probleme curseur main [RESOLU] - HTML/CSS - Programmation
Marsh Posté le 13-02-2006 à 11:26:22
bonjour, voila sous I.E.(Internet explorer), quand je passe sur un de mes lien de mon site, le curseur se change en main,mais avec firefox ca ne change pas voila le css
<style type="text/css"> .dynamic-tab-pane-control.tab-pane { position: relative; width: 100%; } .dynamic-tab-pane-control .tab-row .tab { font: Menu; cursor: Default; display: inline; margin: 1px -2px 1px 2px; float: left; padding: 2px 5px 3px 5px; background: #FFFFFF; border: 1px solid; border-color: ThreeDHighlight ThreeDDarkShadow ThreeDDarkShadow ThreeDHighlight; border-bottom: 0; z-index: 1; position: relative; top: 0; } .dynamic-tab-pane-control .tab-row .tab.selected { border-bottom: 0; z-index: 3; padding: 2px 6px 5px 7px; margin: 1px -3px -2px 0px; top: -2px; } .dynamic-tab-pane-control .tab-row .tab a { font: Menu; color: WindowText; text-decoration: none; cursor: default; } .dynamic-tab-pane-control .tab-row .hover a { color: blue; } .dynamic-tab-pane-control .tab-page { clear: both; border: 1px solid; border-color: ThreeDHighlight ThreeDDarkShadow ThreeDDarkShadow ThreeDHighlight; background: #FFFFFF; z-index: 2; position: relative; top: -2px; color: WindowText; font: Message-Box; padding: 10px; } .dynamic-tab-pane-control .tab-row { z-index: 1; white-space: nowrap; } .dynamic-tab-pane-control .tab-page { height: 200px; } .dynamic-tab-pane-control .tab-page .dynamic-tab-pane-control .tab-page { height: 100px; } html{ font: 11px arial } table{ font: 11px arial } checkbox,radio { background: #FFFFFF; font: 11px arial } textarea, select, button, submit, input { background: white; font: 11px arial } form { margin: 0; padding: 0; } body { background: #FFFFFF; text:#000000 link:"#000000" vlink:"#000000" alink:"#000000" margin: 2px; width: auto; height: auto; scrollbar-base-color: #FFFFFF; scrollbar-track-color: #FFFFFF; font: 11px arial } .curseur { cursor: hand; } </style>
ou meme si je l'inclus dans un case d'un tableau
<tr style="cursor:hand">
rien ne se passe, j'ai regarde sous M.F, la consolle javascript il me dit une erreur que je comprends pas
Erreur : Erreur d'analyse de la valeur pour la propriété « cursor ». Déclaration abandonnée. Fichier source : http://localhost/Myrmica/Myrmica_meca//default.php Ligne : 0
Marsh Posté le 13-02-2006 à 11:34:02
Marsh Posté le 13-02-2006 à 11:38:08
super ca marche merci, j_lecruel
Marsh Posté le 13-02-2006 à 11:39:35
la valeur "hand" n'est pas standard. Tu peux te référer à cette page pour avoir celles possibles.
voila le css
position: relative;
width: 100%;
font: Menu;
cursor: Default;
display: inline;
float: left;
border: 1px solid;
border-bottom: 0;
z-index: 1;
position: relative;
top: 0;
border-bottom: 0;
z-index: 3;
top: -2px;
font: Menu;
color: WindowText;
cursor: default;
color: blue;
clear: both;
border: 1px solid;
z-index: 2;
position: relative;
top: -2px;
color: WindowText;
font: Message-Box;
padding: 10px;
z-index: 1;
height: 200px;
height: 100px;
html{
font: 11px arial
table{
font: 11px arial
checkbox,radio {
font: 11px arial
background: white;
font: 11px arial
form {
margin: 0;
padding: 0;
body {
text:#000000
link:"#000000"
vlink:"#000000"
alink:"#000000"
margin: 2px;
width: auto;
height: auto;
font: 11px arial
.curseur {
cursor: hand;
</style>
Ligne : 0
Message édité par infoman64 le 13-02-2006 à 11:38:49
