probleme de lancement d'eclipse !! an error has occured. see the log
probleme de lancement d'eclipse !! an error has occured. see the log - Java - Programmation
MarshPosté le 04-08-2009 à 09:39:38
Bonjour; j'ai un souci avec l'ouverture de workspace eclipse ( avant il s'ouvrait sans problème) un message d'erreur: an error has occured.see the log file cDocuments and Settings/Administrateur/workspace/.metadata
!ENTRY org.eclipse.ui.views.properties.tabbed 4 4 2009-05-14 16:44:25.953 !MESSAGE Contributor org.eclipse.datatools.connectivity.DataSourceExplorerNavigator cannot be created. !STACK 1 org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.datatools.connectivity.ui.dse was unable to load class org.eclipse.ui.internal.navigator.resources.workbench.TabbedPropertySheetTitleProvider. at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:162) at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:867) at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243) at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51) at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistry.<init>(TabbedPropertyRegistry.java:127) at org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyRegistryFactory.createRegistry(TabbedPropertyRegistryFactory.java:74) at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.initContributor(TabbedPropertySheetPage.java:389) at org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPage.<init>(TabbedPropertySheetPage.java:278) at org.eclipse.ui.internal.navigator.resources.workbench.TabbedPropertySheetAdapterFactory.getAdapter(TabbedPropertySheetAdapterFactory.java:37) at org.eclipse.core.internal.adapter.AdapterFactoryProxy.getAdapter(AdapterFactoryProxy.java:80) at org.eclipse.core.internal.runtime.AdapterManager.getAdapter(AdapterManager.java:291) at org.eclipse.ui.part.WorkbenchPart.getAdapter(WorkbenchPart.java:151) at org.eclipse.ui.navigator.CommonNavigator.getAdapter(CommonNavigator.java:379) at org.eclipse.ui.internal.views.ViewsPlugin.getAdapter(ViewsPlugin.java:103) at org.eclipse.ui.views.properties.PropertySheet.doCreatePage(PropertySheet.java:120) at org.eclipse.ui.part.PageBookView.createPage(PageBookView.java:399) at org.eclipse.ui.part.PageBookView.partActivated(PageBookView.java:741) at org.eclipse.ui.views.properties.PropertySheet.partActivated(PropertySheet.java:192) at org.eclipse.ui.internal.PartListenerList$1.run(PartListenerList.java:72) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37) at org.eclipse.core.runtime.Platform.run(Platform.java:880) at org.eclipse.ui.internal.PartListenerList.fireEvent(PartListenerList.java:57) at org.eclipse.ui.internal.PartListenerList.firePartActivated(PartListenerList.java:70) at org.eclipse.ui.internal.PartService.firePartActivated(PartService.java:186) at org.eclipse.ui.internal.PartService.setActivePart(PartService.java:305) at org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePartChanged(WorkbenchPagePartList.java:56) at org.eclipse.ui.internal.PartList.setActivePart(PartList.java:126) at org.eclipse.ui.internal.WorkbenchPage.setActivePart(WorkbenchPage.java:3491) at org.eclipse.ui.internal.WorkbenchPage.requestActivation(WorkbenchPage.java:3034) at org.eclipse.ui.internal.PartPane.requestActivation(PartPane.java:272) at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:318) at org.eclipse.ui.internal.PartStack.presentationSelectionChanged(PartStack.java:846) at org.eclipse.ui.internal.PartStack.access$1(PartStack.java:829) at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.java:139) at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation$1.handleEvent(TabbedStackPresentation.java:133) at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder.java:267) at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder.java:276) at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder.access$1(DefaultTabFolder.java:1) at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder$2.handleEvent(DefaultTabFolder.java:87) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012) at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770) at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3242) at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:2017) at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:320) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422) at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2384) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348) at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at org.eclipse.equinox.launcher.Main.run(Main.java:1236) Caused by: java.lang.ClassNotFoundException: org.eclipse.ui.internal.navigator.resources.workbench.TabbedPropertySheetTitleProvider at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:483) at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:399) at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:387) at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:87) at java.lang.ClassLoader.loadClass(ClassLoader.java:252) at org.eclipse.osgi.framework.internal.core.BundleLoader.loadClass(BundleLoader.java:315) at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:227) at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1274) at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:160) ... 70 more !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2009-05-14 16:44:25.953 !MESSAGE Plug-in org.eclipse.datatools.connectivity.ui.dse was unable to load class org.eclipse.ui.internal.navigator.resources.workbench.TabbedPropertySheetTitleProvider. !STACK 0 .............................................. ................................................... ...............................la suite est lente
Marsh Posté le 04-08-2009 à 09:39:38
Bonjour; Documents and Settings/Administrateur/workspace/.metadata
c
!SESSION 2009-05-14 16:40:12.328 -----------------------------------------------
eclipse.buildId=M20090211-1700
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!STACK 1
... 70 more
!STACK 0
Bien cordialement
