PEAR ne veux pas m'installer de packages sur wamp ?
PEAR ne veux pas m'installer de packages sur wamp ? - PHP - Programmation
Marsh Posté le 01-08-2011 à 22:12:40
Bonjour.
J'ai installé pear aprés avoir installé wampserver en faisant quelques corrections trouvé surun site pour que l'installation fonctionne.
quand je fais pear list j'ai bien :
  1. INSTALLED PACKAGES, CHANNEL PEAR.PHP.NET:
  2. =========================================
  3. PACKAGE          VERSION STATE
  4. Archive_Tar      1.3.7   stable
  5. Console_Getopt   1.3.1   stable
  6. PEAR             1.9.4   stable
  7. Structures_Graph 1.0.4   stable
  8. XML_Util         1.2.1   stable
mais quand je fais pear install mdb2 j'obtiens :
  1. No releases available for package "pear.php.net/mdb2"
  2. install failed
et quand je fais
pear download-all
il me fait la même erreur pour tous les packages sauf ceux deja installé.
je vous met un copier coller juste de la fin mais c'est pareil pour tous les packages :
  1. No releases available for package "pear.php.net/Validate_ZA"
  2. No releases available for package "pear.php.net/Var_Dump"
  3. No releases available for package "pear.php.net/VersionControl_Git"
  4. No releases available for package "pear.php.net/VersionControl_SVN"
  5. No releases available for package "pear.php.net/VFS"
  6. No releases available for package "pear.php.net/XML_Beautifier"
  7. No releases available for package "pear.php.net/XML_CSSML"
  8. No releases available for package "pear.php.net/XML_DB_eXist"
  9. No releases available for package "pear.php.net/XML_DTD"
  10. No releases available for package "pear.php.net/XML_FastCreate"
  11. No releases available for package "pear.php.net/XML_Feed_Parser"
  12. No releases available for package "pear.php.net/XML_fo2pdf"
  13. No releases available for package "pear.php.net/XML_FOAF"
  14. No releases available for package "pear.php.net/XML_GRDDL"
  15. No releases available for package "pear.php.net/XML_HTMLSax"
  16. No releases available for package "pear.php.net/XML_HTMLSax3"
  17. No releases available for package "pear.php.net/XML_image2svg"
  18. No releases available for package "pear.php.net/XML_Indexing"
  19. No releases available for package "pear.php.net/XML_MXML"
  20. No releases available for package "pear.php.net/XML_NITF"
  21. No releases available for package "pear.php.net/XML_Parser"
  22. No releases available for package "pear.php.net/XML_Query2XML"
  23. No releases available for package "pear.php.net/XML_RDDL"
  24. No releases available for package "pear.php.net/XML_RPC"
  25. No releases available for package "pear.php.net/XML_RPC2"
  26. No releases available for package "pear.php.net/XML_RSS"
  27. No releases available for package "pear.php.net/XML_SaxFilters"
  28. No releases available for package "pear.php.net/XML_Serializer"
  29. No releases available for package "pear.php.net/XML_sql2xml"
  30. No releases available for package "pear.php.net/XML_Statistics"
  31. No releases available for package "pear.php.net/XML_SVG"
  32. No releases available for package "pear.php.net/XML_svg2image"
  33. No releases available for package "pear.php.net/XML_Transformer"
  34. No releases available for package "pear.php.net/XML_Tree"
  35. No releases available for package "pear.php.net/XML_Util2"
  36. No releases available for package "pear.php.net/XML_Wddx"
  37. No releases available for package "pear.php.net/XML_XPath"
  38. No releases available for package "pear.php.net/XML_XPath2"
  39. No releases available for package "pear.php.net/XML_XSLT_Wrapper"
  40. No releases available for package "pear.php.net/XML_XUL"
  41. downloading Archive_Tar-1.3.7.tgz ...
  42. Starting to download Archive_Tar-1.3.7.tgz (17,610 bytes)
  43. ......done: 17,610 bytes
  44. downloading Console_Getopt-1.3.1.tgz ...
  45. Starting to download Console_Getopt-1.3.1.tgz (4,471 bytes)
  46. ...done: 4,471 bytes
  47. downloading PEAR-1.9.4.tgz ...
  48. Starting to download PEAR-1.9.4.tgz (296,332 bytes)
  49. ...done: 296,332 bytes
  50. downloading Structures_Graph-1.0.4.tgz ...
  51. Starting to download Structures_Graph-1.0.4.tgz (30,318 bytes)
  52. ...done: 30,318 bytes
  53. downloading XML_Util-1.2.1.tgz ...
  54. Starting to download XML_Util-1.2.1.tgz (17,729 bytes)
  55. ...done: 17,729 bytes
  56. download failed
Savez vous ce qui ne va pas bien ?
Et comment installer de nouveaux packages ?
Merci.
Message édité par lparis le 01-08-2011 à 22:13:47
