Programmation : pb avec inetaddress - Java - Programmation
Marsh Posté le 18-11-2007 à 14:32:08
package jul;
import java.net.*;
import java.io.*;
import java.util.*;
import javax.swing.JOptionPane;
public class Ip extends javax.swing.JFrame {
public Ip() {
try {
initComponents();
InetAddress Moi = InetAddress.getLocalHost();
MonIP.setText( "Mon nom : "+Moi.getHostName() +" "+"Mon @ IP : "+Moi.getHostAddress());
} catch (Exception ex) {
ex.printStackTrace();
// <editor-fold defaultstate="collapsed" desc="Generated Code">
private void initComponents() {
Recherch = new javax.swing.JButton();
TextNom = new javax.swing.JTextField();
jScrollPane1 = new javax.swing.JScrollPane();
TextIP = new javax.swing.JTextArea();
MonIP = new javax.swing.JLabel();
AllAddress = new javax.swing.JCheckBox();
jLabel1 = new javax.swing.JLabel();
jLabel2 = new javax.swing.JLabel();
BoutAllAddress = new javax.swing.JButton();
jScrollPane2 = new javax.swing.JScrollPane();
TextAllIP = new javax.swing.JTextArea();
TextBaseIP = new javax.swing.JTextField();
jLabel3 = new javax.swing.JLabel();
jMenuBar1 = new javax.swing.JMenuBar();
Save = new javax.swing.JMenu();
jMenuItem1 = new javax.swing.JMenuItem();
jMenu2 = new javax.swing.JMenu();
About = new javax.swing.JMenuItem();
setTitle("IP LAN" );
Recherch.setText("Rechercher" );
Recherch.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
RecherchActionPerformed(evt);
TextNom.setText(" " );
TextIP.setColumns(20);
TextIP.setRows(5);
jScrollPane1.setViewportView(TextIP);
AllAddress.setText("Toutes @ IP" );
jLabel1.setText("Nom de la machine :" );
jLabel2.setText("@ IP de la machine :" );
BoutAllAddress.setText("Rechercher all @ IP" );
BoutAllAddress.addActionListener(new java.awt.event.ActionListener() {
BoutAllAddressActionPerformed(evt);
TextAllIP.setColumns(20);
TextAllIP.setRows(5);
jScrollPane2.setViewportView(TextAllIP);
TextBaseIP.setText("192.168.0." );
jLabel3.setText("jLabel3" );
Save.setText("File" );
jMenuItem1.setAccelerator(javax.swing.KeyStroke.getKeyStroke(java.awt.event.KeyEvent.VK_S, java.awt.event.InputEvent.CTRL_MASK));
jMenuItem1.setText("Save" );
jMenuItem1.addActionListener(new java.awt.event.ActionListener() {
jMenuItem1ActionPerformed(evt);
Save.add(jMenuItem1);
jMenuBar1.add(Save);
jMenu2.setText("About" );
About.setText("About" );
About.addActionListener(new java.awt.event.ActionListener() {
AboutActionPerformed(evt);
jMenu2.add(About);
jMenuBar1.add(jMenu2);
setJMenuBar(jMenuBar1);
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(layout.createSequentialGroup()
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
.addComponent(TextNom)
.addGap(25, 25, 25)
.addComponent(jLabel1))
.addGap(20, 20, 20)
.addComponent(jLabel2))
.addComponent(AllAddress)
.addComponent(Recherch, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addComponent(jScrollPane1)
.addComponent(MonIP))
.addGap(38, 38, 38)
.addComponent(BoutAllAddress, javax.swing.GroupLayout.DEFAULT_SIZE, 216, Short.MAX_VALUE)
.addComponent(TextBaseIP)
.addComponent(jScrollPane2))
.addContainerGap(69, Short.MAX_VALUE))
layout.setVerticalGroup(
.addComponent(MonIP, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGap(37, 37, 37)
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
.addComponent(BoutAllAddress))
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGap(18, 18, 18)
.addComponent(TextNom, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGap(38, 38, 38)
.addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.UNRELATED)
.addComponent(Recherch))
.addGap(4, 4, 4)
.addComponent(TextBaseIP, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGap(27, 27, 27)
.addComponent(jScrollPane2, javax.swing.GroupLayout.PREFERRED_SIZE, 339, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jLabel2))))
.addContainerGap(javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
pack();
}// </editor-fold>
private void RecherchActionPerformed(java.awt.event.ActionEvent evt) {
if(AllAddress.isValid()==true){
try {
InetAddress[] addr = InetAddress.getAllByName(TextNom.getText());
for (int i = 0; i < addr.length; i++) {
String a = addr[i].toString();
TextIP.setText(a);
else{
try{
InetAddress host=InetAddress.getByName(TextNom.getText());
TextIP.setText(host.getHostAddress());
catch(Exception e){
e.printStackTrace();
private void AboutActionPerformed(java.awt.event.ActionEvent evt) {
JOptionPane.showMessageDialog(null,
"Créé par Jul",
"About",
JOptionPane.INFORMATION_MESSAGE);
private void jMenuItem1ActionPerformed(java.awt.event.ActionEvent evt) {
FileWriter addresse;
recupDate();
String nom = TextNom.getText();
nomFichier=JOptionPane.showInputDialog("entrer un nom de fichier" );
affichage="\r\n"+date+"\r\n";
try{
String text = this.TextIP.getText();
addresse = new FileWriter(nomFichier+".txt",true);
addresse.write(affichage);
addresse.write(nom+":"+text+"\r\n" );
addresse.close();
catch(Exception e){
private void BoutAllAddressActionPerformed(java.awt.event.ActionEvent evt) {
int n = 0;
while( n < 255 ){
try {
String p = TextBaseIP.getText() + n;
InetAddress o = InetAddress.getByName(p);
String h = o.getHostName();
if (p.equalsIgnoreCase(o.toString()) == true) {
TextAllIP.setText("" );
//TextAllIP.setText(o.toString() +" : Address no utils\r\n" );
else {
TextAllIP.setText(o.toString() +" : "+ h +"\r\n" );
catch(Exception e){
public String recupDate(){
Date maDate = new Date();
date=maDate.toString();
return date;
public static void main(String [] args) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new Ip().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JMenuItem About;
private javax.swing.JCheckBox AllAddress;
private javax.swing.JButton BoutAllAddress;
private javax.swing.JLabel MonIP;
private javax.swing.JButton Recherch;
private javax.swing.JMenu Save;
private javax.swing.JTextArea TextAllIP;
private javax.swing.JTextField TextBaseIP;
private javax.swing.JTextArea TextIP;
private javax.swing.JTextField TextNom;
private javax.swing.JLabel jLabel1;
private javax.swing.JLabel jLabel2;
private javax.swing.JLabel jLabel3;
private javax.swing.JMenu jMenu2;
private javax.swing.JMenuBar jMenuBar1;
private javax.swing.JMenuItem jMenuItem1;
private javax.swing.JScrollPane jScrollPane1;
private javax.swing.JScrollPane jScrollPane2;
// End of variables declaration
public String affichage="";
public String hote="";
public String nomFichier="";
public Date maDate=null;
public String date="";
Marsh Posté le 19-11-2007 à 10:37:28
Tu ne poses pas de question. J'en déduis que tu veux qu'on donne une solution toute faite à ton problème, çàd qu'on reprenne le code et qu'on le corrige? J'ai bon?
Marsh Posté le 19-11-2007 à 21:01:45
Le probleme c'est au niveau de de laffichage direct de mon address IP et du nom si je ne le met pas ca marche a moitier
metton je met "tit" comme nom a rechercher il me di quil ya un prbleme au niveau de "native method" et sinon la recherche de tte les addresse IP utilisé ds le reseau le bouton reste comme bloqué et rien ne se passe
Marsh Posté le 19-11-2007 à 22:41:52
Super, mais pourrais-tu stp reformuler, avec de la ponctuation et en te souciant un minumum de l'orthographe, pour les vieux qui te lisent. En évitant d'écrire phonétiquement, en quelque sorte. ![]()
Marsh Posté le 18-11-2007 à 14:30:35
Bon voila j'essaye de faire un programme pour :
- chercher toutes les personnes connecter a un reseau lan en affichant l'adresse utilisé et le nom du l'utilisateur
- donner ttes les @ ip d'un nom par exemple "www.google.com" c'est a dire connaitre toutes les adresses qui le compose
- ce qui en resulte doit etre enregistrable (ok)
tous ca suivant la progression en venir a faire une sorte de "msn" on va dire donc pourvoir selectionné une address et pouvoir communiquer avec
merci d'avance
