HELP ME : Pb d'affichage applet - Java - Programmation
Marsh Posté le 13-07-2006 à 09:28:34
http://www.google.com/search?num=1 [...] tnG=Search
| Citation : This can occur when the JDK version that you have does not match or it is older than the JDK version that the project has been developed on. Try traversing trough the imports within the class and check wheather they have some significant differences. |
et puis les caps, tout ça tout ça... on se doute bien que tu as besoin d'aide
Marsh Posté le 13-07-2006 à 09:22:44
Mon applet ne veut plus fonctionner, voici le msg renvoyé par la console java :
>java.lang.ClassFormatError: Illegal UTF8 string in constant pool in class file KawaTree
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClass(Unknown Source)
> at java.security.SecureClassLoader.defineClass(Unknown Source)
> at sun.applet.AppletClassLoader.findClass(Unknown Source)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at sun.applet.AppletClassLoader.loadClass(Unknown Source)
> at sun.applet.AppletClassLoader.loadCode(Unknown Source)
> at sun.applet.AppletPanel.createApplet(Unknown Source)
> at sun.plugin.AppletViewer.createApplet(Unknown Source)
> at sun.applet.AppletPanel.runLoader(Unknown Source)
> at sun.applet.AppletPanel.run(Unknown Source)
> at java.lang.Thread.run(Unknown Source)
Pouvez-vous m'aider ? Merci merci
