Ecran Plasma de marque Zenith's Silver
Ecran Plasma de marque Zenith's Silver - Matériel - Video & Son
Marsh Posté le 04-12-2003 à 11:45:44
Voilà j'ai vu une petite annonce concernant un écran ZENITH'S SILVER 60" PLASMA Monitor Display...
En fait l'annonce est en anglais : "Zenith's Silver 60" plasma HDTV Monitor display is picture perfect. With a 60" diagonal screen, this thin, sleek monitor provides for a truly immersive home theater experience" pour 300 ?.
Voici la suite:
Features
    * 1280 x 720p Resolution
    * Input Signal: VGA, SVGA, XGA, HD, NTSC, SXGA
    * Brightness: 600 cd/m²
    * Viewing Angle: 160º
    * Contrast Ratio: 800:1
    * Intelligent Faroudja Image Scaling
    * Luminance Enhancement
    * Optional Speakers: 2x10 Watts
    * Remote Control
    * Aspect Ratio Correction: Normal, Wide, Zoom
Benefits
60" Plasma HDTV Monitor - Groundbreaking display technology delivers superior image clarity, color, and brightness in large-format televisions that are less than 4" thick
1280 x 720p Resolution - High resolution format produces extremely detailed imagery
800:1 Contrast Ratio - Extremely sharp contrast between light and dark images
600 cd/m2 High Brightness - Renders an incredibly bright picture, even in well-lit areas
Aspect Ratio Correction - Intelligent resizing of video and computer images to 16:9 widescreen or 4:3 conventional formats.
Intelligent Image Scaling - Faroudja/Sage scan converter seamlessly converts TV video data to PC formats without distortion or cropping images in either 4:3 or 16:9.
RS-232 Controls and NTSC, HD, VGA, SVGA, XGA and SXGA inputs - Compatible with DVD players, VCRs, computers, digital broadcasting, multimedia, and traditional video sources
Est ce qqn connait cette marque ? ou alors connait bien le plasma ?
Merci d'avance pour tout vos renseignements...
Message édité par yoann113 le 04-12-2003 à 11:46:26
Marsh Posté le 04-12-2003 à 13:04:54
C'est pas plutot 3000 € ??
Marsh Posté le 04-12-2003 à 16:58:28
clair... ca doit etre une annonce sur les news ou ebay pour atirer le badau... et mieux l'arnaquer :D
Ce qui faut se dire avec le plasma, c'est qu'a moins de 4000 ya anguille sous roche : vieille dalle reconditionnée sous nouvelle marque (genre skyline) (on en est a la 5 ou 6eme generation de dalle et ya eu d'enormes progres), tombe du camion, scam, ...
Je m'y connais pas tellement en plasma mais en cherchant une bonne affaire, j'ai assez vite laissé tomber (je cherchais une dalle vers les 2000 euros), et les informations ci dessus sont celles que j'ai souvent trouvé sur des forums plasma.
Message édité par jimi42 le 04-12-2003 à 17:02:32
