Probleme sql (configuration) - SQL/NoSQL - Programmation
MarshPosté le 08-02-2004 à 22:46:28
salut a tous, j'ai un p'tit probleme de sql (je pense que ca vient de la configuration de mon serveur, mais je vois pas ou): g une (grosse) erreur du type: Warning: session_register(): open(cprogram files/apache group/sessions\sess_bc22260c70c512979b5758032b3789d0, O_RDWR) failed: No such file or directory (2) in C:\gde\verif.php on line 2
Warning: session_register(): Cannot send session cookie - headers already sent by (output started at C:\gde\verif.php:2) in C:\gde\verif.php on line 2
Warning: session_register(): Cannot send session cache limiter - headers already sent (output started at C:\gde\verif.php:2) in C:\gde\verif.php on line 2
Warning: Unknown(): open(cprogram files/apache group/sessions\sess_bc22260c70c512979b5758032b3789d0, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (cprogram files/apache group/sessions) in Unknown on line 0
voila, si quelqu'un a une idee, comme ca, au cas ou... merci d'avance ++
Marsh Posté le 08-02-2004 à 22:46:28
salut a tous,
merci d'avance
