Probleme sappire radeon 9800 Pro 128 Mo 256 Bits - Carte graphique - Hardware
MarshPosté le 13-01-2005 à 12:49:31
Salut a tous, j espere que vous allez m aider
Ma config: CM Asus a7n8x-la 512 Mo pc 2700 Alim 380 Watt Radeon 9800 Pro
Voila alors dans catalyste j ai ca :
Windows Version 5.1.2600 DirectX Version 4.09.00.0904 Hardware Acceleration Setting Not Available Driver Caps Item Number Not Available
CPU Type AMD Athlon(tm) XP 2800+ CPU Speed 2079 MHz
IRQ Table Not Available
BIOS Version Not Available BIOS Date 10/15/03
RDTSC/MMX/SSE/3DNOW/SSE2 Not Available
North Bridge Chipset Vendor ID 10DE North Bridge Chipset Device ID 1E0 North Bridge Chipset Revision Not Available North Bridge Chipset Drivers Version Not Available North Bridge Chipset Drivers Date Not Available
South Bridge Chipset Vendor ID 10DE South Bridge Chipset Device ID 1E8 South Bridge Chipset Revision Not Available South Bridge Chipset Drivers Version Not Available South Bridge Chipset Drivers Date Not Available
Presence of Dual CPU No System RAM Amount 511 MB
Driver Packaging Version 8.082-041130a-019577C-ATI CATALYST Version 04.12 Provider ATI Technologies Inc. 2D Driver Version 6.14.10.6497 2D Driver File Path System\CurrentControlSet\Control\Video\{C21C5201-8C3F-4DE8-B825-E285E3881702}\0000 Direct3D Version 6.14.10.0277 OpenGL Version 6.14.10.4776 CATALYST Control Center Version 1.0.1796.585
Graphics Card Manufacturer Built by ATI Graphics Chipset RADEON 9800 PRO Device ID 4E48 Vendor 1002
Subsystem ID 0002 Subsystem Vendor ID 1002
Bus Type AGP Current Bus Setting AGP 8X
BIOS Version 008.017D.027.00 BIOS Part Number BK-ATI VER008.017D.027.000 BIOS Date 2004/03/04
Memory Size 128 MB Memory Type DDR SGRAM / SDRAM
Core Clock in MHz 378 MHz Memory Clock in MHz 338 MHz
Primary Display Yes
je ne comprends pas grand chose a tout ca mais ca m inquite. En plus j ai lancé 3dmark2003 et la il me sort un peu moin de 3000 alors que j ai lu les test et elle tourne a 5900!!!!!!!
Marsh Posté le 13-01-2005 à 12:49:31
512 Mo pc 2700
Alim 380 Watt
Radeon 9800 Pro
CPU Speed 2079 MHz
BIOS Date 10/15/03
Device ID 4E48
Vendor 1002
Subsystem ID 0002
Bus Type AGP
Memory Size 128 MB
Primary Display Yes
Aidez moi a y voir plus clair!!
