Pourquoi ce code déforme ma page ?
Pourquoi ce code déforme ma page ? - HTML/CSS - Programmation
Marsh Posté le 01-11-2002 à 00:20:57
Voila ce code :
<div align="center"><form method=post action="http://www.votations.com/asp/vote.asp">
  <table border=0 BORDERCOLOR=#000066 cellPadding=0 cellSpacing=0 width=150>
    <input type=hidden name="pollid" value="65931"><tr><td BACKGROUND=""></tr><TABLE border=0 cellPadding=0><tr><td colspan=2>
              <div align="center"><font color=#000000 face=arial size=1><b>Vous
                attendez ?<br>
                <br>
                </b></font></div>
            </td></tr><tr><td valign=top><INPUT name=vote type=radio value="674933"></td><td valign=top width="99%"><FONT face=arial color=#000000 size=1>Zelda</td></font></tr>
<br><tr><td valign=top><INPUT name=vote type=radio value="674934"></td><td valign=top width="99%"><FONT face=arial color=#000000 size=1>Final Fantasy CC</td></tr>
<tr><td valign=top><INPUT name=vote type=radio value="674935"></td><td valign=top width="99%"><FONT face=arial color=#000000 size=1>1080° Avalanche</td></tr>
<tr><td valign=top><INPUT name=vote type=radio value="674936"></td><td valign=top width="99%"><FONT face=arial color=#000000 size=1>F-Zero</td></tr>
<tr><td valign=top><INPUT name=vote type=radio value="674937"></td><td valign=top width="99%"><FONT face=arial color=#000000 size=1>Wario World</td></tr>
<tr><td valign=top><INPUT name=vote type=radio value="674938"></td><td valign=top width="99%"><FONT face=arial color=#000000 size=1>Autre</td></tr>
</TABLE><br><tr><td  align=center>
          <input type=submit name=voteon  value="Voter">
          <br>
          <font face=verdana><small><a href="http://www.votations.com/asp/resultsview.asp?pollid=65931&lang=fr"><font color=#00000><font size="1">Résultats</font></a></small></font></div>
      </td>
    </tr></table><input type=hidden name=lang value=fr></form></div>
</table>
Ce code est placé dans une inclusion .inc et voila comment il déforme la page
http://www.cube-fr.com/pagetest.php
Marsh Posté le 01-11-2002 à 14:31:04
uuuuuuuuup
Marsh Posté le 01-11-2002 à 23:48:12
le dernier </table> est de trop...
aussi, quand tu ouvres une balise <font>, pense à la refermer!! </font>
Another .Net Blog
Marsh Posté le 02-11-2002 à 02:48:55
Un conseil si tu commence à développer, pense à indenter ton code afin qu'il soit plus lisible...surtout pour nous... :-)
Par ailleurs ton code n'est pas du tout valide (absence de </td>, et </font>...) Va faire un tour du coté du site du W3C pour faire valider ton code:
http://validator.w3.org/
@ + : Rem'
Marsh Posté le 02-11-2002 à 10:25:53
c pas mon code hein c un code géré automatiquement :/et ils sont aps capable de te donner un bon code
Marsh Posté le 02-11-2002 à 10:56:28
bah il veut pas prendre le code sur le site....
je les mis sur cette page http://www.cube-fr.com/test.htm
mais il veut pas rechercher les erreurs
Marsh Posté le 02-11-2002 à 15:42:10
Pourtant il te donne la solution :sarcastic: :
  1. Fatal Error: no document type declaration; will parse without validation
  2. I could not parse this document, because it uses a public identifier that is not in my catalog.
  3. You should make the first line of your HTML document a DOCTYPE declaration, for example, for a typical HTML 4.01 document:
  4.       <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
  5.       <HTML>
  6. <HEAD>
  7.   <TITLE>Title</TITLE>
  8. </HEAD>
  9. <BODY>
  10.   <-- ... body of document ... -->
  11. </BODY>
  12.       </HTML>
Il faut que tu rajoutes la première ligne (en gras) avant ta balise <html>:
Et pour corriger les erreurs, il existe Tidy, sur le site du W3C, qui peut le faire si je me souviens bien...
Message édité par haazheel le 02-11-2002 à 15:43:02
Another .Net Blog
Marsh Posté le 02-11-2002 à 15:54:38
okay ils me filent les erreurs mais ca m'aide pas plus :/ ils filent pas une version corrigée ?
Marsh Posté le 02-11-2002 à 19:37:06
 :sarcastic:
Another .Net Blog
Marsh Posté le 02-11-2002 à 20:00:16
Et un cerveau aussi ? non ?
réfléchir et comprendre, c'est si chiant que ça ??
Marsh Posté le 03-11-2002 à 00:07:21
:sleep: dégage si c pour dire ca ton commentaire et vraiment inutile
Marsh Posté le 03-11-2002 à 00:15:13
Mais on t'a déjà aidé.
De plus, il n'existe pas de programme qui pond du code propre à l'heure actuelle. Et comprendre tes erreurs, c'est la seule solution. Sinon, ne cherches pas à valider tes pages, si c'est pour ne pas vouloir savoir quels sont les problèmes...  :sarcastic:
Marsh Posté le 03-11-2002 à 00:18:26
jai regardé les erreurs mais c pas cqu'ils indiquent qui déforme la page
Marsh Posté le 03-11-2002 à 00:55:40
Dans l'exemple que tu donnes, ya pas de déformation, puisqu'il n'y a pas toute la page. On peut pas se rendre compte... C'est dur de t'aider comme ça.
Pour ce qui est du W3C, dis-nous ce que tu ne comprends pas...
Marsh Posté le 03-11-2002 à 01:09:54
jvois pas koi dire de plus c une page .inc (ou jai mis le sondage) dont le menu vas a droite de la page (sur pagetest.htm)
