[Free] impossible d'utiliser les sessions
impossible d'utiliser les sessions [Free] - PHP - Programmation
Marsh Posté le 28-02-2004 à 17:04:00
Impossible de crééer des sessions chez Free?
voici le message d'erreur sur mon site:
Warning: session_start(): open(/var/www/free.fr/6/a/mon_site/sessions/.sess_82c43074f9cb37fcaac25f168e804156, O_RDWR) failed: No such file or directory (2) in /var/www/free.fr/6/a/mon_site/index.php on line 2
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /var/www/free.fr/6/a/mon_site/index.php:2) in /var/www/free.fr/6/a/mon_site/index.php on line 2
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /var/www/free.fr/6/a/mon_site/index.php:2) in /var/www/free.fr/6/a/mon_site/index.php on line 2
Warning: mysql_connect(): Access denied for user: 'mon_site@212.27.40.147' (Using password: YES) in /var/www/free.fr/6/a/mon_site/index.php on line 7
Warning: mysql_select_db(): Access denied for user: 'mon_site@212.27.40.147' (Using password: NO) in /var/www/free.fr/6/a/mon_site/index.php on line 8
Warning: mysql_select_db(): A link to the server could not be established in /var/www/free.fr/6/a/mon_site/index.php on line 8
Warning: mysql_query(): Access denied for user: 'mon_site@212.27.40.147' (Using password: NO) in /var/www/free.fr/6/a/mon_site/index.php on line 84
Warning: mysql_query(): A link to the server could not be established in /var/www/free.fr/6/a/mon_site/index.php on line 84
Probleme de mémorisation du client
Warning: mysql_close(): no MySQL-Link resource supplied in /var/www/free.fr/6/a/mon_site/index.php on line 92
Warning: Unknown(): open(/var/www/free.fr/6/a/mon_site/sessions/.sess_82c43074f9cb37fcaac25f168e804156, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/www/free.fr/6/a/mon_site/sessions) in Unknown on line 0
je pense que ca doit etre un probleme d'ecriture
qu'en pensez vous?
Marsh Posté le 28-02-2004 à 17:05:07
il faut créer un répertoire 'sessions' à la racine de ton compte
Marsh Posté le 28-02-2004 à 17:18:55
merci ca marche super
ya til d'autre truc a savoir de maniere generale ?
Marsh Posté le 28-02-2004 à 17:34:21
oui faire rechercher avant de poster et surtout lire la doc sur le site de free :jap:
(je dis pas ca mechament, j'ai fais la même erreur au debut :D)
IVG en france
Marsh Posté le 28-02-2004 à 17:35:42
ta pas tort, c'est vrai que jutilise trop la methode texane:
poster puis lire les docs apres
