[PHP] Encore une parse error à deux sous :-/
Encore une parse error à deux sous :-/ [PHP] - PHP - Programmation
Marsh Posté le 02-12-2004 à 18:00:36
Salut les codeurs fous !
(premier post OK, voir le post d'en bas mici :))
(je pense que ça a plus sa place ici que chez S&R)
Bon voilà je me suis tapé une petite install manuelle Apache/PHP/Mysql sur mon poste NT, le truc que je n'avais pas fait depuis facile deux ans.
Et j'ai un petit souci : les variables (PHP) que je passe d'une page à l'autre ne sont pas reconnues ! :D
Je ne vois qu'une mauvais config du fichier httpd.conf, mais alors où ?
Prêts ? Voici le fichier dans sa totalité :D
Merci d'avance :)
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/> for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# After this file is processed, the server will look for and process
# C:/Program Files/Apache Group/Apache/conf/srm.conf and then C:/Program Files/Apache Group/Apache/conf/access.conf
# unless you have overridden these with ResourceConfig and/or
# AccessConfig directives here.
# The configuration directives are grouped into three basic sections:
#  1. Directives that control the operation of the Apache server process as a
#     whole (the 'global environment').
#  2. Directives that define the parameters of the 'main' or 'default' server,
#     which responds to requests that aren't handled by a virtual host.
#     These directives also provide default values for the settings
#     of all virtual hosts.
#  3. Settings for virtual hosts, which allow Web requests to be sent to
#     different IP addresses or hostnames and have them handled by the
#     same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
# with ServerRoot set to "/usr/local/apache" will be interpreted by the
# server as "/usr/local/apache/logs/foo.log".
# NOTE: Where filenames are specified, you must use forward slashes
# instead of backslashes (e.g., "c:/apache" instead of "c:\apache" ).
# If a drive letter is omitted, the drive on which Apache.exe is located
# will be used by default.  It is recommended that you always supply
# an explicit drive letter in absolute paths, however, to avoid
# confusion.
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerType is either inetd, or standalone.  Inetd mode is only supported on
# Unix platforms.
ServerType standalone
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
ServerRoot "C:/Program Files/Apache Group/Apache"
# PidFile: The file in which the server should record its process
# identification number when it starts.
PidFile logs/httpd.pid
# ScoreBoardFile: File used to store internal server process information.
# Not all architectures require this.  But if yours does (you'll know because
# this file will be  created when you run Apache) then you *must* ensure that
# no two invocations of Apache share the same scoreboard file.
ScoreBoardFile logs/apache_runtime_status
# In the standard configuration, the server will process httpd.conf (this
# file, specified by the -f command line option), srm.conf, and access.conf
# in that order.  The latter two files are now distributed empty, as it is
# recommended that all directives be kept in a single file for simplicity.
# The commented-out values below are the built-in defaults.  You can have the
# server ignore these files altogether by using "/dev/null" (for Unix) or
# "nul" (for Win32) for the arguments to the directives.
#ResourceConfig conf/srm.conf
#AccessConfig conf/access.conf
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
# Apache on Win32 always creates one child process to handle requests.  If it
# dies, another child process is created automatically.  Within the child
# process multiple threads handle incoming requests.  The next two
# directives control the behaviour of the threads and processes.
# MaxRequestsPerChild: the number of requests each child process is
# allowed to process before the child dies.  The child will exit so
# as to avoid problems after prolonged use when Apache (and maybe the
# libraries it uses) leak memory or other resources.  On most systems, this
# isn't really needed, but a few (such as Solaris) do have notable leaks
# in the libraries.  For Win32, set this value to zero (unlimited)
# unless advised otherwise.
# NOTE: This value does not include keepalive requests after the initial
#       request per connection. For example, if a child process handles
#       an initial request and 10 subsequent "keptalive" requests, it
#       would only count as 1 request towards this limit.
MaxRequestsPerChild 0
# Number of concurrent threads (i.e., requests) the server will allow.
# Set this value according to the responsiveness of the server (more
# requests active at once means they're all handled more slowly) and
# the amount of system resources you'll allow the server to consume.
ThreadsPerChild 50
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
#Listen 3000
#Listen 12.34.56.78:80
# BindAddress: You can support virtual hosts with this option. This directive
# is used to tell the server which IP address to listen to. It can either
# contain "*", an IP address, or a fully qualified Internet domain name.
# See also the <VirtualHost> and Listen directives.
#BindAddress *
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Please read the file README.DSO in the Apache 1.3 distribution for more
# details about the DSO mechanism and run `apache -l' for the list of already
# built-in (statically linked and thus always available) modules in your Apache
# binary.
# Note: The order in which modules are loaded is important.  Don't change
# the order below without expert advice.
# Example:
# LoadModule foo_module modules/mod_foo.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
#LoadModule mime_magic_module modules/mod_mime_magic.so
#LoadModule status_module modules/mod_status.so
#LoadModule info_module modules/mod_info.so
#LoadModule speling_module modules/mod_speling.so
#LoadModule rewrite_module modules/mod_rewrite.so
#LoadModule anon_auth_module modules/mod_auth_anon.so
#LoadModule dbm_auth_module modules/mod_auth_dbm.so
#LoadModule digest_auth_module modules/mod_auth_digest.so
#LoadModule digest_module modules/mod_digest.so
#LoadModule proxy_module modules/mod_proxy.so
#LoadModule cern_meta_module modules/mod_cern_meta.so
#LoadModule expires_module modules/mod_expires.so
#LoadModule headers_module modules/mod_headers.so
#LoadModule usertrack_module modules/mod_usertrack.so
#LoadModule unique_id_module modules/mod_unique_id.so
LoadModule php4_module c:/PHP/sapi/php4apache.dll
#  Reconstruction of the complete module list from all available modules
#  (static and shared ones) to achieve correct module execution order.
# The modules listed below, without a corresponding LoadModule directive,
# are static bound into the standard Apache binary distribution for Windows.
# [WHENEVER YOU CHANGE THE LOADMODULE SECTION ABOVE, UPDATE THIS TOO!]
ClearModuleList
#AddModule mod_vhost_alias.c
AddModule mod_env.c
AddModule mod_log_config.c
#AddModule mod_mime_magic.c
AddModule mod_mime.c
AddModule mod_negotiation.c
#AddModule mod_status.c
#AddModule mod_info.c
AddModule mod_include.c
AddModule mod_autoindex.c
AddModule mod_dir.c
AddModule mod_isapi.c
AddModule mod_cgi.c
AddModule mod_asis.c
AddModule mod_imap.c
AddModule mod_actions.c
#AddModule mod_speling.c
AddModule mod_userdir.c
AddModule mod_alias.c
#AddModule mod_rewrite.c
AddModule mod_access.c
AddModule mod_auth.c
#AddModule mod_auth_anon.c
#AddModule mod_auth_dbm.c
#AddModule mod_auth_digest.c
#AddModule mod_digest.c
#AddModule mod_proxy.c
#AddModule mod_cern_meta.c
#AddModule mod_expires.c
#AddModule mod_headers.c
#AddModule mod_usertrack.c
#AddModule mod_unique_id.c
AddModule mod_so.c
AddModule mod_setenvif.c
AddModule mod_php4.c
# ExtendedStatus controls whether Apache will generate "full" status
# information (ExtendedStatus On) or just basic information (ExtendedStatus
# Off) when the "server-status" handler is called. The default is Off.
#ExtendedStatus On
### Section 2: 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# Port: The port to which the standalone server listens.  Certain firewall
# products must be configured before Apache can listen to a specific port.
# Other running httpd servers will also interfere with this port.  Disable
# all firewall, security, and other services if you encounter problems.
# To help diagnose problems use the Windows NT command NETSTAT -a
Port 80
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.
ServerAdmin dref2@free.fr
# ServerName allows you to set a host name which is sent back to clients for
# your server if it's different than the one the program would get (i.e., use
# "www" instead of the host's real name).
# Note: You cannot just invent host names and hope they work. The name you
# define here must be a valid DNS name for your host. If you don't understand
# this, ask your network administrator.
# If your host doesn't have a registered DNS name, enter its IP address here.
# You will have to access it by its address (e.g., http://123.45.67.89/)
# anyway, and this will make redirections work in a sensible way.
# 127.0.0.1 is the TCP/IP local loop-back address, often named localhost. Your
# machine always knows itself by this address. If you use Apache strictly for
# local testing and development, you may use 127.0.0.1 as the server name.
ServerName 127.0.0.1
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "U:\Perso\smk"
# Each directory to which Apache has access, can be configured with respect
# to which services and features are allowed and/or disabled in that
# directory (and its subdirectories).
# First, we configure the "default" to be a very restrictive set of
# permissions.
<Directory />
    Options FollowSymLinks
    AllowOverride None
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# This should be changed to whatever you set DocumentRoot to.
<Directory "U:\Perso\smk">
# This may also be "None", "All", or any combination of "Indexes",
# "Includes", "FollowSymLinks", "ExecCGI", or "MultiViews".
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
    Options Indexes FollowSymLinks MultiViews
# This controls which options the .htaccess files in directories can
# override. Can also be "All", or any combination of "Options", "FileInfo",
# "AuthConfig", and "Limit"
    AllowOverride None
# Controls who can get stuff from this server.
    Order allow,deny
    Allow from all
</Directory>
# UserDir: The name of the directory which is appended onto a user's home
# directory if a ~user request is received.
# Under Win32, we do not currently try to determine the home directory of
# a Windows login, so a format such as that below needs to be used.  See
# the UserDir documentation for details.
<IfModule mod_userdir.c>
    UserDir "C:/Program Files/Apache Group/Apache/users/"
</IfModule>
# Control access to UserDir directories.  The following is an example
# for a site where these directories are restricted to read-only.
#<Directory "C:/Program Files/Apache Group/Apache/users">
#    AllowOverride FileInfo AuthConfig Limit
#    Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
#    <Limit GET POST OPTIONS PROPFIND>
#        Order allow,deny
#        Allow from all
#    </Limit>
#    <LimitExcept GET POST OPTIONS PROPFIND>
#        Order deny,allow
#        Deny from all
#    </LimitExcept>
#</Directory>
# DirectoryIndex: Name of the file or files to use as a pre-written HTML
# directory index.  Separate multiple entries with spaces.
<IfModule mod_dir.c>
    DirectoryIndex index.html index.php index.htm index.php3 index.php4
</IfModule>
# AccessFileName: The name of the file to look for in each directory
# for access control information.
AccessFileName .htaccess
# The following lines prevent .htaccess files from being viewed by
# Web clients.  Since .htaccess files often contain authorization
# information, access is disallowed for security reasons.  Comment
# these lines out if you want Web visitors to see the contents of
# .htaccess files.  If you change the AccessFileName directive above,
# be sure to make the corresponding changes here.
# Also, folks tend to use names such as .htpasswd for password
# files, so this will protect those as well.
<Files ~ "^\.ht">
    Order allow,deny
    Deny from all
    Satisfy All
</Files>
# CacheNegotiatedDocs: By default, Apache sends "Pragma: no-cache" with each
# document that was negotiated on the basis of content. This asks proxy
# servers not to cache the document. Uncommenting the following line disables
# this behavior, and proxies will be allowed to cache the documents.
#CacheNegotiatedDocs
# UseCanonicalName:  (new for 1.3)  With this setting turned on, whenever
# Apache needs to construct a self-referencing URL (a URL that refers back
# to the server the response is coming from) it will use ServerName and
# Port to form a "canonical" name.  With this setting off, Apache will
# use the hostname:port that the client supplied, when possible.  This
# also affects SERVER_NAME and SERVER_PORT in CGI scripts.
UseCanonicalName On
# TypesConfig describes where the mime.types file (or equivalent) is
# to be found.
<IfModule mod_mime.c>
    TypesConfig conf/mime.types
</IfModule>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value.  If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
# mod_mime_magic is not part of the default server (you have to add
# it yourself with a LoadModule [see the DSO paragraph in the 'Global
# Environment' section], or recompile the server and include mod_mime_magic
# as part of the configuration), so it's enclosed in an <IfModule> container.
# This means that the MIMEMagicFile directive will only be processed if the
# module is part of the server.
<IfModule mod_mime_magic.c>
    MIMEMagicFile conf/magic
</IfModule>
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog logs/error.log
# LogLevel: Control the number of messages logged to the error.log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here.  Contrariwise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
CustomLog logs/access.log common
# If you would like to have agent and referer logfiles, uncomment the
# following directives.
#CustomLog logs/referer.log referer
#CustomLog logs/agent.log agent
# If you prefer a single logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
#CustomLog logs/access.log combined
# Optionally add a line containing the server version and virtual host
# name to server-generated pages (error documents, FTP directory listings,
# mod_status and mod_info output etc., but not CGI generated documents).
# Set to "EMail" to also include a mailto: link to the ServerAdmin.
# Set to one of:  On | Off | EMail
ServerSignature On
# Apache parses all CGI scripts for the shebang line by default.
# This comment line, the first line of the script, consists of the symbols
# pound (#) and exclamation (!) followed by the path of the program that
# can execute this specific script.  For a perl script, with perl.exe in
# the C:\Program Files\Perl directory, the shebang line should be:
   #!c:/program files/perl/perl
# Note you _must_not_ indent the actual shebang line, and it must be the
# first line of the file.  Of course, CGI processing must be enabled by
# the appropriate ScriptAlias or Options ExecCGI directives for the files
# or directory in question.
# However, Apache on Windows allows either the Unix behavior above, or can
# use the Registry to match files by extention.  The command to execute
# a file of this type is retrieved from the registry by the same method as
# the Windows Explorer would use to handle double-clicking on a file.
# These script actions can be configured from the Windows Explorer View menu,
# 'Folder Options', and reviewing the 'File Types' tab.  Clicking the Edit
# button allows you to modify the Actions, of which Apache 1.3 attempts to
# perform the 'Open' Action, and failing that it will try the shebang line.
# This behavior is subject to change in Apache release 2.0.
# Each mechanism has it's own specific security weaknesses, from the means
# to run a program you didn't intend the website owner to invoke, and the
# best method is a matter of great debate.
# To enable the this Windows specific behavior (and therefore -disable- the
# equivilant Unix behavior), uncomment the following directive:
#ScriptInterpreterSource registry
# The directive above can be placed in individual <Directory> blocks or the
# .htaccess file, with either the 'registry' (Windows behavior) or 'script'
# (Unix behavior) option, and will override this server default option.
# Aliases: Add here as many aliases as you need (with no limit). The format is
# Alias fakename realname
<IfModule mod_alias.c>
    # Note that if you include a trailing / on fakename then the server will
    # require it to be present in the URL.  So "/icons" isn't aliased in this
    # example, only "/icons/".  If the fakename is slash-terminated, then the
    # realname must also be slash terminated, and if the fakename omits the
    # trailing slash, the realname must also omit it.
    Alias /icons/ "C:/Program Files/Apache Group/Apache/icons/"
    <Directory "C:/Program Files/Apache Group/Apache/icons">
        Options Indexes MultiViews
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
    Alias /mysql/ "C:/phpMyAdmin"
    <Directory "C:/phpMyAdmin">
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
    # This Alias will project the on-line documentation tree under /manual/
    # even if you change the DocumentRoot. Comment it if you don't want to
    # provide access to the on-line documentation.
    Alias /manual/ "C:/Program Files/Apache Group/Apache/htdocs/manual/"
    <Directory "C:/Program Files/Apache Group/Apache/htdocs/manual">
        Options Indexes FollowSymlinks MultiViews
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the realname directory are treated as applications and
    # run by the server when requested rather than as documents sent to the client.
    # The same rules about trailing "/" apply to ScriptAlias directives as to
    # Alias.
    ScriptAlias /cgi-bin/ "C:/Program Files/Apache Group/Apache/cgi-bin/"
    # "C:/Program Files/Apache Group/Apache/cgi-bin" should be changed to whatever your ScriptAliased
    # CGI directory exists, if you have that configured.
    <Directory "C:/Program Files/Apache Group/Apache/cgi-bin">
        AllowOverride None
        Options None
        Order allow,deny
        Allow from all
    </Directory>
</IfModule>
# End of aliases.
# Redirect allows you to tell clients about documents which used to exist in
# your server's namespace, but do not anymore. This allows you to tell the
# clients where to look for the relocated document.
# Format: Redirect old-URI new-URL
# Directives controlling the display of server-generated directory listings.
<IfModule mod_autoindex.c>
    # FancyIndexing is whether you want fancy directory indexing or standard
    # Note, add the option TrackModified to the IndexOptions default list only
    # if all indexed directories reside on NTFS volumes.  The TrackModified flag
    # will report the Last-Modified date to assist caches and proxies to properly
    # track directory changes, but it does _not_ work on FAT volumes.
    IndexOptions FancyIndexing
    # AddIcon* directives tell the server which icon to show for different
    # files or filename extensions.  These are only displayed for
    # FancyIndexed directories.
    AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
    AddIconByType (TXT,/icons/text.gif) text/*
    AddIconByType (IMG,/icons/image2.gif) image/*
    AddIconByType (SND,/icons/sound2.gif) audio/*
    AddIconByType (VID,/icons/movie.gif) video/*
    AddIcon /icons/binary.gif .bin .exe
    AddIcon /icons/binhex.gif .hqx
    AddIcon /icons/tar.gif .tar
    AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
    AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
    AddIcon /icons/a.gif .ps .ai .eps
    AddIcon /icons/layout.gif .html .shtml .htm .pdf
    AddIcon /icons/text.gif .txt
    AddIcon /icons/c.gif .c
    AddIcon /icons/p.gif .pl .py
    AddIcon /icons/f.gif .for
    AddIcon /icons/dvi.gif .dvi
    AddIcon /icons/uuencoded.gif .uu
    AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
    AddIcon /icons/tex.gif .tex
    AddIcon /icons/bomb.gif core
    AddIcon /icons/back.gif ..
    AddIcon /icons/hand.right.gif README
    AddIcon /icons/folder.gif ^^DIRECTORY^^
    AddIcon /icons/blank.gif ^^BLANKICON^^
    # DefaultIcon is which icon to show for files which do not have an icon
    # explicitly set.
    DefaultIcon /icons/unknown.gif
    # AddDescription allows you to place a short description after a file in
    # server-generated indexes.  These are only displayed for FancyIndexed
    # directories.
    # Format: AddDescription "description" filename
    #AddDescription "GZIP compressed document" .gz
    #AddDescription "tar archive" .tar
    #AddDescription "GZIP compressed tar archive" .tgz
    # ReadmeName is the name of the README file the server will look for by
    # default, and append to directory listings.
    # HeaderName is the name of a file which should be prepended to
    # directory indexes.
    ReadmeName README.html
    HeaderName HEADER.html
    # IndexIgnore is a set of filenames which directory indexing should ignore
    # and not include in the listing.  Shell-style wildcarding is permitted.
    IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
</IfModule>
# End of indexing directives.
# Document types.
    # AddType allows you to tweak mime.types without actually editing it, or to
    # make certain files to be certain types.
    AddType application/x-tar .tgz
    AddType application/x-httpd-php .php .php3 .php4
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    # Despite the name similarity, the following Add* directives have nothing
    # to do with the FancyIndexing customization directives above.
    AddEncoding x-compress .Z
    AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    #AddType application/x-compress .Z
    #AddType application/x-gzip .gz .tgz
    # AddLanguage allows you to specify the language of a document. You can
    # then use content negotiation to give a browser a file in a language
    # it can understand.
    # Note 1: The suffix does not have to be the same as the language
    # keyword --- those with documents in Polish (whose net-standard
    # language code is pl) may wish to use "AddLanguage pl .po" to
    # avoid the ambiguity with the common suffix for perl scripts.
    # Note 2: The example entries below illustrate that in quite
    # some cases the two character 'Language' abbreviation is not
    # identical to the two character 'Country' code for its country,
    # E.g. 'Danmark/dk' versus 'Danish/da'.
    # Note 3: In the case of 'ltz' we violate the RFC by using a three char
    # specifier. But there is 'work in progress' to fix this and get
    # the reference data for rfc1766 cleaned up.
    # Danish (da) - Dutch (nl) - English (en) - Estonian (ee)
    # French (fr) - German (de) - Greek-Modern (el)
    # Italian (it) - Korean (kr) - Norwegian (no) - Norwegian Nynorsk (nn)
    # Portugese (pt) - Luxembourgeois* (ltz)
    # Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cs)
    # Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
    # Russian (ru)
    AddLanguage da .dk
    AddLanguage nl .nl
    AddLanguage en .en
    AddLanguage et .ee
    AddLanguage fr .fr
    AddLanguage de .de
    AddLanguage el .el
    AddLanguage he .he
    AddCharset ISO-8859-8 .iso8859-8
    AddLanguage it .it
    AddLanguage ja .ja
    AddCharset ISO-2022-JP .jis
    AddLanguage kr .kr
    AddCharset ISO-2022-KR .iso-kr
    AddLanguage nn .nn
    AddLanguage no .no
    AddLanguage pl .po
    AddCharset ISO-8859-2 .iso-pl
    AddLanguage pt .pt
    AddLanguage pt-br .pt-br
    AddLanguage ltz .lu
    AddLanguage ca .ca
    AddLanguage es .es
    AddLanguage sv .sv
    AddLanguage cs .cz .cs
    AddLanguage ru .ru
    AddLanguage zh-TW .zh-tw
    AddCharset Big5         .Big5    .big5
    AddCharset WINDOWS-1251 .cp-1251
    AddCharset CP866        .cp866
    AddCharset ISO-8859-5   .iso-ru
    AddCharset KOI8-R       .koi8-r
    AddCharset UCS-2        .ucs2
    AddCharset UCS-4        .ucs4
    AddCharset UTF-8        .utf8
    # LanguagePriority allows you to give precedence to some languages
    # in case of a tie during content negotiation.
    # Just list the languages in decreasing order of preference. We have
    # more or less alphabetized them here. You probably want to change this.
    <IfModule mod_negotiation.c>
        LanguagePriority en da nl et fr de el it ja kr no pl pt pt-br ru ltz ca es sv tw
    </IfModule>
    # AddHandler allows you to map certain file extensions to "handlers",
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action command (see below)
    # If you want to use server side includes, or CGI outside
    # ScriptAliased directories, uncomment the following lines.
    # To use CGI scripts:
    #AddHandler cgi-script .cgi
    # To use server-parsed HTML files
    #AddType text/html .shtml
    #AddHandler server-parsed .shtml
    # Uncomment the following line to enable Apache's send-asis HTTP file
    # feature
    #AddHandler send-as-is asis
    # If you wish to use server-parsed imagemap files, use
    #AddHandler imap-file map
    # To enable type maps, you might want to use
    #AddHandler type-map var
</IfModule>
# End of document types.
# Action lets you define media types that will execute a script whenever
# a matching file is called. This eliminates the need for repeated URL
# pathnames for oft-used CGI file processors.
# Format: Action media/type /cgi-script/location
# Format: Action handler-name /cgi-script/location
# MetaDir: specifies the name of the directory in which Apache can find
# meta information files. These files contain additional HTTP headers
# to include when sending the document
#MetaDir .web
# MetaSuffix: specifies the file name suffix for the file containing the
# meta information.
#MetaSuffix .meta
# Customizable error response (Apache style)
#  these come in three flavors
#    1) plain text
#ErrorDocument 500 "The server made a boo boo.
#  n.b.  the single leading (" ) marks it as text, it does not get output
#    2) local redirects
#ErrorDocument 404 /missing.html
#  to redirect to local URL /missing.html
#ErrorDocument 404 /cgi-bin/missing_handler.pl
#  N.B.: You can redirect to a script or a document using server-side-includes.
#    3) external redirects
#ErrorDocument 402 http://www.example.com/subscription_info.html
#  N.B.: Many of the environment variables associated with the original
#  request will *not* be available to such a script.
# Customize behaviour based on the browser
<IfModule mod_setenvif.c>
    # The following directives modify normal HTTP response behavior.
    # The first directive disables keepalive for Netscape 2.x and browsers that
    # spoof it. There are known problems with these browser implementations.
    # The second directive is for Microsoft Internet Explorer 4.0b2
    # which has a broken HTTP/1.1 implementation and does not properly
    # support keepalive when it is used on 301 or 302 (redirect) responses.
    BrowserMatch "Mozilla/2" nokeepalive
    BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
    # The following directive disables HTTP/1.1 responses to browsers which
    # are in violation of the HTTP/1.0 spec by not being able to grok a
    # basic 1.1 response.
    BrowserMatch "RealPlayer 4\.0" force-response-1.0
    BrowserMatch "Java/1\.0" force-response-1.0
    BrowserMatch "JDK/1\.0" force-response-1.0
</IfModule>
# End of browser customization directives
# Allow server status reports, with the URL of http://servername/server-status
# Change the "fr.net.intra." to match your domain to enable.
#<Location /server-status>
#    SetHandler server-status
#    Order deny,allow
#    Deny from all
#    Allow from fr.net.intra.
#</Location>
# Allow remote server configuration reports, with the URL of
# http://servername/server-info (requires that mod_info.c be loaded).
#<Location /server-info>
#    SetHandler server-info
#    Order deny,allow
#    Deny from all
#</Location>
# There have been reports of people trying to abuse an old bug from pre-1.1
# days.  This bug involved a CGI script distributed as a part of Apache.
# By uncommenting these lines you can redirect these attacks to a logging
# script on phf.apache.org.  Or, you can record them yourself, using the script
# support/phf_abuse_log.cgi.
#<Location /cgi-bin/phf*>
#    Deny from all
#    ErrorDocument 403 http://phf.apache.org/phf_abuse_log.cgi
#</Location>
### Section 3: Virtual Hosts
# VirtualHost: If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at <URL:http://www.apache.org/docs/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# Use name-based virtual hosting.
#NameVirtualHost *:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for requests without a known
# server name.
#<VirtualHost *:80>
#    ServerAdmin webmaster@dummy-host.example.com
#    DocumentRoot /www/docs/dummy-host.example.com
#    ServerName dummy-host.example.com
#    ErrorLog logs/dummy-host.example.com-error_log
#    CustomLog logs/dummy-host.example.com-access_log common
#</VirtualHost>
Message édité par Fred999 le 03-12-2004 à 10:36:29
Marsh Posté le 02-12-2004 à 18:20:50
Bon je vais préciser un peu la demande.
Le traitement de données MySQL fonctionne très bien (j'affiche un calendrier).
Mais dès lors que je veux passer des variables à une page, il fait comme si ces variables étaient inexistantes !
Le truc louche, c'est que sur mon site, ça marche très bien avec le même code.
Marsh Posté le 02-12-2004 à 18:29:08
tu les récupères comment tes variables? un bout de code?
[edit]
Php a pas mal changé depuis 2 ans!
Message édité par skeye le 02-12-2004 à 18:29:22
Can't buy what I want because it's free -
Marsh Posté le 02-12-2004 à 18:38:48
Merci de ta réponse :)
PHP a effectivement pas mal bougé, mais je ne l'utilise pas à un niveau très élevé.
Bin tout bêtement, si j'appelle la page :
http://127.0.0.1/?page=toto
Je tombe dans mon index.php.
Dans cet index.php, il y a
if (empty($page)) $page = "news";
et quand je fais un echo $page après cette instruction, il m'affiche toujours "news" :sweat:
Et en prime le code HTML n'est pas complet sur la page web (IE 5.5).
Marsh Posté le 02-12-2004 à 19:04:39
normal.
$_GET["page"]
Message édité par skeye le 02-12-2004 à 19:04:47
Marsh Posté le 02-12-2004 à 19:16:02
Tiens ça c'est uns nouvelle subtilité de PHP :D
Merci beaucoup :jap:
Sur mon serveur (site associé), l'install est tellement vieille que ça passe.
Marsh Posté le 02-12-2004 à 19:16:50
[:khamal]
Marsh Posté le 02-12-2004 à 19:24:48
Bon OK :sweat:
Histoire de me justifier un peu, j'ai appris PHP à l'arrache, et ne m'en sers pas professionnellement :o
Marsh Posté le 03-12-2004 à 08:33:20
Bien évidemment, maintenant ça marche.
Merci beaucoup :)
Enfin pouruqoi est-ce que cela passe sur mon site, alors que je n'emploie jamais ce code ? Permissivité des anciennes versions ?
Marsh Posté le 03-12-2004 à 08:44:24
Merci beaucoup :)
oui, les anciennes versions permettaient ce genre de choses...
Marsh Posté le 03-12-2004 à 08:53:49
OK :jap:
Pourtant j'ai pris la version 4.3, donc pas la dernière.
Bon j'aurais appris un truc, faudrait que je traîne plus souvent ici (j'y étais en permanence lors de la création) ;)
Marsh Posté le 03-12-2004 à 08:56:56
Fred999 a écrit :
OK :jap:
Je pense que ce n'est plus faisable depuis la version 4...à vérifier.
Marsh Posté le 03-12-2004 à 08:59:48
On a un serveur antique et quasiment plus maintenu, l'horloge n'est même pas à l'heure :sweat:
(et je n'ai aucun pouvoir dessus)
Marsh Posté le 03-12-2004 à 10:35:47
Bon je réuppe, là je me sens vraiment con :/
<? if (empty($_GET["$id_circuit"])) $id_circuit = 1;
else $id_circuit = $_GET["$id_circuit"];
// Liste des coupes et choix des circuits
$requete = "select coupiin_ci, coup_ch_libelle from smk_coupe order by coupiin_ci desc";
$reponse = mysql_query($requete) or die ($requete . "merci de conserver ce texte et de contacter un admin" ); ?>
while ($row = mysql_fetch_array($reponse)) {
 $id_coupe = $row["coupiin_ci"];
 $coupe  = $row["coup_ch_libelle"];
 $requetecir = "select circiin_ci, circ_ch_libelle from smk_circuit where coupiin_ci = $id_coupe order by circiin_ci";
 $reponsecir = mysql_query($requetecir) or die ($requetecir . "merci de conserver ce texte et de contacter un admin" );
 <td>
  <select onChange="if (this.selectedIndex != 0) window.location.href = this.options[this.selectedIndex].value;" name="circuits">
   <option value="aucun" selected><? echo $coupe; ?></option>
  </select>
 </td>
Il me sort l'erreur parse error, unexpected '}' in u:\\perso\\smk\\circuit.php on line 35
Donc sur la fermeture de boucle.
[:wam]
Marsh Posté le 03-12-2004 à 10:56:28
Ce qui est en gras est en trop :D
Marsh Posté le 03-12-2004 à 11:04:04
[:kalisto]
J'étais certain que c'était une connerie comme ça. Le genre de truc qui t'es invisible mais apparaît directement à n'importe quel tiers.
