor=0x046D, product=0xC31C
USB Device Logitech USB Camera (HD Webcam C270), class=0xEF, subclass=0x02, vendor=0x046D, product=0x0825
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8008
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8000
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY5
Name Intel(R) HD Graphics 4600
Board Manufacturer GIGABYTE Technology
Technology 22 nm
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1458)
Model ID 0x0412 (0xD000)
Performance Level 0
Core clock 598.6 MHz
Display adapter 1
Name NVIDIA GeForce GTX 970
Board Manufacturer NVIDIA Corporation
Revision A1
Codename GM204
Technology 28 nm
Memory size 4 GB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x10DE)
Model ID 0x13C2 (0x1131)
Performance Level 0
Core clock 772.0 MHz
Memory clock 810.0 MHz
Monitor 0
Model 22M45 (LG Electronics (GoldStar))
ID GSM5A36
Serial SerialNumber
Manufacturing Date Week 5, Year 2014
Size 21.7 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 150 MHz
Gamma Factor 2.2
Marsh Posté le 17-10-2016 à 15:48:09
En fait ce que tu fais : tu ouvres le soft, tu joues 10-15 minutes et tu regardes les températures max des core du CPU et de ta carte graphique (pas la peine de faire un gros rapport comme ce que tu as generé pour le moment
Marsh Posté le 17-10-2016 à 16:06:00
ok sauf que je peux à peine lancer le jeu quelques secondes que le pc reboot direct
Marsh Posté le 17-10-2016 à 16:07:42
Si tu fais un stress test avec OCCT, ca donne quoi ?
EDIT : ca reboot sur les menus, ou en jeu ?
Marsh Posté le 17-10-2016 à 16:09:16
uniquement en jeu je fais le teste de suite merci en tout cas pour ton aide
Marsh Posté le 17-10-2016 à 16:12:41
j'ai lancé le test le pc a rebooté au bout de quelques secondes
Marsh Posté le 17-10-2016 à 16:27:25
| yules_311 a écrit : ma config est la suivant proc i5 6500 |
| yules_311 a écrit :
Ton CPU n'est pas un 6500 mais un 4670K.
Il tourne actuellement à 3.7Ghz au lieu de 3.4Ghz par défaut (et 3.8Ghz en mode turbo) (source: http://ark.intel.com/products/7504 [...] o-3_80-GHz )
La tension de base de ce cpu est 1.15V
Dans le rapport HWMon que tu as collé plus haut on peut lire:
| Citation : Voltage 0 0.78 Volts [0x41] (CPU VCORE) |
Je ne sais pas lequel des 2 est appliqué à ton CPU, mais les 2 valeurs 0.78V et 1.76V sont de toute façon mauvaises.
EDIT: il est possible que le mode économie d’énergie C1E soit activé: dans ce cas fréquence et tension CPU sont fortement diminuées lorsque tu ne sollicites pas le CPU: par exemple au moment ou tu génère un rapport avec HWMon ... donc on a qu'une vue de ta machine à un instant où elle ne crashe pas. Ça aide pas à diagnostiquer mais c'est pas ta faute. En tout cas un reset Bios ne sera pas forcément la solution miracle que j'ai entrevu à la 1ere analyse. /EDIT
Ton problème viens d'une config CPU pas stable: soit la fréquence est trop haute, soit la tension est trop basse ou trop haute, soit les 2. Du coup, dès que le CPU est un peu sollicité, il crashe tout.
Dans un 1er temps je te suggère d'aller dans le bios et de trouver l'option pour remettre tous les paramètres par défaut.
En parallèle, retourne-toi contre celui qui t'as vendu ce PC en te faisant croire que t'achetais un coreI5 de 6eme génération alors qu'il s'agit d'un 4eme génération.
Marsh Posté le 17-10-2016 à 16:34:14
Bien vu Mitch2Pain, j’avais même pas fait attention pour le 4670K
yules_311, il faut que tu ouvres ton PC est que tu nous liste les composants de ton PC car tu n'as pas forcement ce que tu penses avoir et ca change tout.
Marsh Posté le 17-10-2016 à 16:37:18
pardon c est moi qui au buggué sur le processeur j'ai bien un 4 eme génération
Marsh Posté le 17-10-2016 à 16:47:38
Voila avec everest ca evite les erreurs
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Version EVEREST v5.50.2100/fr
Module de benchmark 2.5.292.0
Site web http://www.lavalys.com/
Type de rapport Rapport rapide [ TRIAL VERSION ]
Ordinateur DESKTOP-K3DSH9M
Générateur jul5r
Système d'exploitation Windows 10 Pro Professional 6.2.9200
Date 2016-10-17
Heure 16:46
--------[ Résumé ]------------------------------------------------------------------------------------------------------
Ordinateur:
Type de système PC ACPI avec processeur x64
Service Pack du système [ TRIAL VERSION ]
Internet Explorer 9.11.14393.0
DirectX DirectX 12.0
Nom du système DESKTOP-K3DSH9M
Nom de l'utilisateur jul5r
Domaine de connexion [ TRIAL VERSION ]
Date / Heure 2016-10-17 / 16:46
Carte mère:
Type de processeur 4x , 3400 MHz
Nom de la carte mère Inconnu
Chipset de la carte mère Inconnu
Mémoire système [ TRIAL VERSION ]
Type de BIOS AMI (04/13/12)
Port de communication Port de communication (COM1)
Port de communication Intel(R) Active Management Technology - SOL (COM3)
Port de communication Port imprimante (LPT1)
Moniteur:
Carte vidéo Intel(R) HD Graphics 4600 (1024 Mo)
Carte vidéo NVIDIA GeForce GTX 970 (4095 Mo)
Moniteur Moniteur Plug-and-Play générique [NoDB] (SerialNumber)
Multimédia:
Carte audio Contrôleur High Definition Audio [10DE-0FBB] [NoDB]
Carte audio Contrôleur High Definition Audio [8086-0C0C] [NoDB]
Carte audio Contrôleur High Definition Audio [8086-8C20] [NoDB]
Stockage:
Contrôleur IDE Contrôleur AHCI SATA standard
Contrôleur de stockage Contrôleur des espaces de stockage Microsoft
Contrôleur de stockage DAEMON Tools Lite Virtual SCSI Bus
Disque dur Samsung SSD 840 EVO 120GB (111 Go)
Disque dur WDC WD5000AAKX-00ERMA0 (465 Go)
Lecteur optique DiscSoft Virtual SCSI CdRom Device
Lecteur optique TSSTcorp CDDVDW SH-224DB
État des disques durs SMART OK
Partitions:
C: (NTFS) [ TRIAL VERSION ]
D: (NTFS) 465.8 Go (85.5 Go libre)
Taille totale [ TRIAL VERSION ]
Entrée:
Clavier Périphérique clavier PIH
Souris Souris HID
Réseau:
Adresse IP principale [ TRIAL VERSION ]
Adresse MAC principale 74-D4-35-89-74-B4
Carte réseau Realtek PCIe GBE Family Controller (192. [ TRIAL VERSION ])
Périphériques:
Périphérique USB Generic USB Hub
Périphérique USB HD Webcam C270
Périphérique USB Logitech HD Webcam C270
Périphérique USB Logitech USB Camera (HD Webcam C270)
Périphérique USB Périphérique d’entrée USB
Périphérique USB Périphérique USB composite
DMI:
Distributeur du BIOS American Megatrends Inc.
Version du BIOS F9
Fabricant du système Gigabyte Technology Co., Ltd.
Nom du système B85M-D3H
Version du système To be filled by O.E.M.
Numéro de série du système [ TRIAL VERSION ]
UUID du système [ TRIAL VERSION ]
Fabricant de la carte mère Gigabyte Technology Co., Ltd.
Nom de la carte mère B85M-D3H
Version de la carte mère x.x
Numéro de série de la carte mère [ TRIAL VERSION ]
Fabricant du châssis Gigabyte Technology Co., Ltd.
Version du châssis To Be Filled By O.E.M.
Numéro de série du châssis [ TRIAL VERSION ]
Identifiant du châssis [ TRIAL VERSION ]
Type du châssis Desktop Case
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: Pont processeur hôte standard PCI [8086-0C00] [NoDB]
Offset 000: 86 80 00 0C 06 00 90 20 06 00 00 06 00 00 00 00
Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 00 50
Offset 030: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
Offset 040: 01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
Offset 050: 11 02 00 00 39 00 00 00 17 00 90 AF 01 00 00 AB
Offset 060: 05 00 00 F8 00 00 00 00 01 80 D1 FE 00 00 00 00
Offset 070: 00 00 00 FE 01 00 00 00 00 0C 00 FE 7F 00 00 00
Offset 080: 10 11 11 00 00 00 11 00 1A 00 00 00 00 00 00 00
Offset 090: 01 00 00 FE 01 00 00 00 01 00 50 4E 02 00 00 00
Offset 0A0: 01 00 00 00 02 00 00 00 01 00 60 4E 02 00 00 00
Offset 0B0: 01 00 A0 AB 01 00 80 AB 00 00 00 AB 01 00 A0 AF
Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0E0: 09 00 0C 01 61 80 80 62 D0 00 44 04 00 00 00 00
Offset 0F0: 00 00 00 00 C8 0F 03 00 00 00 00 00 00 00 00 00
B00 D01 F00: Pont PCI vers PCI [8086-0C01] [NoDB]
Offset 000: 86 80 01 0C 07 04 10 00 06 00 04 06 10 00 81 00
Offset 010: 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 20
Offset 020: 00 C0 00 D3 F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 88 00 00 00 00 00 00 00 0B 01 18 00
Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
Offset 080: 01 90 03 C8 08 00 00 00 0D 80 00 00 58 14 00 50
Offset 090: 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 10 00 42 01 01 80 00 00 20 00 00 00 03 AD 61 02
Offset 0B0: 40 00 03 D1 80 25 0C 00 00 00 40 00 00 00 00 00
Offset 0C0: 00 00 00 00 80 0B 08 00 00 64 00 00 0E 00 00 00
Offset 0D0: 43 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0F0: 00 60 01 00 4E 01 01 40 00 00 00 00 00 00 10 00
B00 D02 F00: Intel(R) HD Graphics 4600 [8086-0412] [NoDB]
Offset 000: 86 80 12 04 06 04 90 00 06 00 00 03 00 00 00 00
Offset 010: 04 00 40 D3 00 00 00 00 0C 00 00 B0 00 00 00 00
Offset 020: 81 FF 00 00 00 00 00 00 00 00 00 00 58 14 00 D0
Offset 030: 00 00 00 00 90 00 00 00 00 00 00 00 00 01 00 00
Offset 040: 09 00 0C 01 61 80 80 62 D0 00 44 04 00 00 00 00
Offset 050: 11 02 00 00 39 00 00 00 00 00 00 00 01 00 A0 AB
Offset 060: 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 05 D0 01 00 0C F0 E0 FE 71 49 00 00 00 00 00 00
Offset 0A0: 00 00 00 00 13 00 06 03 00 00 00 00 00 00 00 00
Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 01 A4 22 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0E0: 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
Offset 0F0: 00 00 00 00 00 00 00 00 00 00 06 00 18 F0 67 AA
B00 D03 F00: Contrôleur High Definition Audio [8086-0C0C] [NoDB]
Offset 000: 86 80 0C 0C 06 00 10 00 06 00 03 04 10 00 00 00
Offset 010: 04 40 91 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 10 20
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
Offset 040: 00 00 00 00 61 80 80 62 D0 00 44 04 39 00 00 00
Offset 050: 01 60 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 10 00 91 00 C0 0F 00 10 00 08 00 00 00 00 00 00
Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D14 F00: Contrôleur hôte Intel(R) USB 3.0 eXtensible - 1.0 (Microsoft) [8086-8C31] [NoDB]
Offset 000: 86 80 31 8C 06 04 90 02 05 30 03 0C 00 00 00 00
Offset 010: 04 00 90 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 07 50
Offset 030: 00 00 00 00 70 00 00 00 00 00 00 00 00 01 00 00
Offset 040: FD 01 36 80 89 C6 0F 80 00 00 00 00 00 00 00 00
Offset 050: 9F 6E 88 07 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 01 80 C2 C1 08 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 05 00 87 00 0C F0 E0 FE 00 00 00 00 61 49 00 00
Offset 0A0: 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0B0: 0F 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0C0: 03 04 20 C0 03 0C 30 00 03 0C 30 00 00 00 00 00
Offset 0D0: FF 3F 00 00 FF 3F 00 00 3F 00 00 00 3F 00 00 00
Offset 0E0: A2 00 00 00 00 00 00 00 00 00 00 00 D8 D8 D8 08
Offset 0F0: 00 00 00 00 00 00 00 00 B1 0F 06 08 00 00 00 00
B00 D16 F00: Intel(R) Management Engine Interface [8086-8C3A] [NoDB]
Offset 000: 86 80 3A 8C 06 04 10 00 04 00 80 07 00 00 80 00
Offset 010: 04 F0 91 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 3A 1C
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
Offset 040: 55 02 00 1E 20 00 01 80 0E 23 00 69 E0 1F 00 10
Offset 050: 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 00 03 00 00 01 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00
Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 05 00 81 00
Offset 090: 0C F0 E0 FE 00 00 00 00 51 49 00 00 00 00 00 00
Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
Offset 0C0: 42 1D C0 8C B4 6F E4 11 80 00 27 86 A1 C4 BB E6
Offset 0D0: DC E0 46 14 78 D9 96 D1 AA 4A 88 4B CB 19 33 98
B00 D16 F03: Intel(R) Active Management Technology - SOL (COM3) [8086-8C3D] [NoDB]
Offset 000: 86 80 3D 8C 00 04 B0 00 04 02 00 07 00 00 00 00
Offset 010: C1 F0 00 00 00 D0 91 D3 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 C8 00 00 00 00 00 00 00 13 02 00 00
Offset 0C0: 00 00 00 00 00 00 00 00 01 D0 23 00 0B 00 00 00
Offset 0D0: 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1A F00: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D [8086-8C2D] [NoDB]
Offset 000: 86 80 2D 8C 06 00 90 02 05 20 03 0C 00 00 00 00
Offset 010: 00 C0 91 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 06 50
Offset 040: 00 00 00 00 DB 05 D3 1B 00 00 00 00 00 00 00 00
Offset 050: 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
Offset 060: 20 20 81 07 00 00 00 00 01 00 00 01 00 20 00 00
Offset 070: 00 00 DF 3F 03 0C 30 00 4F 01 00 00 8C 40 00 00
Offset 080: 00 00 80 00 11 88 0C 93 70 0D 00 24 01 04 02 00
Offset 090: 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 C1 01 27 00 00 00
Offset 0E0: 00 00 00 00 FF EF FF EF FF 7F 7F F7 04 60 34 AA
Offset 0F0: 00 00 00 00 88 85 80 00 B1 0F 06 08 08 17 1A 20
B00 D1B F00: Contrôleur High Definition Audio [8086-8C20] [NoDB]
Offset 000: 86 80 20 8C 06 00 10 00 05 00 03 04 10 00 00 00
Offset 010: 04 00 91 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 02 A0
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
Offset 040: 03 00 00 17 00 00 00 00 00 00 00 00 00 80 00 00
Offset 050: 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
Offset 0C0: 00 04 02 01 00 60 00 00 00 0C 85 82 10 00 33 02
Offset 0D0: 00 0C 85 02 10 00 33 02 00 00 00 00 00 00 00 00
B00 D1C F00: Intel(R) 8 Series/C220 Series PCI Express Root Port #1 - 8C10 [8086-8C10] [NoDB]
Offset 000: 86 80 10 8C 04 04 10 00 D5 00 04 06 10 00 81 00
Offset 010: 00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 20
Offset 020: F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 0B 01 00 00
Offset 040: 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 32 01
Offset 050: 00 00 01 10 00 B2 04 00 00 00 00 00 00 00 00 00
Offset 060: 00 00 00 00 17 08 00 00 00 04 00 00 00 00 00 00
Offset 070: 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 0D A0 00 00 58 14 01 50 00 00 00 00 00 00 00 00
Offset 0A0: 01 00 03 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 01 42 18 00 00 08 80 11 8B 00 00 00 00
Offset 0E0: 00 3F 00 00 00 00 00 00 01 00 00 00 00 00 00 00
Offset 0F0: 50 00 00 00 80 05 00 00 B1 0F 06 08 01 00 02 41
B00 D1C F02: Intel(R) 8 Series/C220 Series PCI Express Root Port #3 - 8C14 [8086-8C14] [NoDB]
Offset 000: 86 80 14 8C 07 04 10 00 D5 00 04 06 10 00 81 00
Offset 010: 00 00 00 00 00 00 00 00 00 03 03 00 D0 D0 00 00
Offset 020: 80 D3 80 D3 F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 0A 03 00 00
Offset 040: 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 32 03
Offset 050: 00 00 11 70 00 B2 14 00 00 00 40 00 00 00 00 00
Offset 0E0: 00 03 00 00 00 00 00 00 01 00 00 00 00 00 00 00
Offset 0F0: 50 00 00 00 40 00 00 0C B1 0F 06 08 00 00 00 03
B00 D1D F00: Intel(R) 8/C220 USB EHCI N° 1 - 8C26 [8086-8C26] [NoDB]
Offset 000: 86 80 26 8C 06 00 90 02 05 20 03 0C 00 00 00 00
Offset 010: 00 B0 91 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Offset 040: 00 00 00 00 DB 05 83 18 00 00 00 00 00 00 00 00
Offset 060: 20 20 01 06 00 00 00 00 01 00 00 01 00 20 00 00
Offset 070: 00 00 DF 3F 03 04 20 C0 4F 01 00 00 8C 40 00 00
Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 5B 98 27 00 00 00
Offset 0E0: 00 00 00 00 EF FF FB FF FB FF DF FF 04 B0 D8 A9
B00 D1F F00: Intel(R) B85 LPC Controller - 8C50 [8086-8C50] [NoDB]
Offset 000: 86 80 50 8C 07 00 10 02 05 00 01 06 00 00 80 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 58 14 01 50
Offset 040: 01 18 00 00 80 00 00 00 01 1C 00 00 10 00 00 00
Offset 050: F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 8B 8A 8A 83 90 00 00 00 80 80 8B 83 F8 F0 00 00
Offset 070: 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0
Offset 080: 00 00 04 14 01 0A 3C 00 00 00 00 00 00 00 00 00
Offset 090: 00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 08 5E A0 18 08 38 06 00 00 46 00 00 00 00 01 00
Offset 0D0: 33 22 11 00 67 45 00 00 CF FF 00 00 08 00 00 00
Offset 0E0: 09 00 0C 10 00 00 00 00 01 00 C0 91 00 00 00 00
Offset 0F0: 01 C0 D1 FE 00 00 00 00 B1 0F 06 08 00 00 00 00
B00 D1F F02: Contrôleur AHCI SATA standard [8086-8C02] [NoDB]
Offset 000: 86 80 02 8C 07 04 B0 02 05 01 06 01 00 00 00 00
Offset 010: B1 F0 00 00 A1 F0 00 00 91 F0 00 00 81 F0 00 00
Offset 020: 61 F0 00 00 00 A0 91 D3 00 00 00 00 58 14 05 B0
Offset 030: 00 00 00 00 80 00 00 00 00 00 00 00 00 02 00 00
Offset 040: 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 05 70 01 00 0C F0 E0 FE 50 49 00 00 00 00 00 00
Offset 090: 60 29 16 96 83 01 00 29 20 02 5C 20 20 00 00 80
Offset 0A0: A8 00 00 00 39 00 00 00 12 00 10 00 48 00 00 00
B00 D1F F03: Intel(R) 8 Series/C220 Series SMBus Controller - 8C22 [8086-8C22] [NoDB]
Offset 000: 86 80 22 8C 01 00 80 02 05 00 05 0C 00 00 00 00
Offset 010: 04 90 91 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 41 F0 00 00 00 00 00 00 00 00 00 00 58 14 01 50
Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 0A 03 00 00
Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
Offset 080: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B01 D00 F00: NVIDIA GeForce GTX 970 [10DE-13C2] [NoDB]
Offset 000: DE 10 C2 13 07 00 10 00 A1 00 00 03 10 00 80 00
Offset 010: 00 00 00 D2 0C 00 00 C0 00 00 00 00 0C 00 00 D0
Offset 020: 00 00 00 00 01 E0 00 00 00 00 00 00 DE 10 31 11
Offset 030: 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
Offset 040: DE 10 31 11 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
Offset 060: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 10 00 12 00 E1 8D 2C 01
Offset 080: 30 21 00 00 03 4D 45 00 40 01 03 11 00 00 00 00
Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 13 00 04 00
Offset 0A0: 00 00 00 00 0E 00 00 00 03 00 1F 00 00 00 00 00
Offset 0B0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
B01 D00 F01: Contrôleur High Definition Audio [10DE-0FBB] [NoDB]
Offset 000: DE 10 BB 0F 06 00 10 00 A1 00 03 04 10 00 80 00
Offset 010: 00 00 08 D3 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 DE 10 31 11
Offset 030: 00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
Offset 050: 00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 10 00 02 00 E1 8D 2C 01
Offset 080: 20 29 00 00 03 4D 45 00 40 01 03 11 00 00 00 00
Offset 0A0: 00 00 00 00 0E 00 00 00 00 00 01 00 00 00 00 00
B03 D00 F00: Realtek RTL8168/8111 PCI-E Gigabit Ethernet Adapter
Offset 000: EC 10 68 81 07 04 10 00 06 00 00 02 10 00 00 00
Offset 010: 01 D0 00 00 00 00 00 00 04 40 80 D3 00 00 00 00
Offset 020: 0C 00 80 D3 00 00 00 00 00 00 00 00 58 14 00 E0
Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
Offset 040: 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
Offset 050: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 10 B0 02 02 C0 8C 90 05 00 50 10 00 11 7C 07 00
Offset 080: 00 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 00 00 00 00 1F 00 00 00 10 00 00 00 00 00 00 00
Offset 0B0: 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
Offset 0D0: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.r.K7400.L.w.VIDEO ..........IBM VGA Compatible......-P10/14/15
C000:0040 ..........P.A.....%...1................V............>..>PMIDu
C000:0080 .x............!NVIDIA GeForce GTX 970 VGA BIOS V5642............
C000:00C0 ................................Version 84.04.84.00.95 ...Copyri
C000:0100 ght (C) 1996-2015 NVIDIA Corp..............GM204 Board..........
C000:0140 ..............Chip Rev .......................................
C000:0180 ................................PCIR............r...............
C000:01C0 NPDE..............BIT......D2...^.B.%.j.C.....D.....A.....I.....
C000:0200 L.....M.....N.....P.h...S...A.T...Y.U...[.V...`.x...f.d...n.p...
C000:0240 p.u...t.i.H.......QF._.iy......................G................
C000:0280 \\N...b.....[...........L....O..M.....}F.....F...J.F...J..QFa...
C000:02C0 ._.../J.J....*....M..Eo...i..Qo..]s..^x..W................x.....
C000:0300 .H........k...l..Nn......=...7o......<.......5s..J...h...u......
C000:0340 ...P.....(.K..K#+.#N...K(.N.L...nL*L..........#]................
C000:0380 .............-.....07/02/15..........S..............2000G4010010
C000:03C0 ................C.`.`......................_ ...C.`.`...........
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
HDD Samsung SSD 840 EVO 120GB
Monitor ID GSM5A36: Moniteur Plug-and-Play générique [NoDB]
Monitor Model 22M45
Motherboard 63-0100-000001-00101111-041312-Chipset$B85M-D3H_BIOS DATE: 01/24/14 09:59:27 VER: 04.06.05
Motherboard DMIMOBO: Gigabyte Technology Co., Ltd. B85M-D3H
Motherboard DMISYS: Gigabyte Technology Co., Ltd. B85M-D3H
Motherboard Unknown
PCI/AGP 10DE-0FBB [SubSys: 10DE-1131]: Contrôleur High Definition Audio [10DE-0FBB] [NoDB]
PCI/AGP 10DE-13C2 [SubSys: 10DE-1131]: NVIDIA GeForce GTX 970 [10DE-13C2] [NoDB]
PCI/AGP 8086-0412 [SubSys: 1458-D000]: Intel(R) HD Graphics 4600 [8086-0412] [NoDB]
PCI/AGP 8086-0C00 [SubSys: 1458-5000]: Pont processeur hôte standard PCI [8086-0C00] [NoDB]
PCI/AGP 8086-0C01 [SubSys: 0000-0000]: Pont PCI vers PCI [8086-0C01] [NoDB]
PCI/AGP 8086-0C0C [SubSys: 8086-2010]: Contrôleur High Definition Audio [8086-0C0C] [NoDB]
PCI/AGP 8086-8C02 [SubSys: 1458-B005]: Contrôleur AHCI SATA standard [8086-8C02] [NoDB]
PCI/AGP 8086-8C10 [SubSys: 0000-0000]: Intel(R) 8 Series/C220 Series PCI Express Root Port #1 - 8C10 [8086-8C10] [NoDB]
PCI/AGP 8086-8C14 [SubSys: 0000-0000]: Intel(R) 8 Series/C220 Series PCI Express Root Port #3 - 8C14 [8086-8C14] [NoDB]
PCI/AGP 8086-8C20 [SubSys: 1458-A002]: Contrôleur High Definition Audio [8086-8C20] [NoDB]
PCI/AGP 8086-8C22 [SubSys: 1458-5001]: Intel(R) 8 Series/C220 Series SMBus Controller - 8C22 [8086-8C22] [NoDB]
PCI/AGP 8086-8C26 [SubSys: 1458-5006]: Intel(R) 8/C220 USB EHCI N° 1 - 8C26 [8086-8C26] [NoDB]
PCI/AGP 8086-8C2D [SubSys: 1458-5006]: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D [8086-8C2D] [NoDB]
PCI/AGP 8086-8C31 [SubSys: 1458-5007]: Contrôleur hôte Intel(R) USB 3.0 eXtensible - 1.0 (Microsoft) [8086-8C31] [NoDB]
PCI/AGP 8086-8C3A [SubSys: 1458-1C3A]: Intel(R) Management Engine Interface [8086-8C3A] [NoDB]
PCI/AGP 8086-8C3D [SubSys: 1458-1C3A]: Intel(R) Active Management Technology - SOL (COM3) [8086-8C3D] [NoDB]
PCI/AGP 8086-8C50 [SubSys: 1458-5001]: Intel(R) B85 LPC Controller - 8C50 [8086-8C50] [NoDB]
PnP INT3394: Ressources de la carte mère [NoDB]
PnP INT3F0D: Ressources de la carte mère [NoDB]
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Marsh Posté le 17-10-2016 à 19:19:54
voila je rappelle que avant et sans que je change aucun materiels ou parametrage ça marchait très bien
Marsh Posté le 17-10-2016 à 21:02:36
Évite ce genre de pâté, ca incite pas a la lecture
En gros, tu as :
- Un SSD Samsung 840 EVO 120GB
- Un HDD WD Blue (WD5000AAKX-00ERMA0)
- Une CM Gigabyte B85M-D3H
- Un 4670K
Fait un petit CMOS comme l'a dit Mitch2Pain histoire de voir.
Fait un petit Memtest de tes RAM
Un état SMART de ton HDD (peu de chance car ca fait plutôt des freeze mais dans le doute)
As-tu mise a jour ton pilote graphique ?
Marsh Posté le 17-10-2016 à 21:11:46
allez j essaye de faire tout ça
une mise à jour de la carte graphique peux jouer dessus ?
Marsh Posté le 17-10-2016 à 23:15:48
Bon je reviens aux news j'ai fait une mise a jour des drivers Nvidia , j ai fait un Clear Cmos du bios ,jai dépoussiérer un peu le boitier et les ventilos et depuis après une heure de jeu rien n a planté donc je sais pas si le problème est réglé ,s il l'est réglé je sais pas d ou çà venait mais ça l air de fonctionner.Merci à Vladobar et Mitch2pmain en tout cas.
Marsh Posté le 18-10-2016 à 14:20:50
BON ben verdict apres 24 heures ça marche niquel donc RESOLU.
merci à tous
Marsh Posté le 17-10-2016 à 14:18:09
Bonjour à tous , je viens vers vous car j'ai un petit problème.
En effet mon pc redemarre d 'une manière aléatoire mais rapide (entre 3 minutes et 20 minutes durant les jeux)
Je pense que ça peut venir de l'alim mais ça me le faisait pas avant et j'ai changé aucune pièces à mon pc.
ma config est la suivant proc i5 6500 , 8 go ram , gtx 970 et surtout l'alim c est une coolmaster g650M
je précise que ça me le fait que avec des jeux ayant des graphismes .
merci d'avance de votre précieuse aide
