Catalyst 3.7 OUT ! (Voir topic R9xxx)
Catalyst 3.7 OUT ! (Voir topic R9xxx) - Carte graphique - Hardware
Marsh Posté le 04-09-2003 à 23:40:03
TJS plus de drivers...
Lien ATI 3.7 :
http://www.ati.com/support/drivers [...] submit.y=3
FIX:
Running MS Links 2003 with Anisotropic filtering and Anti-Aliasing enabled results in vertical and horizontal lines being displayed within the game. This issue is known to occur under Windows XP with a RADEON? 9700 series card installed
Switching the display resolution mode when playing Jedi Knight II or Quake 3 no longer results in display corruption being displayed on the top of the menu screen
Unreal Tournament 2003 highlight corruption is no longer seen when the pull down menu bar is used to choose a selection
The Windows XP system not responding when attempting to launch IL2 Sturmovik Forgotten Battles if the display resolution is set to 1024x768 32bpp is now resolved. This issue was known to occur on the RADEON? 9700, 9600, and 9500 series of cards
The Windows XP operating system no longer stop responding when switching the display resolution from 1280x1024 to 1600x1200 when playing Jedi Knight II
Configuring the game NASCAR Racing to 1600x1200 32 bpp under Windows ME with a RADEON? 9600 series card installed no longer results in the system not responding
Selecting the pin camera in the game MS Links 2003 no longer results in the ground not being drawn correctly in the sub window. This issue was known to occur under Windows XP with the RADEON? 9000 series card installed
Playing a multiplayer game in the lost city map in the game Will Rock no longer results in the sky flashing black images. This issue was known to occur under Windows XP with the RADEON? 9000 series card installed
Slow playback of the game Remington Big Buck Trophy Hunt is now resolved. This issue was known to occur under Windows XP with a RADEON? 9700, 9600 TX or 9500 series card installed
Configuring the game NeverWinter Nights with Nice 4 Sample Anti-Aliasing enabled and attempting to launch the game no longer results in the system failing to respond. This issue was known to occur under Windows XP with a RADEON? 9800 SE or 9500 series card installed
Enabling Anti-Aliasing and attempting to take a screen shot results in a corrupt capture when running OpenGL games such as, CounterStrike, Half-Life, Quake III or Medal of Honour: Allied Assault
The Tron 2 demo no longer runs slowly on the RADEON? 7200 and 9000 series
Anti-Aliasing support is now available for the game Giants Citizen Kabuto
The shadow image is no longer missing in the demo named Miracle
Setting the display resolution to 1024x768 32bpp and running D3D DolphinVS DX8.1 no longer results in display corruption under the Japanese version of Windows XP
Starting the TV in a windowed mode on a RADEON? 7200 All-In-Wonder series no longer results in the display going blank and the Windows XP operating system failing to respond
Running Hydravision with the Transparency feature enabled and setting the display resolution to 1024x768 16bpp no longer results in display corruption being left behind when dragging an MS Paint window over a DVD image
Tiling corruption noticed under the Windows 9X operating system when the display is set to an interlaced mode is now resolved
Changing the compatibility settings in the ATI OpenGL tab now results in the users' setting being retained when the system reboots
Setting the secondary desktop to panning mode and the primary desktop to normal mode, followed by enabling Overlay Theater Mode no longer results in display corruption being displayed on the secondary display
Installing a RADEON? 8500 series card that has two CRT connectors under Windows XP, no longer results in the display not being available on the second CRT
Connecting two display devices to a RADEON? 9700 series card no longer results in display corruption being seen in Overlay Theater Mode when playing an HDTV source
Running the 3D Pipes screen saver for an extended period of time (24 hours or longer) produces an error message indicating that the virtual memory is not enough
Resuming from suspend mode under Windows ME no longer results in the system not responding
Setting the display to 2048x1536 followed by installing the latest version of Hydravision no longer results in display corruption when relaunching the Windows Explorer
Setting the desktop display to 1024x768 32bpp and enabling OTM no longer results in display corruption when toggling between expansion and non-expansion mode while playing an MPG1 file
Help is now available when entering the Adjustments page found under the Displays tab for HDTV
Enabling clone mode followed by setting the display resolution to 1200x800 no longer results in the CRT being in pan mode
The ATI Options page no longer displays incorrect information about the graphic card's memory size under the traditional Chinese version of Windows XP
The Video BIOS number now reflects the current version number in the control panel
Text no longer appears blurred when font smoothing is enabled and set to Standard. This issue was known to occur under Windows XP with a RADEON? 8500 or 9100 series card installed
The driver component that interfaces to the DDC/CI is now working properly
When the AGP Fastwrite is disabled it no longer appears to be enabled in both the Private and Public SmartGart control panels
The option buttons for Digital Video Interface are now function correctly when the system is set to extended desktop mode
Disabling Extended Desktop with two Adapters and four Displays no longer results in corruption on one display
Sources: ATI.com
Message édité par raydi le 04-09-2003 à 23:47:25
Marsh Posté le 05-09-2003 à 01:10:23
les perf avec les ps amélioré, ouf, yavait besoin :D
Marsh Posté le 05-09-2003 à 01:26:13
+200 à 3dm03
et enfin le bug de l'overlay en theater mode fixé
j'en demandais pas plus :love:
Marsh Posté le 05-09-2003 à 01:54:39
Pour enterrer encore plus les GFFX ? :whistle:
"I wonder if the internal negative pressure in self pumping toothpaste tubes is adjusted for different market altitudes." John Carmack
Marsh Posté le 05-09-2003 à 02:26:34
DRAPAL à PULL
Marsh Posté le 05-09-2003 à 03:31:11
de Terry Makedon:
I would also like to point out at this time that CATALYST public driver posting frequence has been improved to a minimum of twelve (12!) times a year.
et ben, c'est parti pour une release par mois on dirait :wahoo:
Marsh Posté le 05-09-2003 à 03:54:35
Tu va voir les nvidiots avec leur detonator 50.xx, ils auront moins d'améliorations que la avec les catalyst 3.7 :D .
Marsh Posté le 05-09-2003 à 04:03:34
Marsh Posté le 05-09-2003 à 05:36:40
tant que tout marche bien, pourquoi changer?
Et je regarde passer les jours comme les pages blanches d'un livre qui touche à sa fin.
Marsh Posté le 05-09-2003 à 08:14:58
[:drapo]
Vais ptet changer mes cata 3.5 :whistle:
Marsh Posté le 05-09-2003 à 08:21:07
Si tout marche pour toi change pas...mais pour certains ca peut servir, cf au-dessus! [:skeye]
Marsh Posté le 05-09-2003 à 08:22:04
quel bug ?
Marsh Posté le 05-09-2003 à 11:28:56
Beegee a écrit :
quel bug ?
celui de l'overlay en mode theatre.
Marsh Posté le 05-09-2003 à 11:30:01
ChrisLeurn a écrit :
[:drapo]
attend les omega 3.7  :D
...Tuco Benedictio Pacifico Juan Maria Ramirez "dit LE PORC"...
Marsh Posté le 05-09-2003 à 13:04:01
Les Omega spour les noobs [:ddr555], t'as rien a faire, tout est dedans, spa drole [:joce]
Marsh Posté le 05-09-2003 à 13:19:49
oui, j'avais bien compris :lol:
mais ça se traduisait comment ? moi j'ai jamais eu de problème en theater mode avec une 8500 et une 9700 ...
Marsh Posté le 05-09-2003 à 13:29:35
et ben alors tant mieux, qu'est-ce que tu veux que je te dise ? ca t'avancera à quoi de savoir ce que c'est puisque de toute facon t'es pas concerné ?
(sinon, il est décrit dans la page où ATI raconte ce qu'il y a de nouveau dans ces drivers, si vraiment tu veux tout savoir)
Marsh Posté le 05-09-2003 à 13:39:13
bien sur ça resoud pas le probléme de windows xp qui crash et switch en 640*480 sur les radeon 9500/9700 :fou:
ati :gun:
Message édité par drakkeng le 05-09-2003 à 13:39:58
Marsh Posté le 05-09-2003 à 13:55:01
ati :gun:
désactive l'AGP fast write
Marsh Posté le 05-09-2003 à 13:59:22
c'est fait depuis hier je croise les doigts visiblement ça a un impact minim sur les perfs.
Marsh Posté le 05-09-2003 à 14:38:08
ben oui, c'est un pb connu [:spamafote]
Marsh Posté le 05-09-2003 à 14:44:13
et ca marche en plus [:ddr555]
Marsh Posté le 05-09-2003 à 15:05:54
Elle sort quand la 9900 ou 9800XT ?
Marsh Posté le 05-09-2003 à 15:08:09
http://rage3d.com/board/showthread [...] d=33708513
CAT 3.8 the biggest most innovative driver posting ever!
Par Terry Makedon / Responsable des drivers Catalyst  :whistle:
Marsh Posté le 05-09-2003 à 15:08:15
tu vas poser cette question sur tous les topics ?
Marsh Posté le 05-09-2003 à 15:17:07
oui, puisque personne répond...Ca sera du harcellement jusqu'à plus soif... :o
Marsh Posté le 05-09-2003 à 15:20:17
en fait on sait pas, beintot [:spamafote]
Marsh Posté le 05-09-2003 à 15:28:26
En fait , la gf fx5900 est même pas totalement directx 9 :
"Les spécifications de DirectX 9 mentionnent la nécessité d'avoir 12 buffers au moins pour le processeur graphique. Les FX 5800 et FX5900 n'en possèdent que 2 !"
Bouh Nvidia  :kaola:
Pr lire l'article en entier sur les ps 2.0 :
http://www.onversity.com/cgi-bin/p [...] P=last#060
Marsh Posté le 05-09-2003 à 15:30:22
Bouh Nvidia  :kaola:
[:plusun]
Topics : NFSU2 - NFS : Most Wanted - Volant PC Site :  NFS-Mania.com
Marsh Posté le 05-09-2003 à 18:39:40
Bouh Nvidia  :kaola:
Yen a qui lisent les news de www.tt-hardware.com  :)
Mes photos sont sur : http://alacorte.free.fr
Marsh Posté le 05-09-2003 à 18:48:51
Comment on les installe puique le contol panel est dedans. On vire les anciens drivers et l'ancien control panel et ensuite on met simplement le pack de driver ?
Marsh Posté le 05-09-2003 à 18:51:47
ben oui [:spamafote]
Marsh Posté le 05-09-2003 à 18:54:54
et quand on a une R9700 o/c par soft on fait quoi ?  :sweat:
bon j'arrete de me plaindre parce que je les ai choisi les Omega, alors si j'accepte les avantages faudra aussi accepter les inconvénients  [:spamafote]
Message édité par $$$$$$TENSHI$$$$$$ le 05-09-2003 à 18:55:15
Marsh Posté le 05-09-2003 à 18:57:19
On se suicide parce que c'est impossible d'attendre plus de 48H pour installer les derniers drivers sortis.
Marsh Posté le 05-09-2003 à 18:57:58
tu attend les omega 3.7  :whistle:
ou alors tu d/l radclock et tu l'installe seul  :sol:
Marsh Posté le 05-09-2003 à 18:58:32
bon je fais 3300 avec les derniers catalyst sur une radeon 9700 flashée en 9700 pro ...
j'viens juste d'installer la carte ...
c une club 3d
Message édité par KIKAduKANA le 05-09-2003 à 18:58:47
Marsh Posté le 05-09-2003 à 19:00:56
c une club 3d
looser :o
moi je fais 157238 :o
Marsh Posté le 05-09-2003 à 19:26:49
(intéressant)
Topic .Net - C# @ Prog
