erreur execution, compilation
erreur execution, compilation - Java - Programmation
Marsh Posté le 08-07-2011 à 16:10:50
Je fais un script junit qui lance des test à partir de jar .class, il ne fais pas la compilation. J'ai vérifié qu'il y a tous les packages.
<target name="test">
        <mkdir dir="C:/reports" />
        <junit>
            <classpath>
                <fileset dir="${project.dir.lib.jdevelopper}">
                    <include name="*.jar" />
                </fileset>
                <fileset dir="${project.dir.lib.jdevelopper.ejb}">
                </fileset>
                <fileset dir="${project.dir.lib.shared}">
                </fileset>
                <fileset dir="${project.dir.lib.common}">
                </fileset>
                <fileset dir="${project.dir.lib.common.lib}">
                </fileset>
                <pathelement path="${project.dir.class}" />
            </classpath>
            <formatter type="brief" usefile="false" />
            <formatter type="xml"/>
            <batchtest  todir="C:/reports">
                <fileset  dir="${project.dir.class}"  includes="**/*Test*.class" excludes="**/${project.dir.class.exclude}.*" />
            </batchtest>
        </junit>
    </target>
Testcase: testCalculateNeed(com.fluide.procurement.processes.need.CalculateNeedBeanTest): Caused an ERROR
    [junit] Cannot subclass final class class com.fluide.common.util.DateUtil
    [junit] java.lang.IllegalArgumentException: Cannot subclass final class class com.fluide.common.util.DateUtil
    [junit]  at org.mockito.cglib.proxy.Enhancer.generateClass(Enhancer.java:447)
    [junit]  at org.mockito.cglib.core.DefaultGeneratorStrategy.generate(DefaultGeneratorStrategy.java:25)
    [junit]  at org.mockito.cglib.core.AbstractClassGenerator.create(AbstractClassGenerator.java:217)
    [junit]  at org.mockito.cglib.proxy.Enhancer.createHelper(Enhancer.java:378)
    [junit]  at org.mockito.cglib.proxy.Enhancer.createClass(Enhancer.java:318)
    [junit]  at org.mockito.internal.creation.jmock.ClassImposterizer.createProxyClass(ClassImposterizer.java:93)
    [junit]  at org.mockito.internal.creation.jmock.ClassImposterizer.imposterise(ClassImposterizer.java:50)
    [junit]  at org.powermock.api.mockito.internal.mockcreation.MockCreator.createMethodInvocationControl(MockCreator.java:100)
    [junit]  at org.powermock.api.mockito.internal.mockcreation.MockCreator.mock(MockCreator.java:58)
    [junit]  at org.powermock.api.mockito.PowerMockito.spy(PowerMockito.java:229)
Si je lance avec un run sous jdevelopper j'ai pas ce problème. NB Les class PowerMockito génére des class à l'exécution.
