Probleme de connection base de donnée
Probleme de connection base de donnée - SQL/NoSQL - Programmation
Marsh Posté le 30-10-2005 à 14:16:06
Voila je voudrait mettre un compteur sur mon site,
j'ai télécharger un script tou fait et automatisé et impossible de lancer l'installation pourtt les infos sont les bonne (mot de pase...)
Warning: fopen(connect_visite.php): failed to open stream: Permission denied in /home10/eq42432/html/visite/install.php on line 19
Warning: fwrite(): supplied argument is not a valid stream resource in /home10/eq42432/html/visite/install.php on line 20
Warning: fclose(): supplied argument is not a valid stream resource in /home10/eq42432/html/visite/install.php on line 21
Warning: mysql_connect(): Access denied for user: 'xxx@andrea.nfrance.com' (Using password: YES) in /home10/eq42432/html/visite/connect_visite.php on line 6
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home10/eq42432/html/visite/connect_visite.php on line 7
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home10/eq42432/html/visite/install.php on line 35
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home10/eq42432/html/visite/install.php on line 37
