C'est quoi pour un langage ?!? [Diskemu.bat] - Shell/Batch - Programmation
Marsh Posté le 27-03-2003 à 10:36:10
ou plutôt :
tiré de http://tigger.uic.edu/~mterlo1/bscript/
Boot Scriptor is a program that allows a high degree of interactivity when booting from a Compact Disc or DVD drive. It provides a set of commands designed to enable users to boot a system in a number of ways, as well as provide interactive menus to choose boot options from. It is based heavily on concepts pioneered by Bart Lagerweij in his great program Diskem1x. Boot Scriptor provides similar functionality to Diskem1x, as well as new original features, and interfaces to other great programs such as Isolinux/Memdisk and Ranish Partition Manager. All of these features can be commanded through a console interface or by constructing simple script files.
Boot Scriptor is free for non-commercial use. The program and its source code is distributed under the NASM License. The distribution and use of some optional components is restricted by their respective licenses.
Marsh Posté le 27-03-2003 à 10:38:31
Salut !
Sympa pour le lien, je regarde ça tout de suite !
Marsh Posté le 27-03-2003 à 10:19:21
Salut !
Quel est le language utilisé ?!?
Merci du coup de pouce !
