Bonjour à tous j'utilise deux serveurs , server web PHP Apache (dans le virtual box centos7 ) et l'autre server base de données ( centos 7) J'ai copié les dossiers GLPI 4.2 dans /var/www/html du server web PHP Apache Je voudrais connecter mon server web PHP Apache avec le server base de données ,je ne sais pas quel fichier dois-je paramétrer
J'ai ouvert le fichier config.php dans /var/www/html/glpi/inc
Voici le code <?php
if (!defined('GLPI_ROOT')) { die("Sorry. You can't access this file directly" ); }
// Be sure to use global objects if this file is included outside normal process global $CFG_GLPI, $GLPI, $GLPI_CACHE;
if (!file_exists(GLPI_CONFIG_DIR . "/config_db.php" )) { Session::loadLanguage('', false); // no translation if (!isCommandLine()) { Html::nullHeader("DB Error", $CFG_GLPI["root_doc"]); echo "<div class='center'>"; echo "<p>Error: GLPI seems to not be configured properly.</p>"; echo "<p>config_db.php file is missing.</p>"; echo "<p>Please restart the install process.</p>"; echo "<p><a class='red' href='".$CFG_GLPI['root_doc']."/install/install.php'>Click here to proceed</a></p>"; echo "</div>"; Html::nullFooter();
} else { echo "Error: GLPI seems to not be configured properly.\n"; echo "config_db.php file is missing.\n"; echo "Please connect to GLPI web interface to complete the install process.\n"; } die(1);
$older_to_latest = !isset($_GET['donotcheckversion']) // use normal config table on restore process && (isset($TRY_OLD_CONFIG_FIRST) // index case || (isset($_SESSION['TRY_OLD_CONFIG_FIRST']) && $_SESSION['TRY_OLD_CONFIG_FIRST'])); // backup case
if (isset($_SESSION['TRY_OLD_CONFIG_FIRST'])) { unset($_SESSION['TRY_OLD_CONFIG_FIRST']); }
if (!Config::loadLegacyConfiguration($older_to_latest)) { echo "Error accessing config table"; exit(); }
if (isset($_SESSION["glpiroot"]) && $CFG_GLPI["root_doc"]!=$_SESSION["glpiroot"]) { Html::redirect($_SESSION["glpiroot"]); }
// Override cfg_features by session value foreach ($CFG_GLPI['user_pref_field'] as $field) { if (!isset($_SESSION["glpi$field"]) && isset($CFG_GLPI[$field])) { $_SESSION["glpi$field"] = $CFG_GLPI[$field]; } }
// Check maintenance mode if (isset($CFG_GLPI["maintenance_mode"]) && $CFG_GLPI["maintenance_mode"] && !isset($dont_check_maintenance_mode)) { if (isset($_GET['skipMaintenance']) && $_GET['skipMaintenance']) { $_SESSION["glpiskipMaintenance"] = 1; }
if (!isset($_SESSION["glpiskipMaintenance"]) || !$_SESSION["glpiskipMaintenance"]) { Session::loadLanguage('', false); if (isCommandLine()) { echo __('Service is down for maintenance. It will be back shortly.'); echo "\n";
echo "<p class='red'>"; echo __('Service is down for maintenance. It will be back shortly.'); echo "</p>"; if (isset($CFG_GLPI["maintenance_text"]) && !empty($CFG_GLPI["maintenance_text"])) { echo "<p>".$CFG_GLPI["maintenance_text"]."</p>"; } echo "</div>"; Html::nullFooter(); } exit(); } } // Check version if ((!isset($CFG_GLPI['dbversion']) || (trim($CFG_GLPI["dbversion"]) != GLPI_SCHEMA_VERSION)) && !isset($_GET["donotcheckversion"])) {
if (isCommandLine()) { echo __('The version of the database is not compatible with the version of the installed files. An update is necessary.'); echo "\n";
if (!isset($CFG_GLPI["version"])) { $older = true; } else { if (strlen(GLPI_SCHEMA_VERSION) > 40) { $dev = true; //got a sha1sum on both sides... cannot know if version is older or newer if (!isset($CFG_GLPI['dbversion']) || strlen(trim($CFG_GLPI['dbversion'])) < 40) { //not sure this is older... User will be warned. if (trim($CFG_GLPI["version"]) < GLPI_PREVER) { $older = true; } else if (trim($CFG_GLPI['version']) >= GLPI_PREVER) { $newer = true; } } } else if (isset($CFG_GLPI['dbversion']) && strlen($CFG_GLPI['dbversion']) > 40) { //got a dev version in database, but current stable if (Toolbox::startsWith($CFG_GLPI['dbversion'], GLPI_SCHEMA_VERSION)) { $older = true; } else { $newer = true; } } else if (!isset($CFG_GLPI['dbversion']) || trim($CFG_GLPI["dbversion"]) < GLPI_SCHEMA_VERSION) { $older = true; } else if (trim($CFG_GLPI["dbversion"]) > GLPI_SCHEMA_VERSION) { $newer = true; } }
if ($older === true) { echo "<form method='post' action='".$CFG_GLPI["root_doc"]."/install/update.php'>"; if ($dev === true) { echo Config::agreeDevMessage(); } echo "<p class='red'>"; echo __('The version of the database is not compatible with the version of the installed files. An update is necessary.')."</p>"; echo "<input type='submit' name='from_update' value=\""._sx('button', 'Upgrade')."\" class='submit'>"; Html::closeForm(); } else if ($newer === true) { echo "<p class='red'>". __('You are trying to use GLPI with outdated files compared to the version of the database. Please install the correct GLPI files corresponding to the version of your database.')."</p>"; } else if ($dev === true) { echo "<p class='red'><strong>". __('You are trying to update to a development version from a development version. This is not supported.')."</strong></p>"; } }
Marsh Posté le 17-06-2019 à 17:42:57
Voici le code
<?php
include_once (GLPI_ROOT."/inc/based_config.php" );
include_once (GLPI_ROOT."/inc/define.php" );
include_once (GLPI_ROOT."/inc/dbconnection.class.php" );
//init cache
$GLPI_CACHE = Config::getCache('cache_db');
Session::setPath();
Session::start();
Config::detectRootDoc();
// no translation
echo "</div>";
Html::nullFooter();
} else {
die(1);
} else {
include_once(GLPI_CONFIG_DIR . "/config_db.php" );
// Default Use mode
if (!isset($_SESSION['glpi_use_mode'])) {
$_SESSION['glpi_use_mode'] = Session::NORMAL_MODE;
$GLPI = new GLPI();
$GLPI->initLogger();
//Database connection
DBConnection::establishDBConnection((isset($USEDBREPLICATE) ? $USEDBREPLICATE : 0),
(isset($DBCONNECTION_REQUIRED) ? $DBCONNECTION_REQUIRED : 0));
// *************************** Statics config options **********************
// ********************options d'installation statiques*********************
//Options from DB, do not touch this part.
exit();
if (isCommandLine()
&& isset($_SERVER['argv'])) {
$key = array_search('--debug', $_SERVER['argv']);
if ($key) {
$_SESSION['glpi_use_mode'] = Session::DEBUG_MODE;
unset($_SERVER['argv'][$key]);
$_SERVER['argv'] = array_values($_SERVER['argv']);
$_SERVER['argc']--;
Toolbox::setDebugMode();
//deprecated configuration options
//@deprecated 9.4
if ($_SESSION['glpi_use_mode'] != Session::DEBUG_MODE) {
$_SESSION['glpiticket_timeline'] = 1;
$_SESSION['glpiticket_timeline_keep_replaced_tabs'] = 0;
} else {
unset($_SESSION['glpiticket_timeline']);
unset($_SESSION['glpiticket_timeline_keep_replaced_tabs']);
unset($CFG_GLPI['use_rich_text']);
unset($CFG_GLPI['ticket_timeline']);
unset($CFG_GLPI['ticket_timeline_keep_replaced_tabs']);
echo "\n";
} else {
Html::nullHeader("MAINTENANCE MODE", $CFG_GLPI["root_doc"]);
echo "</p>";
echo "</div>";
Html::nullFooter();
exit();
// Check version
echo "\n";
} else {
Html::nullHeader("UPDATE NEEDED", $CFG_GLPI["root_doc"]);
echo "<table class='tab_cadre'>";
$error = Toolbox::commonCheckForUseGLPI();
echo "</table><br>";
if ($error) {
echo "<form action='".$CFG_GLPI["root_doc"]."/index.php' method='post'>";
echo "<input type='submit' name='submit' class='submit' value=\"".__s('Try again')."\">";
Html::closeForm();
if ($error < 2) {
$older = false;
$newer = false;
$dev = false;
$older = true;
} else {
$dev = true;
$older = true;
$newer = true;
$older = true;
} else {
$newer = true;
$older = true;
$newer = true;
class='submit'>";
Html::closeForm();
echo "</div>";
Html::nullFooter();
exit();
S'il vous plait aidez moi
