AGP 4X : plantage en Direct 3D! : la SOLUCE!! - Carte graphique - Hardware
Marsh Posté le 01-08-2002 à 21:22:07
| Helios1086 a écrit a écrit : Tous ceux qui comme moi ont des freezes dans les jeux Direct 3D (surtout Warcraft III)avec l'AGP 4X peuvent corriger ce prob en allant dans le BIOS, mettre l'AGP driving control en manual et mettre la valeur AGP driving value à FF(je sais pas si ces options sont présentes dans la majeur partie des carte mères..)! Chez moi ça marche en tout cas...(Leadtek A250TD + KT7A-Raid) Toutefois dans certains jeux (comme Midtown Madness 2), les textures peuvent parfois scintiller. maintenant j'peux overclocker tranquille... Ceux qui ont ces 2 options essayez-les!! |
Marsh Posté le 01-08-2002 à 22:30:40
What does AGP driving control do and how should I set it?
Note modifying this setting changes the signal timing to the graphics card. If you get it wrong, the graphics card won't boot, and you'll be left with a black screen. The only way to remedy this is to temporarily use an old PCI graphics card, change the driving control setting, and then reboot.
ABIT recommend a driving control of DA or EA with NVidia-based GeForce GTS or MX cards. ABIT recommend a driving control of E9 with the Prolink MX with fast writes disabled. For other cards use Auto.
The following answer was provided by AskArs of Arstechnica.com:
"By selecting a manual hex range (00h-FFh) we are setting the timing of the signal that your video card's driver uses to communicate across the AGP bus
Default for the AGP Driving control is going to be 'Auto'. This is pretty much akin to your 'auto' ram-timing selection; it is the lowest-common denominator settings that are going to yield you the widest compatibility at the cost of performance.
'Manual' AGP Driving Control setting is VIA's way of skirting chipset design and driver issues, by allowing them to configure for optimal scenarios.
"Since the 'AGP Driving Control' BIOS option is specific to the VIA
chipset's AGP implementation and there are multiple motherboards based
on the VIA chipset, I would have to say that for certain motherboards
there is no magic setting that works with every graphics card and
motherboard combination. For instance, a setting of CCh on a particular
motherboard is not going to mysteriously work better with every card
than a setting of BAh."
As for how to find out the specific settings recommended for various video cards, the best recommendation would be to contact your video card vendor first (and I would attempt to contact the chipset provider as well, if they are an IHV (like nVidia)). Ask them what their recommended manual timing is.
The only straight answer on manual timings that I have been able to get is from Epox and Tyan. For the original Geforce 256's, they recommend A8h for timing control. This is independent of driver, but dependant on chipset. With the Geforce 256 GTS they recommend a manual setting of BAh. Asus, keeping with PC tradition of doing your own thing, recommends a setting of B9h for their 6600 Pure card. Tyan used to recommend DCh with everything (as a few other vendors have posted on their websites), but with all Tyan VIA-chipset motherboard BIOS updates posted after 2/15/2000, you will notice they now recommend CCh."
source :
http://www.viahardware.com/faq/kt7/kt7faq.htm
Marsh Posté le 02-08-2002 à 00:13:08
De toute façon, la KT7A a un gros problème d'alimentation du bus AGP... et les cartes Leadtek ont pas très bonne réputation...
Marsh Posté le 02-08-2002 à 01:01:54
en tout k avant de dire telle carte CG ou CM c dla merde, faut apprendre a regler SON bios! si chaque bios est parametrable c parce ke chaque config est differente! donc a chacun son reglage!
bref bienvenue dans le club des heureux utilisateurs ki se creusent un peu la tete avant dhurler au scandale
bravo
Marsh Posté le 02-08-2002 à 08:46:07
Ce prob est à moitié résolu, car maintenant ya le clignotement des textures (qui reste léger mais c'est un peu gênant, surtout dans Diablo II). J'avais trouvé dans un commentaire de chez ldlc qu'il fallait mettre l'AGP driving value à FF, mais peut-être ya t-il une meilleure valeur pour la GeForce 4...(dommage que l'article soit un peu ancien...)
Marsh Posté le 02-08-2002 à 08:55:11
| Citation : la SOLUCE!! |
Jouer en OpenGL
Marsh Posté le 02-08-2002 à 09:03:40
On est content pour toi mais maintenant que t'as résolu ton probleme explique moi l'intérêt d'activier l'AGP 4x pour Warcraft III.
Marsh Posté le 02-08-2002 à 09:14:00
Ben pour que ce soit + rapide quand j'active le FSAA 4X (vu que ça consomme de la bande passante) jpréfère joué en 1024*768 avec qu'en 1600*1200 sans.(je n'ai qu'un 17'
Et puis j'en ai un peu marre d'aller tout le temps dans le BIOS!!
Et entre 8000 et 6700 au 3D Mark j'préfère 8000!!!
Marsh Posté le 02-08-2002 à 09:17:41
| vazno75 a écrit a écrit : en tout k avant de dire telle carte CG ou CM c dla merde, faut apprendre a regler SON bios! si chaque bios est parametrable c parce ke chaque config est differente! donc a chacun son reglage! bref bienvenue dans le club des heureux utilisateurs ki se creusent un peu la tete avant dhurler au scandale |
Marsh Posté le 06-09-2002 à 21:43:33
Désolé mais j'ai eu une KT7A-R pendant trois jours, et le problème d'alimentation a été reconnu par certains utilisateurs. Une modification éléctronique sur la carte est d'ailleurs possible pour régler le problème (j'avais ce problème avec une GF2MX...).
Pour ce qui est de la réputation des cartes Leadtek, il suffit de lire les posts de ce forum pour s'en rendre compte...
Voilà
Marsh Posté le 06-09-2002 à 21:51:15
Bonsoir voila moi j ai une Gigabyte GA-7VAXP ( kt 400 chipset Via ) et une msi geforce 4ti4200 128mo et ca freeze dans els jeux dirext 3D meme 3dmark freeze direct seul CS et quake 3 ne freeze pas surment ke l open GL marche parfait je sais pas...
en tout cas tu a l air d avoir trouver la soluce mais le prob c ke dans mon Bios y a pas ca
(( y a rien en raport avec l agp a part le first display c tout c ca ke je comprend pas snifff
pas moyen de choisir le monde 4X dedans et sous win98 ca me dis je suis en 2x
donc si kelkun peu m aider dans mes problemes merci d avance
Marsh Posté le 07-09-2002 à 23:29:33
c koi tes drivers?
vai tester sur une msi k7t pro2, si les reglages peuvent etre fait et que ca marche ze te ferai de gros poutous
et oui aussi, moi je freeze sur d3d, opengl, windows ...... partout partout ![]()
Marsh Posté le 07-09-2002 à 23:36:14
avec ls 4in1440 ou41 j' était avec ma cg en 1x sous winxp au lieu de 2x, pas de prob avec ls 4in1442 P2
Marsh Posté le 01-08-2002 à 16:44:03
