OPTIONAL BACKEND DEPENDENCIES libpng: 1.2.15beta5 Tkinter: no * Using default library and include directories for * Tcl and Tk because a Tk window failed to open. * You may need to define DISPLAY for Tk to work so * that setup can determine where your libraries are * located. Tkinter present, but header files are not * found. You may need to install development * packages. wxPython: no * wxPython not found Gtk+: no * Building for Gtk+ requires pygtk; you must be able * to "import gtk" in your build/install environment Qt: no Qt4: no Cairo: no
OPTIONAL DATE/TIMEZONE DEPENDENCIES datetime: present, version unknown dateutil: matplotlib will provide pytz: matplotlib will provide
EXPERIMENTAL CONFIG PACKAGE DEPENDENCIES configobj: matplotlib will provide enthought.traits: no
[Edit setup.cfg to suppress the above messages] ============================================================================ running build running build_py copying lib/matplotlib/mpl-data/matplotlibrc -> build/lib.linux-i686-2.5/matplotlib/mpl-data copying lib/matplotlib/mpl-data/matplotlib.conf -> build/lib.linux-i686-2.5/matplotlib/mpl-data running build_ext building 'matplotlib.backends._backend_agg' extension creating build/temp.linux-i686-2.5 creating build/temp.linux-i686-2.5/agg24 creating build/temp.linux-i686-2.5/agg24/src creating build/temp.linux-i686-2.5/src creating build/temp.linux-i686-2.5/CXX gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c agg24/src/agg_trans_affine.cpp -o build/temp.linux-i686-2.5/agg24/src/agg_trans_affine.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c agg24/src/agg_bezier_arc.cpp -o build/temp.linux-i686-2.5/agg24/src/agg_bezier_arc.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c agg24/src/agg_curves.cpp -o build/temp.linux-i686-2.5/agg24/src/agg_curves.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c agg24/src/agg_vcgen_dash.cpp -o build/temp.linux-i686-2.5/agg24/src/agg_vcgen_dash.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c agg24/src/agg_vcgen_stroke.cpp -o build/temp.linux-i686-2.5/agg24/src/agg_vcgen_stroke.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c agg24/src/agg_image_filters.cpp -o build/temp.linux-i686-2.5/agg24/src/agg_image_filters.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c src/_image.cpp -o build/temp.linux-i686-2.5/src/_image.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c src/ft2font.cpp -o build/temp.linux-i686-2.5/src/ft2font.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c src/mplutils.cpp -o build/temp.linux-i686-2.5/src/mplutils.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c CXX/IndirectPythonInterface.cxx -o build/temp.linux-i686-2.5/CXX/IndirectPythonInterface.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c CXX/cxx_extensions.cxx -o build/temp.linux-i686-2.5/CXX/cxx_extensions.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c CXX/cxxsupport.cxx -o build/temp.linux-i686-2.5/CXX/cxxsupport.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c CXX/cxxextensions.c -o build/temp.linux-i686-2.5/CXX/cxxextensions.o gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/local/include -I/usr/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -Isrc -Iagg24/include -I. -I/FGST/Tools/Python-lib/Python-2.5.1/numpy-1.2.0/lib/python/numpy/core/include -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -I. -I/FGST/GLAST_EXT/rhel4_gcc34/python/2.5.1/include/python2.5 -c src/backend_agg.cpp -o build/temp.linux-i686-2.5/src/backend_agg.o cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes" est valide pour C/ObjC mais pas pour C++ g++ -pthread -shared build/temp.linux-i686-2.5/agg24/src/agg_trans_affine.o build/temp.linux-i686-2.5/agg24/src/agg_bezier_arc.o build/temp.linux-i686-2.5/agg24/src/agg_curves.o build/temp.linux-i686-2.5/agg24/src/agg_vcgen_dash.o build/temp.linux-i686-2.5/agg24/src/agg_vcgen_stroke.o build/temp.linux-i686-2.5/agg24/src/agg_image_filters.o build/temp.linux-i686-2.5/src/_image.o build/temp.linux-i686-2.5/src/ft2font.o build/temp.linux-i686-2.5/src/mplutils.o build/temp.linux-i686-2.5/CXX/IndirectPythonInterface.o build/temp.linux-i686-2.5/CXX/cxx_extensions.o build/temp.linux-i686-2.5/CXX/cxxsupport.o build/temp.linux-i686-2.5/CXX/cxxextensions.o build/temp.linux-i686-2.5/src/backend_agg.o -L/usr/local/lib -L/usr/lib -L/usr/lib64 -L/usr/local/lib -L/usr/lib -L/usr/lib64 -lstdc++ -lm -lfreetype -lz -lz -lstdc++ -lm -o build/lib.linux-i686-2.5/matplotlib/backends/_backend_agg.so `.L26981' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L26982' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L26992' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L27002' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L27003' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L26980' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L27013' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L27032' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L27042' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o `.L27061' referenced in section `.rodata' of build/temp.linux-i686-2.5/src/backend_agg.o: defined in discarded section `.gnu.linkonce.t._ZN3agg18rasterizer_sl_clipINS_12ras_conv_intEE7line_toINS_19rasterizer_cells_aaINS_7cell_aaEEEEEvRT_ii' of build/temp.linux-i686-2.5/src/backend_agg.o collect2: ld a retourné 1 code d'état d'exécution error: command 'g++' failed with exit status 1
Message édité par sylvaing le 26-10-2008 à 22:43:35
Marsh Posté le 26-10-2008 à 05:57:26
Bonjour a tous,
 FGST/Tools/Python-lib/Python-2.5.1/matplotlib-0.98.3$ pythonGE setup.py build
Je ne trouve pas de section consacree a Python, alors je poste ici...
J essaye de compiler le package matplotlib, mais comme vous pouvez vous en douter, j ai un probleme...
Je ne parviens pas a dechiffrer le message d erreur de ld....
Est ce que quelqu un pourrait me guider ?
guiriec@Mars
BUILDING MATPLOTLIB
matplotlib: 0.98.3
python: 2.5.1 (r251:54863, Jul 3 2007, 11:00:59) [GCC
3.4.6 20060404 (Red Hat 3.4.6-8)]
platform: linux2
REQUIRED DEPENDENCIES
numpy: 1.2.0
freetype2: 9.16.3
libpng: 1.2.15beta5
Tkinter: no
* packages.
wxPython: no
Gtk+: no
Qt: no
Qt4: no
Cairo: no
OPTIONAL USETEX DEPENDENCIES
dvipng: 1.9
ghostscript: 8.61
latex: 3.141592
pdftops: 3.00
running build
running build_py
running build_ext
