Souci pilote ATI sur une HD7970 sous W8 Pro
Souci pilote ATI sur une HD7970 sous W8 Pro - Carte graphique - Hardware
Marsh Posté le 25-05-2013 à 14:40:03
bonjour,
j'ai un souci quand j'installe les drivers de ma carte version CCC 13.4 à la fin le journal installation me signale un problème qui est le suivent:
<?xml version="1.0"?>
<?xml-stylesheet type="text/xsl" href="Report.xml.xsl"?>
<monetreport xmlns:dt="urn:schemas-microsoft-com:datatypes">
  <general>
    <cmdline>-UI </cmdline>
    <time>05/25/13 14:28:41</time>
    <action>install</action>
    <download></download>
  </general>
  <dcm>
    <primary>
     <name>AMD Radeon Graphics Processor</name>
     <manufacture>Advanced Micro Devices, Inc.</manufacture>
     <chiptype></chiptype>
     <chipid>0x6798</chipid>
     <vendorid>0x1002</vendorid>
     <ssid>0x3000</ssid>
     <ssvid>0x1002</ssvid>
     <classcode>0x030000</classcode>
     <revisionid>0x00</revisionid>
    </primary>
    <device>
     <name></name>
     <chipid>0xaaa0</chipid>
     <ssid>0xaaa0</ssid>
     <classcode>0x040300</classcode>
    </device>
  </dcm>
  <exist>
<package>
 <description>AMD Gestionnaire d&apos;installation de Catalyst</description>
 <result></result>
 <version>8.0.911.0</version>
 <size>20 </size>
</package>
<package>
 <description>Microsoft Visual C++ 2010 Redistributable 64bit</description>
 <result></result>
 <version>10.0.30319</version>
 <size>9 </size>
</package>
<package>
 <description>AMD Accelerated Video Transcoding</description>
 <result></result>
 <version>12.10.100.30328</version>
 <size>3 </size>
</package>
<package>
 <description>Catalyst Control Center</description>
 <result></result>
 <version>2013.0328.2218.38225</version>
 <size>150 </size>
</package>
  </exist>
  <install>
<package>
 <result>Succeed</result>
 <size>20 </size>
</package>
<package>
 <description>Pilote d&apos;affichage AMD</description>
 <result>Fail</result>
 <version>12.104.0.0000</version>
 <size>90 </size>
</package>
<package>
 <description>Pilote audio HDMI</description>
 <version>8.0.0.8811</version>
 <size>1 </size>
</package>
  </install>
  <uninstall>
  </uninstall>
  <downloaded>
  </downloaded>
  <resource>
    <hwinfo>Informations sur le matériel</hwinfo>
    <existpkg>Packages existants</existpkg>
    <pkg2inst>Packages à installer</pkg2inst>
    <pkg2uninst>Packages à désinstaller</pkg2uninst>
    <otherdev>Autres périphériques détectés</otherdev>
    <errmsg>Messages d'erreur</errmsg>
    <name>Nom</name>
    <manufacture>Fabricant</manufacture>
    <chiptype>Type de puce</chiptype>
    <chipid>ID du périphérique</chipid>
    <otherhw>Autre matériel</otherhw>
    <download>Télécharger les packages</download>
    <succeed>Réussite</succeed>
    <fail>Échec</fail>
    <vendorid>ID du fournisseur</vendorid>
    <classcode>Code de classe</classcode>
    <revisionid>ID de la révision</revisionid>
    <ssid>ID du sous-système</ssid>
    <ssvid>ID du fournisseur du sous-système</ssvid>
    <header1>Gestionnaire d'installation de Catalyst™</header1>
    <header2>Rapport d'installation</header2>
    <finalstatus>État final :</finalstatus>
    <versionofitem>Version de l'élément :</versionofitem>
    <size>Taille :</size>
    <bytes>Mo</bytes>
  </resource>
  <error><msg>Installation du pilote : l'installation a échoué</msg></error>  <error><msg>Installation du pilote : l'installation a échoué</msg></error>  <error><msg>Installation du pilote : l'installation a échoué</msg></error></monetreport>
Voila je suis sous "Windows 8 Pro 64" je cherche une solution & pour le reste de ma config voir mon profil.
Marsh Posté le 25-05-2013 à 15:42:26
Fait une restauration de ton systeme...vers l'ancien pilote :)
Je suis objectif ! Point final.
Marsh Posté le 25-05-2013 à 16:04:49
Je viens de le faire ça fonctionne pour le moment!
Marsh Posté le 25-05-2013 à 17:44:47
OK :) redonne moi des nouvelles :)
