probleme de fermeture JFrame
probleme de fermeture JFrame - Java - Programmation
Marsh Posté le 29-12-2012 à 18:27:14
le problème c'est que l'application ne se ferme plus et il s'affiche en noir
voilà le code source
import java.awt.Container;
import java.awt.Dimension;
import java.awt.GridLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.PrintWriter;
import java.net.ServerSocket;
import java.net.Socket;
import java.util.HashSet;
import java.util.Iterator;
import java.util.logging.Level;
import java.util.logging.Logger;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JLabel;
import javax.swing.JOptionPane;
import javax.swing.JPanel;
import javax.swing.JTextArea;
import javax.swing.JTextField;
import org.omg.PortableInterceptor.SYSTEM_EXCEPTION;
 class Serveur extends JFrame implements ActionListener {
    HashSet<String> names = new HashSet<String>();
    private static HashSet<PrintWriter> writers = new HashSet<PrintWriter>();
     private JPanel pan1, pan2,pan3;
    private JLabel port,nbMax ;
    private JTextField fport,fnbMax;
    private JButton ecouter ;
    ServerSocket serv ;
    Serveur() {
        setSize(460, 400);
        setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        setLocationRelativeTo(null);
        setLayout(new GridLayout(7, 1));
        pan1 = new JPanel();
        port = new JLabel("Port: " );
        port.setPreferredSize(new Dimension(70, 30));
        fport = new JTextField(15);
        nbMax = new JLabel("Nombre maximum de clients : " );
        nbMax.setPreferredSize(new Dimension(90, 30));
        fnbMax = new JTextField(15);
        pan1.add(port);
        pan1.add(fport);
        pan2 = new JPanel();
        pan2.add(nbMax);
        pan2.add(fnbMax);
        pan3 = new JPanel();
        ecouter = new JButton("Ecouter" );
        pan3.add(ecouter);
        Container c = getContentPane();
        c.add(pan1); c.add(pan2); c.add(pan3);
        ecouter.addActionListener(this);
    @Override
    public void actionPerformed(ActionEvent ae) {
        String cmd=(String)ae.getActionCommand();
        if(cmd.equals("Ecouter" ))
        {int I1=Integer.parseInt(fport.getText());
         int I2= Integer.parseInt(fnbMax.getText());
  try{
    serv = new ServerSocket(I1);
  while(true){
    ClientHandler w;
//server.accept returns a client connection
        Socket soc=serv.accept();
        PrintWriter writer = new PrintWriter(soc.getOutputStream());
 writers.add(writer);
      w = new ClientHandler(soc,writer);
      Thread t = new Thread(w);
      t.start();
    }} catch (IOException e) {
  finally {
                try {
                    serv.close();
                } catch (IOException ex) {
    public class ClientHandler implements Runnable {
  BufferedReader reader;
  Socket sock;
                PrintWriter client;
  public ClientHandler(Socket clientSocket, PrintWriter user) {
  // new inputStreamReader and then add it to a BufferedReader
                        client = user;
   try {
    sock = clientSocket;
    InputStreamReader isReader = new InputStreamReader(sock.getInputStream());
    reader = new BufferedReader(isReader);
   } // end try
   catch (Exception ex) {
    System.out.println("error beginning StreamReader" );
   } // end catch
  } // end ClientHandler()
  public void run() {
                        String message;
   String[] data;
                        String connect = "Connect";
                        String disconnect = "Disconnect";
                        String chat = "Chat";
   try {
    while ((message = reader.readLine()) != null) {
     System.out.println("Received: " + message);
     data = message.split("¥" );
                                        for (String token:data) {
                                        System.out.println(token);
                                        if (data[2].equals(connect)) {
                                                tellEveryone((data[0] + "¥" + data[1] + "¥" + chat));
                                                userAdd(data[0]);
     } else if (data[2].equals(disconnect)) {
                                            tellEveryone((data[0] + "¥has disconnected." + "¥" + chat));
                                            userRemove(data[0]);
     } else if (data[2].equals(chat)) {
                                            tellEveryone(message);
     } else {
                                            System.out.println("No Conditions were met." );
        } // end while
   } // end try
    System.out.println("lost a connection" );
                                writers.remove(client);
   } // end catch
  } // end run()
 } // end class ClientHandler
    public void userAdd (String data) {
                String message;
                String add = "¥ ¥Connect", done = "Server¥ ¥Done";
                names.add(data);
                String[] tempList = new String[(names.size())];
  names.toArray(tempList);
                for (String token:tempList) {
                    message = (token + add);
                tellEveryone(done);
 public void userRemove (String data) {
                String message;
                names.remove(data);
                tellEveryone(done);
        public void tellEveryone(String message) {
 // sends message to everyone connected to server
  Iterator it = writers.iterator();
  while (it.hasNext()) {
   try {
    PrintWriter writer = (PrintWriter) it.next();
    writer.println(message);
    System.out.println("Sending" + message);
                                writer.flush();
   } // end try
    System.out.println("error telling everyone" );
   } // end catch
  } // end while
 } // end tellEveryone()
public class Main {
  * @param args
 public static void main(String[] args) {
  // TODO Auto-generated method stub
   Serveur serv =new Serveur();
         serv. setVisible(true);
s'il y a qq1 qui peut m'éclairer ?
  Merci d'avance!
