Commentaire de code ? Auto génération ?
Commentaire de code ? Auto génération ? - PHP - Programmation
Marsh Posté le 26-08-2008 à 16:14:03
Salut a tous...
Quand on regarde certains codes php on peut souvent voir les même lignes en début de code : prenons l'exemple d'un fichier typo3 ;)
  1. /***************************************************************
  2. *  Copyright notice
  3. *
  4. *  (c) 1999-2008 Kasper Skaarhoj (kasperYYYY@typo3.com)
  5. *  All rights reserved
  6. *
  7. *  This script is part of the TYPO3 project. The TYPO3 project is
  8. *  free software; you can redistribute it and/or modify
  9. *  it under the terms of the GNU General Public License as published by
  10. *  the Free Software Foundation; either version 2 of the License, or
  11. *  (at your option) any later version.
  12. *
  13. *  The GNU General Public License can be found at
  14. http://www.gnu.org/copyleft/gpl.html.
  15. *  A copy is found in the textfile GPL.txt and important notices to the license
  16. *  from the author is found in LICENSE.txt distributed with these scripts.
  17. *
  18. *
  19. *  This script is distributed in the hope that it will be useful,
  20. *  but WITHOUT ANY WARRANTY; without even the implied warranty of
  21. *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  22. *  GNU General Public License for more details.
  23. *
  24. *  This copyright notice MUST APPEAR in all copies of the script!
  25. ***************************************************************/
  26. /**
  27. * Login-screen of TYPO3.
  28. *
  29. * $Id: index.php 3633 2008-04-23 11:47:26Z flyguide $
  30. * Revised for TYPO3 3.6 December/2003 by Kasper Skaarhoj
  31. * XHTML compliant
  32. *
  33. * @author Kasper Skaarhoj <kasperYYYY@typo3.com>
  34. */
  35. /**
  36. * [CLASS/FUNCTION INDEX of SCRIPT]
  37. *
  38. *
  39. *
  40. *   87: class SC_index
  41. *  120:     function init()
  42. *  159:     function main()
  43. *  268:     function printContent()
  44. *
  45. *              SECTION: Various functions
  46. *  292:     function makeLoginForm()
  47. *  337:     function makeLogoutForm()
  48. *  379:     function wrapLoginForm($content)
  49. *  438:     function checkRedirect()
  50. *  495:     function makeInterfaceSelectorBox()
  51. *  549:     function makeCopyrightNotice()
  52. *  582:     function makeLoginBoxImage()
  53. *  622:     function makeLoginNews()
  54. *
  55. * TOTAL FUNCTIONS: 11
Bon, on a tous reconnus des commentaires de code, mais les questions que je me pose, sont les suivantes :
- L'auteur se tape t'il à la main ces commentaires ?
- Existe t il un logiciel ou editeur qui permettent de les générer automatiquement ?
(que ce soit en en-tête de fichier ou pour decrire des fonctions de classe par exemple...)
- Doxygene par exemple se base sur les commentaires de code pour generer des doc... fait-il l'inverse ? (pourquoi pas vu qu'il "parse" les fichiers...)
Bref ceci m'aiderait drolement dans la conception des mes classes et fonctions php (actuellement je m'écris tout à la main ou via des copier/coller...)
Merci pour les réponses...  [:l'ours maturin]
Rien est impossible, il suffit d'y croire !
Marsh Posté le 26-08-2008 à 16:45:37
Idée: te faire une appli qui fait ça automatiquement ?
arg(z) = pi /2 donc z = i, moi je prends pas
Marsh Posté le 26-08-2008 à 16:54:20
J'y ai pensé à un moment donné, mais bon, si ca existe, pourquoi ré-inventer la roue... Et t'imagine l'appli ? (bon ok, suffit de mettre un morceau au debut du fichier, parser les classe, function, etc...
it's possible, mais pas forcément utile de s'attarder dessus...
Message édité par Pyksel le 26-08-2008 à 16:55:00
Marsh Posté le 26-08-2008 à 16:56:43
Ton IDE devrait savoir faire ça...
[edit]
ça se fait à la création du fichier, par contre, en général...
Message édité par skeye le 26-08-2008 à 16:57:14
Can't buy what I want because it's free -
Marsh Posté le 26-08-2008 à 17:11:29
J'utilise dreamweaver CS3... evidement je peux réutiliser les fragments de code, mais un logiciel qui parse les fichiers ca peut être pas mal utile... Pour commenter au mieux le code source. (j'ai l'impression de m'enliser là ;))
Marsh Posté le 27-08-2008 à 16:36:41
phpEd permet de le faire, notamment :D
et de surcroit retrace l'arborescence des fichiers dans ton projet, retrace où sont placées tes fonctions,classes,variables et un tas d'autre choses :)
Message édité par grosbin le 27-08-2008 à 16:37:57
Photos Panoramiques Montagnes Haute Savoie
Marsh Posté le 27-08-2008 à 22:44:57
lôÔôl c'est pas l'idéal pour le PHP, PHPEdit powaa  ;)
Marsh Posté le 27-08-2008 à 23:26:33
Disons que dreamweaver me depanne pas mal... j'aime bien finalement même si pas aussi complet que zend studio pour le php...
Marsh Posté le 27-08-2008 à 23:30:01
de toute façon, moi, quand il y a de la coloration syntaxique... :)
Marsh Posté le 27-08-2008 à 23:33:16
Pour ca que je l'apprécie finalement ;)
Marsh Posté le 29-08-2008 à 00:35:18
J'avais trouvé la PHPDoc, une sorte d'équivalent de la Javadoc, mais je n'ai pas bcp testé ...
http://www.phpdoc.de/
NewsletTux - outil de mailing list en PHP MySQL
