CG mieux qu'une ATI Radeon 9200SE - Carte graphique - Hardware
Marsh Posté le 22-10-2006 à 00:35:22
Personne pour m'aider?
Marsh Posté le 22-10-2006 à 00:39:40
hello,ben en principe tout est mieus qu une 9200 se en agp..........
Marsh Posté le 22-10-2006 à 00:52:41
ou sinon une 9600 pro que l on peut trouver encore dans certaine grande surface a 60 euros...........................
Marsh Posté le 22-10-2006 à 01:01:20
AGP
PNY Nvidia GeForce 6600 128 Mo (75 euros): http://www.cdiscount.com/informati [...] &numpage=2
Twintech Nvidia GeForce 7300 GT 256 Mo DDR2 (99 euros): http://www.cdiscount.com/informati [...] &numpage=2
HIS X1300 256 Mo DDR2 AGP Dual Link DVI (89 euros): http://www.cdiscount.com/informati [...] &numpage=2
Twintech Nvidia GeForce 7600 GS 256 Mo DDR2 (109 euros): http://www.cdiscount.com/informati [...] &numpage=3
XFX nVidia GeForce 6800 XTreme 256 Mo GDDR3 350MHz/1GHz (129 euros): http://www.cdiscount.com/informati [...] &numpage=3
HIS X1650Pro IceQ 256 Mo DDR2 (134 euros): http://www.cdiscount.com/informati [...] &numpage=3
PCI EXPRESS
Asus EAX1300 PRO-TD 256 Mo (70 euros): http://www.cdiscount.com/informati [...] &numpage=2
Point Of View Nvidia GeForce 7300 GS 256 Mo DDR2 (supporte jusqu'à 512 Mo) (71 euros): http://www.cdiscount.com/informati [...] &numpage=2
Twintech Nvidia GeForce 6600 LE 256 Mo DDR (80 euros): http://www.cdiscount.com/informati [...] &numpage=2
Point Of View nVidia GeForce 6500 256 Mo DDR2 (82 euros): http://www.cdiscount.com/informati [...] &numpage=2
Sapphire Radeon X1600 PRO Advantage 256 Mo DDR2 (89 euros): http://www.cdiscount.com/informati [...] &numpage=2
PowerColor Radeon X800GTO 256 Mo GDDR3 400/590MHz (91 euros): http://www.cdiscount.com/informati [...] &numpage=2
Twintech Nvidia GeForce 7600 GS 256 Mo DDR (94 euros): http://www.cdiscount.com/informati [...] &numpage=2
HIS X1650PRO IceQ 256Mo DDR2 Dual Link DVI (115 euros): http://www.cdiscount.com/informati [...] &numpage=3
Marsh Posté le 22-10-2006 à 06:28:43
une 7600 gt dans les 150-60 euros et c'est du tout bon
EN PCI-E: http://www.ldlc.com/fiche/PB00038472.html
En AGP: http://www.ldlc.com/fiche/PB00040747.html mais elle à 190 euros
Marsh Posté le 22-10-2006 à 13:04:27
Merci pour tout ces renseignements (et je suis en AGP, le PCI-Express ne faisait que se pointer quand j'ai assemblé mon PC)
Marsh Posté le 21-10-2006 à 19:04:15
Bonjour!
Voilà, j'ai comme CG une ATI Radeon 9200 SE. Quand je l'ai acheté ça me suffisait, mais j'ai l'impression qu'elle va me lâcher sous peu (taches violettes qui apparaissent sur les surfaces 3D, plantage dès qu'il fait chaud)
Qu'est-ce que vous me conseillez de mieux, sachant que j'ai pas envie d'investir 150 voire plus dans une CG qui va être dépassée rapidement; je veut juste une CG qui soit mieux (apparement c'est une daube) et qu'on puisse trouver pas trop cher en occase (sur eBay par exemple)...
Merci d'avance
Si on attend la dernière minute pour faire quelque chose, au moins ça ne prendra qu'une minute à faire.
