aligning footer content on the bottom of the region-area
aligning footer content on the bottom of the region-area - XML/XSL - Programmation
Marsh Posté le 04-08-2005 à 09:39:25
I'm a newbie with xsl-fo so I would need some help.
I am trying to position my footer content aligned on the bottom of my region-after area. I'm using the display-align attribut initialized at "after". Here is some code:
<fo:simple-page-master
master-name="first"
page-height="29.7cm"
page-width="21.0cm"
margin-top="0.5cm"
margin-bottom="0.5cm"
margin-left="0.5cm"
margin-right="0.5cm">
<fo:region-body margin-top="0cm" margin-bottom="1.5cm"/>
<fo:region-before extent="1cm" region-name="before-first"/>
<fo:region-after extent="3.5cm" display-align="after" background-color="#BBB34F" region-name="after-first" />
</fo:simple-page-master>
Here I place a static content for the region-after area
<fo:static-content flow-name="after-first">
  <xsl:call-template name="show-footer" />
</fo:static-content>
Suposing the template show-footer looks like this (no need to bother you with the whole code, it doesn't work eaven with this simple one):
<xsl:template name="show-footer">
<fo:table>
 <fo:table-column column-width="18.5cm" />
 <fo:table-body>
  <fo:table-row>
   <fo:table-cell background-color="#CCCCCC">
    <fo:block>
     test
    </fo:block>
   </fo:table-cell>
  </fo:table-row>
</fo:table-body>
</fo:table>
</xsl:template>
I'm not using a stylesheet so it ain't a problem of override.
Thanks for any kind of help
