Probleme de connections sur serveur ftp @home - Windows & Software
Marsh Posté le 05-07-2006 à 19:11:41
Quel est l'erreur qu'obtient ton ami ?
Marsh Posté le 05-07-2006 à 19:14:13
Je demande, chez moi ca donne ça :
(000028) 05/07/2006 19:10:20 - virus (son ip)> 230 Logged on
(000028) 05/07/2006 19:10:20 - virus (son ip)> SYST
(000028) 05/07/2006 19:10:20 - virus (son ip)> 215 UNIX emulated by FileZilla
(000028) 05/07/2006 19:10:20 - virus (son ip)> FEAT
(000028) 05/07/2006 19:10:20 - virus (son ip)> 211-Features:
(000028) 05/07/2006 19:10:20 - virus (son ip)>  MDTM
(000028) 05/07/2006 19:10:20 - virus (son ip)>  REST STREAM
(000028) 05/07/2006 19:10:20 - virus (son ip)>  SIZE
(000028) 05/07/2006 19:10:20 - virus (son ip)>  MLST type*;size*;modify*;
(000028) 05/07/2006 19:10:20 - virus (son ip)>  UTF8
(000028) 05/07/2006 19:10:20 - virus (son ip)>  CLNT
(000028) 05/07/2006 19:10:20 - virus (son ip)> 211 End
(000028) 05/07/2006 19:10:20 - virus (son ip)> PWD
(000028) 05/07/2006 19:10:20 - virus (son ip)> 257 "/" is current directory.
(000028) 05/07/2006 19:10:20 - virus (son ip)> TYPE A
(000028) 05/07/2006 19:10:20 - virus (son ip)> 200 Type set to A
(000028) 05/07/2006 19:10:20 - virus (son ip)> PASV
(000028) 05/07/2006 19:10:20 - virus (son ip)> 227 Entering Passive Mode (192,168,1,2,16,9)
(000028) 05/07/2006 19:10:21 - virus (son ip)> disconnected.
Ses logs :
Command:     USER virus
Response:     331 Password required for virus
Command:     PASS *****
Response:     230 Logged on
Command:     SYST
Response:     215 UNIX emulated by FileZilla
Command:     FEAT
Response:     211-Features:
Response:      MDTM
Response:      REST STREAM
Response:      SIZE
Response:      MLST type*;size*;modify*;
Response:      UTF8
Response:      CLNT
Response:     211 End
Status:     Connected
Status:     Retrieving directory listing...
Command:     PWD
Response:     257 "/" is current directory.
Command:     TYPE A
Response:     200 Type set to A
Command:     PASV
Error:     Disconnected from server
Error:     Could not retrieve directory listing
Error:     Timeout detected!
Marsh Posté le 05-07-2006 à 19:18:42
Si tu le fais de chez toi, il faut utiliser ton IP privée, pas ton IP publique.
Marsh Posté le 05-07-2006 à 19:21:57
C'est a dire ?
Mon ami a installé le logiciel et n'a fais aucun parametrage si ce n'est me créer un compte, et j'arrive a me connecter a son ftp ...
J'ai installé et tout laissé sur Standard ..
Marsh Posté le 05-07-2006 à 19:22:45
Demande à ton ami de désactiver le mode passif de son logiciel de client ftp.
Marsh Posté le 05-07-2006 à 19:38:37
Merci beaucoup Com21
Par contre c'est normal que ca ne marche que comme ça ?
Marsh Posté le 05-07-2006 à 19:44:07
Oui
Marsh Posté le 05-07-2006 à 19:08:08
J'ai installé un serveur ftp FileZilla sur mon pc, qui est déjà serveur web ( via easyphp ) derriere une livebox.
Le site marche bien.
J'ai ouvert mes ports 20 et 21 dans le firewall, je route la plage de ports 20 a 22 vers mon pc.
Et malgré tout un ami n'arrive pas a se connecter, il est déconnecter immédiatement ...
Qu'est ce que j'ai loupé ?
