Pb MYSQL ordre insert
Pb MYSQL ordre insert - PHP - Programmation
Marsh Posté le 25-07-2002 à 09:56:35
J'ai un pb avec cet ordre . Vous voyez l'erreur ???
include("fonctions.php" );
  #Appel de la fonction connect ds fonctions.php
  Connect();
$r1321 = "insert into 'roulement' values (
98205809, 78,29460,'E',20625,2,'F','29460E','R06210',NULL,
'91','9','4','','0','0','300.000','540.000','145.000','1',
'0.0000','175.0000','0.00','370.0000', '0.0000', '0.00', '125.00', '55.0',
'70.0', '0.00', '0.00', '489.2000', '0.0000', '0.00', '0.00', '145.0000',
'0.00',
'0.0', '6.0', '0.0', '0.0', '0.0', '0.0', '0.0', '0.000', '0.000', '0.000',
'0.0', '0.0', '0.000', '0.000', '415.0000', '0.00', '319.00', '0.00', '0.00', '0.00',
'0.00', '0.00', '340.00', '0.00', '0.00', '0.00', '465.00', '0.00', '0.00', '0.00',
'', '4512.00', '16458.00', '0.000', '0.000', '0.000', '0.000', '0', '580', '133.0000',
'0.000', '1.000', '0.000', '69.100', '415.9900', '731.4000', '19', '85.340', '0.000', '512003',
'0', '', '', '', '', 'Q01', 'G', '0.000', '0.000', '0.000',
'0.000', '0', 'O',
20020705, '', '', '0.448', '5.955',
'8.514', '10.485',
20020625 , , 'H', '', '', '0.0', '0.00', '0.00', '0.000';)" ;
Marsh Posté le 25-07-2002 à 10:02:36
c quoi l'erreur ?
tu as le bon nombre de champs ?
tu as essayé la requête dans phpmyadmin ou autre ?
