Private Const RESOURCETYPE_ANY As Long = &H0& Private Const RESOURCETYPE_DISK As Long = &H1& Private Const RESOURCETYPE_PRINT As Long = &H2& Private Const RESOURCETYPE_UNKNOWN As Long = &HFFFF&
Private Const RESOURCEUSAGE_ALL As Long = &H0& Private Const RESOURCEUSAGE_CONNECTABLE As Long = &H1& Private Const RESOURCEUSAGE_CONTAINER As Long = &H2& Private Const RESOURCEUSAGE_RESERVED As Long = &H80000000
Private Const NO_ERROR = 0 Private Const ERROR_MORE_DATA = 234 Private Const RESOURCE_ENUM_ALL As Long = &HFFFF
Private Type NETRESOURCE dwScope As Long dwType As Long dwDisplayType As Long dwUsage As Long pLocalName As Long pRemoteName As Long pComment As Long pProvider As Long End Type
Private Type NETRESOURCE_EXTENDED dwScope As Long dwType As Long dwDisplayType As Long dwUsage As Long sLocalName As String sRemoteName As String sComment As String sProvider As String End Type
'WNet API resources Private Declare Function WNetAddConnection2 Lib "mpr.dll" Alias "WNetAddConnection2A" (lpNetResource As NETRESOURCE, ByVal lpPassword As String, ByVal lpUserName As String, ByVal dwFlags As Long) As Long Private Declare Function WNetOpenEnum Lib "mpr.dll" Alias "WNetOpenEnumA" (ByVal dwScope As Long, ByVal dwType As Long, ByVal dwUsage As Long, lpNetResource As Any, lphEnum As Long) As Long Private Declare Function WNetEnumResource Lib "mpr.dll" Alias "WNetEnumResourceA" (ByVal hEnum As Long, lpcCount As Long, lpBuffer As NETRESOURCE, lpBufferSize As Long) As Long Private Declare Function WNetCloseEnum Lib "mpr.dll" (ByVal hEnum As Long) As Long Private Declare Function VarPtrAny Lib "vb40032.dll" Alias "VarPtr" (lpObject As Any) As Long Private Declare Sub CopyMem Lib "kernel32" Alias "RtlMoveMemory" (lpTo As Any, lpFrom As Any, ByVal lLen As Long) Private Declare Sub CopyMemByPtr Lib "kernel32" Alias "RtlMoveMemory" (ByVal lpTo As Long, ByVal lpFrom As Long, ByVal lLen As Long) Private Declare Function lstrcpy Lib "kernel32" Alias "lstrcpyA" (ByVal lpString1 As String, ByVal lpString2 As Any) As Long Private Declare Function lstrlen Lib "kernel32" Alias "lstrlenA" (ByVal lpString As Any) As Long Private Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long Private Declare Function GetComputerName Lib "kernel32" Alias "GetComputerNameA" (ByVal lpBuffer As String, nSize As Long) As Long
'Filtered immediate access storage Private sUserName As String Private sMachineName As String Private sServerList As String Private sPrinterList As String Private sShareList As String Private sDirectoryList As String Private sDomainList As String Private sFileList As String Private sGenericList As String Private sGroupList As String Private sNetworkList As String Private sRootList As String Private sShareAdminList As String
'Sets the resource types that will be enumerated (disk,printer etc) Private lResType As Long
'Reloads the enumerated list of network entities Public Sub Reset()
Dim bFirstTime As Boolean Dim lReturn As Long Dim hEnum As Long Dim lCount As Long Dim lMin As Long Dim lLength As Long Dim l As Long Dim lBufferSize As Long Dim lLastIndex As Long
bFirstTime = True Do 'Create an enumeration using the required resource type If bFirstTime Then lReturn = WNetOpenEnum(RESOURCE_GLOBALNET, GetResourceType, RESOURCEUSAGE_ALL, ByVal 0&, hEnum) bFirstTime = False Else If uNet(lLastIndex).dwUsage And RESOURCEUSAGE_CONTAINER Then lReturn = WNetOpenEnum(RESOURCE_GLOBALNET, GetResourceType, RESOURCEUSAGE_ALL, uNet(lLastIndex), hEnum) Else lReturn = NOT_A_CONTAINER hEnum = 0 End If lLastIndex = lLastIndex + 1 End If
'Make sure that we have a good enumeration If lReturn = NO_ERROR Then lCount = RESOURCE_ENUM_ALL 'Work through the enumeration until we run out Do lBufferSize = UBound(uNetApi) * Len(uNetApi(0)) / 2 lReturn = WNetEnumResource(hEnum, lCount, uNetApi(0), lBufferSize) If lCount > 0 Then ReDim Preserve uNet(0 To lMin + lCount - 1) As NETRESOURCE_EXTENDED For l = 0 To lCount - 1 'Each Resource will appear here as uNet(i) uNet(lMin + l).dwScope = uNetApi(l).dwScope uNet(lMin + l).dwType = uNetApi(l).dwType uNet(lMin + l).dwDisplayType = uNetApi(l).dwDisplayType uNet(lMin + l).dwUsage = uNetApi(l).dwUsage
'Get the name If uNetApi(l).pLocalName Then lLength = lstrlen(uNetApi(l).pLocalName) uNet(lMin + l).sLocalName = Space$(lLength) CopyMem ByVal uNet(lMin + l).sLocalName, ByVal uNetApi(l).pLocalName, lLength End If
'Get the remote name If uNetApi(l).pRemoteName Then lLength = lstrlen(uNetApi(l).pRemoteName) uNet(lMin + l).sRemoteName = Space$(lLength) CopyMem ByVal uNet(lMin + l).sRemoteName, ByVal uNetApi(l).pRemoteName, lLength End If
'Get any comment associated with it If uNetApi(l).pComment Then lLength = lstrlen(uNetApi(l).pComment) uNet(lMin + l).sComment = Space$(lLength) CopyMem ByVal uNet(lMin + l).sComment, ByVal uNetApi(l).pComment, lLength End If
'Get the provider information If uNetApi(l).pProvider Then lLength = lstrlen(uNetApi(l).pProvider) uNet(lMin + l).sProvider = Space$(lLength) CopyMem ByVal uNet(lMin + l).sProvider, ByVal uNetApi(l).pProvider, lLength End If Next l End If lMin = lMin + lCount Loop While lReturn = ERROR_MORE_DATA End If
'Check if we have a successfully opened Enumeration If hEnum Then l = WNetCloseEnum(hEnum) End If
Loop While lLastIndex < lMin
'Decode the results Call DecodeEnum
End Sub
Private Sub DecodeLocalInfo()
On Error Resume Next
'Create a buffer sUserName = String(255, Chr(0))
'Get the username Call GetUserName(sUserName, 255)
'Strip the rest of the buffer sUserName = Left(sUserName, InStr(sUserName, Chr(0)) - 1)
'Create a buffer sMachineName = String(255, Chr(0)) Call GetComputerName(sMachineName, 255)
'Sets the resource type to be enumerated '(restricting this greatly improves performance) '0 RESOURCETYPE_ANY = Everything '1 RESOURCETYPE_DISK = Machines and shares only '2 RESOURCETYPE_PRINT = Printers only 'Default is RESOURCETYPE_DISK Public Sub SetResourceType(lResourceType As Long)
lResType = lResourceType
End Sub
'Returns the current resource type that is being scanned for Public Function GetResourceType() As Long
GetResourceType = lResType
End Function
'Decodes the network array into a useful set of values Private Sub DecodeEnum()
Dim l As Long
If UBound(uNet) > 0 Then 'Get some local information Call DecodeLocalInfo
'Parse the network enumeration For l = 0 To UBound(uNet) 'TODO: Include comments? uNet(l).sComment Select Case uNet(l).dwDisplayType Case RESOURCEDISPLAYTYPE_DIRECTORY& sDirectoryList = sDirectoryList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_DOMAIN sDomainList = sDomainList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_FILE sFileList = sFileList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_GENERIC sGenericList = sGenericList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_GROUP sGroupList = sGroupList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_NETWORK& sNetworkList = sNetworkList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_ROOT& sRootList = sRootList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_SERVER sServerList = sServerList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_SHARE sShareList = sShareList + uNet(l).sRemoteName + "|" Case RESOURCEDISPLAYTYPE_SHAREADMIN& sShareAdminList = sShareAdminList + uNet(l).sRemoteName + "|" End Select Next l End If
End Sub
'Provides the current user name Public Function GetLocalUserName() As String
GetLocalUserName = sUserName
End Function
'Provides the current machine name Public Function GetLocalMachineName() As String
GetLocalMachineName = sMachineName
End Function
'Returns a | delimited list of all computers on the network Public Function GetServerList() As String
GetServerList = sServerList
End Function
'Returns a | delimited list of all shares on the network Public Function GetShareList() As String
GetShareList = sShareList
End Function
'Returns a | delimited list of all printers on the network Public Function GetPrinterList() As String
GetPrinterList = sPrinterList
End Function
'Returns a | delimited list of all directories on the network Public Function GetDirectoryList() As String
GetDirectoryList = sDirectoryList
End Function
'Returns a | delimited list of all domains on the network Public Function GetDomainList() As String
GetDomainList = sDomainList
End Function 'Returns a | delimited list of all files on the network Public Function GetFileList() As String
GetFileList = sFileList
End Function
'Returns a | delimited list of all generic items on the network Public Function GetGenericList() As String
GetGenericList = sGenericList
End Function
'Returns a | delimited list of all groups on the network Public Function GetGroupList() As String
GetGroupList = sGroupList
End Function
'Returns a | delimited list of all sub networks on the network Public Function GetNetworkList() As String
GetNetworkList = sNetworkList
End Function
'Returns a | delimited list of all roots on the network Public Function GetRootList() As String
GetRootList = sRootList
End Function
'Returns a | delimited list of all admin shares on the network Public Function GetShareAdminList() As String
GetShareAdminList = sShareAdminList
End Function
To use it:
Option Explicit
Dim clsNetwork As CNetworkEnum
Private Sub Form_Load() Dim strList As String Dim strThisComputer As String Dim arrList() As String Dim iCount As Integer Dim iIndex As Integer
'create list of computers on the network Set clsNetwork = New CNetworkEnum clsNetwork.SetResourceType (1) 'Machines and shares clsNetwork.Reset
strThisComputer = clsNetwork.GetLocalMachineName strList = clsNetwork.GetServerList arrList = Split(strList, "|" ) ReDim arrComputerList(0) For iCount = 0 To UBound(arrList) If arrList(iCount) <> "" Then arrList(iCount) = Replace(arrList(iCount), "\", "" ) If arrList(iCount) <> strThisComputer Then If arrComputerList(0) = "" Then iIndex = 0 Else iIndex = UBound(arrComputerList) + 1 End If ReDim Preserve arrComputerList(0 To iIndex) arrComputerList(iIndex) = UCase$(arrList(iCount)) End If End If Next iCount End Sub
Marsh Posté le 23-01-2004 à 14:54:43
yop,
je me connecte aux pc's du réseau avec
Set p_objWbemRoot = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & NOM_DU_PC & \root\cimv2)
(projet avec référence à microsoft WMI scripting library)
le problème, c'est que si le pc n'est pas connecté, ca bloque pendant un certain temps (trop long)
donc je voudrais vérifier avant si le pc est alumé/connecté
si quelqu'un à une idée...
ps: c'est du vb6
oui oui
