Probleme avec script : XML to PHP
Probleme avec script : XML to PHP - PHP - Programmation
Marsh Posté le 15-08-2005 à 19:51:59
j'utilise ce script pour afficher un flux XML en php :
  1. function GetXMLTree ($xmldata)
  2. {
  3. ini_set ('track_errors', '0');
  4. $xmlreaderror = false;
  5. $parser = xml_parser_create ('ISO-8859-1');
  6. xml_parser_set_option ($parser, XML_OPTION_SKIP_WHITE, 1);
  7. xml_parser_set_option ($parser, XML_OPTION_CASE_FOLDING, 0);
  8. if (!xml_parse_into_struct ($parser, $xmldata, $vals, $index)) {
  9.  $xmlreaderror = true;
  10.  echo "error";
  11. }
  12. xml_parser_free ($parser);
  13. if (!$xmlreaderror) {
  14.  $result = array ();
  15.  $i = 0;
  16.  if (isset ($vals [$i]['attributes']))
  17.   foreach (array_keys ($vals [$i]['attributes']) as $attkey)
  18.   $attributes [$attkey] = $vals [$i]['attributes'][$attkey];
  19.  $result [$vals [$i]['tag']] = array_merge ($attributes, GetChildren ($vals, $i, 'open'));
  20. }
  21. ini_set ('track_errors', '0');
  22. return $result;
  23. }
  24. function GetChildren ($vals, &$i, $type)
  25. {
  26. if ($type == 'complete') {
  27.  if (isset ($vals [$i]['value']))
  28.   return ($vals [$i]['value']);
  29.  else
  30.   return '';
  31. }
  32. $children = array ();
  33. while ($vals [++$i]['type'] != 'close') {
  34.  $type = $vals [$i]['type'];
  35.  if (isset ($children [$vals [$i]['tag']])) {
  36.   if (is_array ($children [$vals [$i]['tag']])) {
  37.    $temp = array_keys ($children [$vals [$i]['tag']]);
  38.    if (is_string ($temp [0])) {
  39.     $a = $children [$vals [$i]['tag']];
  40.     unset ($children [$vals [$i]['tag']]);
  41.     $children [$vals [$i]['tag']][0] = $a;
  42.    }
  43.   } else {
  44.    $a = $children [$vals [$i]['tag']];
  45.    unset ($children [$vals [$i]['tag']]);
  46.    $children [$vals [$i]['tag']][0] = $a;
  47.   }
  48.   $children [$vals [$i]['tag']][] = GetChildren ($vals, $i, $type);
  49.  } else
  50.   $children [$vals [$i]['tag']] = GetChildren ($vals, $i, $type);
  51.  if (isset ($vals [$i]['attributes'])) {
  52.   $attributes = array ();
  53.   foreach (array_keys ($vals [$i]['attributes']) as $attkey)
  54.   $attributes [$attkey] = $vals [$i]['attributes'][$attkey];
  55.   if (isset ($children [$vals [$i]['tag']])) {
  56.    if ($children [$vals [$i]['tag']] == '') {
  57.     unset ($children [$vals [$i]['tag']]);
  58.     $children [$vals [$i]['tag']] = $attributes;
  59.    }
  60.    elseif (is_array ($children [$vals [$i]['tag']])) {
  61.     $index = count ($children [$vals [$i]['tag']]) - 1;
  62.     if ($children [$vals [$i]['tag']][$index] == '') {
  63.      unset ($children [$vals [$i]['tag']][$index]);
  64.      $children [$vals [$i]['tag']][$index] = $attributes;
  65.     }
  66.     $children [$vals [$i]['tag']][$index] = array_merge ($children [$vals [$i]['tag']][$index], $attributes);
  67.    } else {
  68.     $value = $children [$vals [$i]['tag']];
  69.     unset ($children [$vals [$i]['tag']]);
  70.     $children [$vals [$i]['tag']]['value'] = $value;
  71.     $children [$vals [$i]['tag']] = array_merge ($children [$vals [$i]['tag']], $attributes);
  72.    }
  73.   } else
  74.    $children [$vals [$i]['tag']] = $attributes;
  75.  }
  76. }
  77. return $children;
  78. }
  79. // URL du flux xml
  80. $url = "info.xml";
  81. $contents = file_get_contents($url);
  82. $data = GetXMLTree ($contents);
  83. print_r($data);
Celui ci marche sans probleme quand le fichier est pas trop gros
seulement si mon fichier XML fait 40mo ca ne marche pas
je lance le script mais rien; page blanche
si qqun peut m'aider
Marsh Posté le 15-08-2005 à 20:16:33
dans ton php.ini ya une limite memory_limit = 8M      ; Maximum amount of memory a script may consume (8MB)
peut-être que c'est ça ?
Marsh Posté le 15-08-2005 à 20:22:37
ca ne change rien
j'ai mis a 64
Marsh Posté le 15-08-2005 à 20:29:53
ça valait le coup d'essayer [:petrus75]
(t'as relançé apache je suppose ?)
Message édité par push le 15-08-2005 à 20:30:29
Marsh Posté le 15-08-2005 à 20:33:12
oui je lai relancer mais pareil
Marsh Posté le 15-08-2005 à 20:35:32
T'a essayé avec un debuggeur?
Si la vérité est découverte par quelqu'un d'autre,elle perd toujours un peu d'attrait
Marsh Posté le 15-08-2005 à 20:37:00
cest a dire ?
Marsh Posté le 15-08-2005 à 20:48:19
Prend un debuggeur PHP et regarde a quel moment ça plante ... ça revient un peu au meme que faire un echo de toutes les variables a chaque ligne ...
Marsh Posté le 15-08-2005 à 20:51:16
Je vois pas trop comment on fait
desolé mais jsuis pas un expert :=
Marsh Posté le 15-08-2005 à 20:53:25
c'est tres bisard
cest le meme fichier, si je met 10 items dans le XML ca marche
si jamais je le met complet (40mo) ca plante
Marsh Posté le 15-08-2005 à 23:14:03
Tu tapes "debugger php" sur google et tu lis, je crois que c'est a ta portée meme si t'es pas un expert
Marsh Posté le 16-08-2005 à 10:15:30
En fait ca viendrait de la limite dexecution de PHP
celle ci est a 32M
j'ai essayé de la monter a 256M mais tj pareil
Ma seule solution est de découper le fichier XML en tout petit mais ca n'est pas pratique car j'aimerai recuperer ce flux pour le mettre a jour toutes les nuits
Si qqun a deja vu ce soucis
Marsh Posté le 16-08-2005 à 10:21:40
Et le debugger te dis quoi?
Marsh Posté le 16-08-2005 à 10:26:48
il me dis Fatal error ; memory etc...
ca vient de ce probleme
