[Topic] Logitech Z-5300E -> Annulées en Europe /!\ Vive Logitech !
Logitech Z-5300E -> Annulées en Europe /!\ Vive Logitech ! [Topic] - Matériel - Video & Son
Marsh Posté le 27-10-2004 à 18:56:30
Bienvenue,  :hello:
     http://images10.newegg.com/productimage/36-121-121-03.JPG
Caractéristiques a écrit :
More Sound, More Intensity
  • High power and THX performance for demanding gamers
  • Patented dual chamber subwoofer plays louder and goes lower for unbelievable bass
  • Subwoofer delivers twice the bass energy of conventional designs
  • Polished aluminum phase plug satellites combine two drivers into one: the clarity of a tweeter with the richness and fullness of a separate mid-range
  • Use Matrix mode and source selector switch to create breathtaking 5.1 surround sound from stereo, 4 channel, or 5.1 sound sources
  • Exercise complete control over your listening experience with the full-featured SoundTouch™ wired remote control, featuring headphone jack, master volume control, and separate volume controls for the subwoofer, center channel, and rear channels
  • Pedestals rotate easily for wall mounting or desk placement
  • Innovative design features removable grilles & aluminum phase plug drivers
  • Video game console adapter works with Sony® PlayStation®, Sony® PlayStation®2, Microsoft® Xbox®, or Nintendo GameCube™ using stereo RCA (red and white) audio cables
Technical Specifications
  • Power:
Total RMS power: 280 watts RMS
Satellites 180 Watts RMS (2 x 35.25W front, 2 x 35.25W rear, 39W center)
Subwoofer: 100 Watts RMS
Total peak power: 560 watts
Frequency response: 35Hz - 20kHz
  • Drivers:
Satellites: 2.5" aluminum phase plug driver
Subwoofer: 6.5" high-excursion driver
  • Speaker dimensions:
Satellites: (H) 8" x (W) 3.75" x (D) 3.5"
Center: (H) 5" x (W) 6.625" x (D) 3"
Subwoofer: (H) 11.813" x (W) 11.75" x (D) 14.5"
  • Signal to noise ratio: >85 db
  • Input selector switch:
2 Channel (stereo)
4 Channel
5.1 Channel
SoundTouch™ remote control
Master volume
Sub, center & surround levels
Matrix surround sound
Package Contents
  • Speakers: 4 satellites & 1 subwoofer & 1 center Channel speaker
  • Power cord
  • Color coded audio cables
  • Two-year limited warranty
  • Owner's Manual
  • SoundTouch remote control
-> déjà dispo sur les sites américains à ~150$ voire moins !
Message édité par Roi de Yamimakai le 14-03-2005 à 20:46:18
Marsh Posté le 27-10-2004 à 19:33:16
Apparemment la seule différence avec l'ancien modèle n'est que d'ordre esthétique !
Marsh Posté le 27-10-2004 à 19:43:42
J'a
Marsh Posté le 27-10-2004 à 21:48:31
En effet, ben c'est suffisant pour que je les attende parce que les Z-5300 actuelles j'aime po trop :o :D
Marsh Posté le 28-10-2004 à 08:30:47
Pour avoir les z5300 à côté de moi, je peux te dire que la seule différence esthétique n'est même pas le design mais seulement la couleur. C'est la seule différence esthétique entre les deux. SI pour toi cela suffit à les payer le double du prix, tant mieux pour toi seulement pour ce prix là tu pourrais presque te payer les z680...
Message édité par le nain culte le 28-10-2004 à 08:31:49
Marsh Posté le 28-10-2004 à 13:49:58
Tu es sur qu elle ne vont po couter le meme prix ? ca me semble fort ibzarre ca ;)
MAis si tu dis vrai, alors je sis a 100% d accord avec toi! mais je reste tres perplexe...
Marsh Posté le 28-10-2004 à 15:06:09
Je suis sûr qu'elle ne seront pas au même prix. C'est ça le plus scandaleux. ILs liquident les stock de z5300 pour une bouchée de pain pour ensuite revendre les même pratiquement le double du prix...
http://www.sunshinecomputers.com.a [...] 70102-1122
Ce n'est qu'indicatif mais significatif quand même...
Marsh Posté le 28-10-2004 à 15:08:02
+1 mais 139€ a montgalet les Z-5300 et 143$ les Z-5300E sur newegg, sachant que le dollar est + faible que l'euro en ce moment, je dirais qu'il n'ya pas de prob  :jap:  quitte a les payer 10€ + cher à la limite au pire des cas je m'en fiche je préfère en argent.. mais bon s'po tres grave ca encore.
Enfin mis à part ça, comme les Z-680 on connue qq modifications techniques en + de l'esthéique on peut s'attendre aussi à des ptites modifs sur les Z-5300E  [:c17]
edit: je susi d'accord pour le côté scandaleux de la chose, dans la mesure où les z-680, techniquement = à 99% des z-5500 et pourtant 100€ moins chères n'ont pas fait 1 semaine à montgallet......
sinon mes sources pour le pric des z-5300e :
http://www.newegg.com/app/viewprod [...] 121&DEPA=0
menfin sachant que les z-5300 sont sorties à 300€ à la base, je pense po que les z-5300e couteront ausis peu cher, donc w6 & w8..
PS: la véritable affaire du moment semble être les Megaworks...
500W de bon son pour 270€, s'pas mal !
Mais le design m'attire pas trop.. m'enfin en verra  :heink:
Message édité par Roi de Yamimakai le 28-10-2004 à 15:12:17
Marsh Posté le 28-10-2004 à 19:05:19
qd crois tu que les Z-5300E vont sortir en europe ? le design me plait pr les deux modeles mais ta remarque sur une potentielle "mise a jour technique" est interessante.
Marsh Posté le 28-10-2004 à 19:37:33
Je c po quand est-ce que les Z-5300E seront dispo en France, elles le sont déjà aux USA  :sarcastic:
w8 & 6  :??:
(brrrrrrrr j'avais fais une réponse + longue mais jétais délogué alors que jaV pas remarqué, et quand g voulu poster.. blablabla.. et g tt perdu  :cry: )
Marsh Posté le 28-10-2004 à 19:42:04
Liens sur les Z-5300E ::
site de Logitech (US)
caractéristiques - avis aux actuels possesseurs de Z-5300...
/!\ sites de vente US > c pas 300$$ !!
youhou je pense qu'on pourra les avoir aux alentours des 150€ (entre 140 et 180) perso si elles venaient à dépasser les 200€ je me tournerait vers les Megaworks.. mais j'm po trop le design :/
-> c'est pas cher
http://www.securemart.com/cgi-bin/ [...] ml?pcode=1
sinon sur le site de logitech elles sont annoncées à 299$, et les z-5500 à 529$... oué oué... 375 à montgallet  :na:
un rapide tableau en croix fixerait le prix théorique des Z-5300E à 212$  :D  - les prix américains se situant dans les 140$ je pense pas qu'ont les aura vraiment + cher... (et l'€ est + fort que le $  :)  )
Message édité par Roi de Yamimakai le 28-10-2004 à 19:49:11
Marsh Posté le 28-10-2004 à 19:50:13
Au fait, pour les possesseurs de Z-5300, les satellites sont pas un peu grands ? je vois 203mm dans les spec ! et vu la taille de la télécommande ca me parait massif out ca, alors votre avis? en tout cas c joli donc ca passe je pense.. :)
Marsh Posté le 28-10-2004 à 22:35:04
J'ai vérifié les mensurations, les spécificités techniques, tout,... Et c'est totalement identique. IL n'y a vraiment que la couleur qui change.
Marsh Posté le 28-10-2004 à 23:10:47
C'est vrai que ca fait joli sur la foto, mais bon, faut vraiment que la différence de prix soit minime.
Roi de Yamimakai: les satellites sont grands mais pas encombrants, c'est plus "massif" que les z-640 mais normal les Z 5300 sont de bien meilleur qualité.
Marsh Posté le 29-10-2004 à 08:59:04
Personne veut confirmer mes propos comme quoi, techniquement ils seront identiques et que la seule différence est limite la couleur des caches????
Marsh Posté le 29-10-2004 à 16:08:52
Ben pourquoi te contredire :) on te croit, tout semble dit!
Seul le design change, c'est presque sûr à 100%, et seul un prix quasi identique aux actuelles Z-5300 rendrait ces enceintes intéressantes!
Marsh Posté le 29-10-2004 à 16:10:31
ok, sinon ptites questions sur la téélcommande pq on en parle po bcp dans les tests, elle est bien? pas trop grosse? de quelle facon ets indiquée l'augmentation du volume? leds? quelle couleur ?  :pt1cable:   :ange:
Marsh Posté le 29-10-2004 à 16:31:34
Elle est bien, pas trop grosse, le volume se fixe à l'aide d'une grosse molette, leds rouge et verte pour le son, assez discret, on peut brancher le casque dessus (trés pratique) et régler le volume du son, le volume du caisson de basse, le volume des enceintes (toutes).
Marsh Posté le 29-10-2004 à 17:13:29
si on veut desesperement les 5300, mieux vaut-il les acheter mnt ds une couleur moins attrayante (aux premiers abords), ou attendre et risquer de constater un prix exhorbitant pr les 5300E ? God is dead ( ou qlq un d autre): niveau look, tu es decu des 5300? tcho !
Message édité par Raszagal le 29-10-2004 à 17:14:12
Marsh Posté le 30-10-2004 à 00:10:29
Perso je les ai. Franchement vu le prix actuel de ces enceintes il vaut vraiment mieux foncer dessus car là elles ont atteint un prix inédit. La qualité du son est vraiment excellente et pourtant je ne suis aps du genre à être trop vite satisfait. Franchement vu leur prix c'est vraiment une affaire. A mon avis, les trouver à ce prix là est très provisoire car le 5300e seront identiques et je suis presque sûr beaucoup plus cher sinon l'écart de prix entre les 5500 et 5300e serait beaucoup trop grand selon ma logique. ILs vont forcément profiter du soi disant côté nouveau pour vendre les 5300e beaucoup plus cher que les 5300. Là ils vident les stocks d'où le prix... Tout ça selon moi et ce qui me semble logique...
Marsh Posté le 30-10-2004 à 01:48:42
En fait, en réfléchissant un peu, on devine ce qu'il y a de plus dans les Z-5300e en dehors de la couleur métal : la longueur des cables. :)
C'était "le" défaut des Z-5300, et j'espère bien que Logitech en a tenu compte, car si c'est bien le cas, et que ce kit est vendu en Europe au même prix qu'aux US, alors cela ne fait aucun doute qu'il sera sous mon sapin le 25 décembre. :jap:
Message édité par Sett le 30-10-2004 à 01:58:56
Marsh Posté le 30-10-2004 à 13:08:23
God is dead >> merci pour les précisions :jap:
Le nain culte >> ta logique est bonne, c'est clair, mais bon si seul le design change, et qu'elles sont affichées à moins de 150$ dans pas mal de magazins US, je pense pas que Logitech va abuser à ce point. Pour les Z-5500 ils ont mis le prix d'origine des Z-680, à cause des qq évolutions techniques en + du design, mais bon... c'est pas justifié tt ça :o  Perso, si les Z-5300E coûtent + de 180€, ben ciao Logitech.. :/
Sinon c'est vrai que les Z-5300 vallent le coup! Mais dans mon cas j'accorde un peu d'importance au design et j'aime pas trop les Z-5300.. bon ça c'est moi hein.. sinon je les conseil à tout le monde ! 280W THX de pur son pour 140€ à Montgallet..  :p
Message édité par Roi de Yamimakai le 30-10-2004 à 13:10:27
Marsh Posté le 30-10-2004 à 13:41:12
Dans la news sur HFR, j'avais pu lire que les kits seront dispo à environ 10% plus cher que l'ancienne génération.
Si le Z-5300 est trouvable à 150€, on trouvera logiquement le 5300e à 165€, soit 15€ supplémentaires, ce qui est tout à fait acceptable. Maintenant il faut esperer que ca n'ira pas au delà.
Message édité par Sett le 30-10-2004 à 13:41:35
Marsh Posté le 02-11-2004 à 12:51:45
Toujours aucune date de prévue (?)  :(
Marsh Posté le 02-11-2004 à 15:27:24
non tjrs po...(de mon coté du moins :( )
Marsh Posté le 03-11-2004 à 18:52:43
:cry:
Marsh Posté le 03-11-2004 à 18:56:19
Petites tofs pour patienter...
http://images10.newegg.com/productimage/36-121-121-05.JPG
http://images10.newegg.com/productimage/36-121-121-02.JPG
http://images10.newegg.com/productimage/36-121-121-04.JPG
http://www.logitech.com/lang/images/0/5882.jpghttp://www.logitech.com/lang/images/0/5883.jpg
http://www.logitech.com/lang/images/0/5879.jpg
Message édité par Roi de Yamimakai le 25-12-2004 à 23:28:30
Marsh Posté le 04-11-2004 à 19:44:20
Apparemment un site français propose les Z-5300E en import US, mais vlà le prix...
http://www.camelot.ca/fr/article/221244.html
Je mets ce lien à titre indicatif, car à moins d'être idiot je vois pas l'intérêt de les acheter à ce prix, de + en import.. sachant que les Z-5300 sont identiques design à part, et sont proposées a 140€, et que ces Z-5300E arriveront en France aux alentours de 150€ (prix constatés chez la majorité des sites US où ces enceintes sont actuellement en vente).
Marsh Posté le 05-11-2004 à 23:33:28
Message édité par Raszagal le 06-11-2004 à 18:49:58
Marsh Posté le 06-11-2004 à 18:50:15
Au fait, question a ceux qui possedent cette installation : y a til de bonne potssibilité d orientation des bafles ou po ? ou logitech n a pensé qu a un mouvement verticale ?(pr permettre de les accrocher au mur)
Merfi!
Marsh Posté le 14-11-2004 à 01:22:59
Marsh Posté le 14-11-2004 à 20:05:58
Avec des z5300 à 150 euros ce sont elles l'affaire je dirais. Les Megaworks sont d'une autre gamme, et probablement meilleures . Mais il est rare que le rapport qualité/prix suive avec la montée en gamme. Disons que celui des z5300 est excellent , et que celui des megaworks est plus que bon. :)
Pour l'esthétique, il est certain que les deux kits ne semblent pas cibler le même public. d'un coté la classe et la sobriété, de l'autre l'agressivité et la modernité...
Il est probable que tu aies raison. Vive les changements de gamme chez logitech... :sarcastic: où devrait t'on dire changement de rentabilité?
KEF – Certains pensent. D'autres croient. Qui pensez vous qu'il faille croire ? – SC2 #HFR #Pony
Marsh Posté le 14-11-2004 à 22:21:10
Nom didju, mais ils sortent qd ? :) Logitech n en parle meme pas encore sur son site FR.
Marsh Posté le 14-11-2004 à 23:40:37
..et ca fait 8 ans qu'elles sont sur le site US :o (enfin à qq années prètes =)
Marsh Posté le 15-11-2004 à 09:47:06
Omg, mais sommes ns sur au moins qu elle va bien sortir en europe ? :/
Marsh Posté le 15-11-2004 à 17:55:35
Pas sûr en fait! Comme seul le design change, peut-être que logitech veut répondre à une demande différente, dans un autre pays, peut-être qu'elles s'appellent Z-5300E pour Estonie, ou bien Egypte :heink: ..ou Europe :D ...ou encu**.. pq elles vont coûter 974€ HT alors que le seul design change  :cry:  ..nan allez juste attendre, ou réussir à mailer logitech, chose que je n'ai jamais réussie à faire, je trouve pas leur mail,
[:roi de yamimakai]
Message édité par Roi de Yamimakai le 15-11-2004 à 17:57:42
Marsh Posté le 15-11-2004 à 23:56:40
Bah pareil, j'attends ce beau carton sous mon sapin. Pas de news de dispo encore en Europe, mais les Z3e et Z-5500 commencent à être dispo, donc les Z-5300e devraient suivre :)
Marsh Posté le 16-11-2004 à 11:06:52
Je vais contacter le 08 36 65 65 65... p-ê aurais-je une réponse :heink:
:lol:
Marsh Posté le 17-11-2004 à 11:31:06
cool! tiens ns au courant gros...
Marsh Posté le 17-11-2004 à 16:16:29
eh beh.. on verra bien le 25 decembre sous le sapin :lol: ..
:heink:
