Problème cookie
Problème cookie - PHP - Programmation
Marsh Posté le 10-04-2009 à 21:23:09
Bonjour à tous
Voici mon code php
  1. include("includes/dbconnected.php" );
  2. $config = mysql_query("SELECT * FROM $TABLE_CONFIG" );
  3. $data = mysql_fetch_array($config);
  4. if((!isset($_COOKIE['admin_pseudo'])) OR ($_COOKIE['admin_pseudo'] == '') OR (!isset($_COOKIE['admin_password'])) OR ($_COOKIE['admin_password'] == ''))
  5. {
  6. if ((isset($_POST['sign'])) && ($_POST['sign'] == 'in'))
  7. {
  8.  if ((isset($_POST['admin_pseudo']) && !empty($_POST['admin_pseudo'])) && (isset($_POST['admin_password']) && !empty($_POST['admin_password'])))
  9.  {
  10.         $sql = mysql_query('SELECT * FROM '.$TABLE_USERS.' WHERE pseudo="'.addslashes($_POST['admin_pseudo']).'" AND password="'.md5(addslashes($_POST['admin_password'])).'"');
  11.         $nb = mysql_num_rows($sql);
  12.         if ($nb == 1)
  13.   {
  14.    setcookie('admin_pseudo',$_POST['admin_pseudo'],time()+3600*24*30);
  15.    setcookie('admin_password',md5($_POST['admin_password']),time()+3600*24*30);
  16.    $lg = mysql_fetch_array($sql);
  17.    $_SESSION['lg'] = $lg['lang'];
  18.    $sql2 = mysql_query('UPDATE '.$TABLE_USERS.' SET last_session="'.$date.'" WHERE pseudo = "'.$_POST['admin_pseudo'].'"')  or die('Erreur SQL !<br />'.$sql2.'<br />'.mysql_error());
  19.    $_SESSION['message'] = '<center><font color="green">'.$tx['ADMIN_sign_in_ok'].'</font></center>';
  20.    //$_SESSION['message'] '<meta http-equiv="Refresh" content="2;URL=index.php">';
  21.         }
  22.         else
  23.   {
  24.    $_SESSION['message'] = '<center><font color="red">'.$tx['ADMIN_error'].'</font></center>';
  25.         }
  26.
  27.     }
  28.     else
  29.  {
  30.   $_SESSION['message'] = '<center><font color="red">'.$tx['ADMIN_error_empty'].'</font></center>';
  31.  }
  32. }
  33. }
J'ai une erreur du type
  1. Warning: Cannot modify header information - headers already sent by (output started at /home/gs1433/domains/phpmysiteweb.com/public_html/widgetlike/index.php:1) in /home/gs1433/domains/phpmysiteweb.com/public_html/widgetlike/index.php on line 20
  2. Warning: Cannot modify header information - headers already sent by (output started at /home/gs1433/domains/phpmysiteweb.com/public_html/widgetlike/index.php:1) in /home/gs1433/domains/phpmysiteweb.com/public_html/widgetlike/index.php on line 21
Cependant, je suis presque sûr que je n'ai demandé l'affichage d'aucun truc côté client. Donc quelque chose cloche. Sur easyphp 3, ça marche sans problème. Sur mon serveur internet, ça plante
Merci d'avance pour vos réponses
Marsh Posté le 10-04-2009 à 21:50:51
Il est possible que ton hébergeur affiche une pub.
http://www.aideinfo.com/  Whois adresses IP/domaines le plus évolué !!  FAQ Free Mobile
Marsh Posté le 10-04-2009 à 21:53:01
C'est un hébergeur payant, d'où le fait qu'il n'affiche rien
Je dois changer d'hébergeur pour tester ?
Marsh Posté le 10-04-2009 à 21:54:37
Quel hébergeur ? Il n'affiche pas non plus un script de stat ?
Marsh Posté le 10-04-2009 à 22:00:35
gold-serveur.com
Ah, ça je ne sais pas
Je vais voir sur un autre hébergeur et on verra bien :) Merci de l'info
Marsh Posté le 10-04-2009 à 22:11:28
Vois aussi s'il n'y a pas un espace dans dbconnected.php
Marsh Posté le 10-04-2009 à 22:26:30
J'ai essayé sur un autre hébergeur et ça marche à merveille
Merci aideinfo
Marsh Posté le 13-04-2009 à 09:25:07
Vois avec Gold-serveur, ça confirme qu'ils ajoutent quelque chose au début des pages.
