problème avec tomcat - Java - Programmation
Marsh Posté le 29-04-2003 à 18:20:42
yanis97 a écrit : Bonjour; |
va dans la ligne 239 de warp.c
et tu la supprimes
dis pas merci
Marsh Posté le 29-04-2003 à 21:37:33
ReplyMarsh Posté le 29-04-2003 à 22:47:35
tu vas en faire combien des topics dit pour ton pb de tomcat?
Marsh Posté le 30-04-2003 à 09:55:35
Bonjour;
Mon fichier server.xml :
<Server port="8005" shutdown="SHUTDOWN" debug="0">
<!-- A "Service" is a collection of one or more "Connectors" that share
a single "Container" (and therefore the web applications visible
within that Container). Normally, that Container is an "Engine",
but this is not required.
Note: A "Service" is not itself a "Container", so you may not
define subcomponents such as "Valves" or "Loggers" at this level.
<!-- The MOD_WEBAPP connector is used to connect Apache 1.3 with Tomcat 4.0
as its servlet container. Please read the README.txt file coming with
the WebApp Module distribution on how to build it.
(Or check out the "jakarta-tomcat-connectors/webapp" CVS repository)
To configure the Apache side, you must ensure that you have the
"ServerName" and "Port" directives defined in "httpd.conf". Then,
lines like these to the bottom of your "httpd.conf" file:
LoadModule webapp_module libexec/mod_webapp.so
WebAppConnection warpConnection warp localhost:8008
WebAppDeploy examples warpConnection /examples/
The next time you restart Apache (after restarting Tomcat, if needed)
the connection will be established, and all applications you make
visible via "WebAppDeploy" directives can be accessed through Apache.
<!-- Define an Apache-Connector Service -->
<Service name="Tomcat-Apache">
<Connector className="org.apache.catalina.connector.warp.WarpConnector"
port="8008" minProcessors="5" maxProcessors="75"
enableLookups="true" appBase="webapps"
acceptCount="10" debug="0"/>
<Engine className="org.apache.catalina.connector.warp.WarpEngine"
name="stldev" debug="0">
<Logger className="org.apache.catalina.logger.FileLogger"
prefix="apache_log." suffix=".txt"
timestamp="true"/>
<Realm className="org.apache.catalina.realm.MemoryRealm" />
</Engine>
</Service>
</Server>
Si vous avez un fichier server.xml bcq plus complet et qui marche, je suis prennant.
Merci;
Marsh Posté le 29-04-2003 à 18:13:06
Bonjour;
Quelqu'un pourra m'aider à comprendre (la cause) pourquoi j'ai le msg suivant lorsque je me connecte à mon application web.
Les messages suivant s'affichent lors de tentative de connexion. WebApp: Error 500 File: pr_warp.c Line: 239) Cannot open connection warpConnection
Merci;
