Mauvais affichage menu SPRY sous IE - HTML/CSS - Programmation
MarshPosté le 25-06-2010 à 09:24:35
Je suis entrain de fabriquer un site via Dreamweaver, et pour faire ma barre de menu j'ai utilisé l'outil SPRY mis à la disposition dans le logiciel. Le tout marche très bien sous firefox, mais je rencontre une problème d'affichage sous internet explorer que je n'arrive pas à résoudre :
FIREFOX
INTERNET EXPLORER
Voilà mon CSS générer par Dreamweaver "sprymenubarhorizontal.css"
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */ ul.MenuBarHorizontal { margin: 0; padding: 0; list-style-type: none; font-size: 100%; cursor: default; width: auto; letter-spacing: 0em; } /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */ ul.MenuBarActive { z-index: 1150; } /* Menu item containers, position children relative to this container and are a fixed width */ ul.MenuBarHorizontal li { margin: 0; padding: 0; list-style-type: none; font-size: 100%; position: relative; text-align: center; cursor: pointer; width: 7.5em; float: left; font-weight: normal; border: 0px solid #999; visibility: inherit; } /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */ ul.MenuBarHorizontal ul { margin: 0; padding: 0; list-style-type: none; font-size: 100%; z-index: 1150; cursor: default; width: 7.5em; position: absolute; left: -1000em; } /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */ ul.MenuBarHorizontal ul.MenuBarSubmenuVisible { left: 0px; } /* Menu item containers are same fixed width as parent */ ul.MenuBarHorizontal ul li { width: 10em; } /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */ ul.MenuBarHorizontal ul ul { position: absolute; margin: -3% 0 0 97%; } /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */ ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible { left: auto; top: 0; }
/* Submenu containers have borders on all sides */ ul.MenuBarHorizontal ul { border: 1px solid #CCC; } /* Menu items are a light gray block with padding and no text decoration */ ul.MenuBarHorizontal a { display: block; cursor: pointer; background-color: #E8E8E8; padding: 0.5em 0.1em; color: #F90; text-decoration: none; font-weight: normal; font-family: Calibri, "Segoe UI", Verdana, Arial; font-style: normal; font-size: 20px; } /* Menu items that have mouse over or focus have a blue background and white text */ ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus { background-color: #ff6000; color: #000; white-space: 0; word-spacing: 0em; } /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */ ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible { background-color: #ff6000; color: #FFF; }
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */ ul.MenuBarHorizontal a.MenuBarItemSubmenu { background-image: url(SpryMenuBarDown.gif); background-repeat: no-repeat; background-position: 95% 50%; border-top-color: #333; border-right-color: #333; border-bottom-color: #333; border-left-color: #333; } /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */ ul.MenuBarHorizontal ul a.MenuBarItemSubmenu { background-image: url(SpryMenuBarRight.gif); background-repeat: no-repeat; background-position: 95% 50%; } /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */ ul.MenuBarHorizontal a.MenuBarItemSubmenuHover { background-image: url(SpryMenuBarDownHover.gif); background-repeat: no-repeat; background-position: 95% 50%; } /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */ ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover { background-image: url(SpryMenuBarRightHover.gif); background-repeat: no-repeat; background-position: 95% 50%; }
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */ ul.MenuBarHorizontal iframe { position: absolute; z-index: 1000; filter:alpha(opacity:0.1); } /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */ @media screen, projection { ul.MenuBarHorizontal li.MenuBarItemIE { display: inline; f\loat: left; } }
Marsh Posté le 25-06-2010 à 09:24:35
FIREFOX
INTERNET EXPLORER
Merci d'avance
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
margin: 0;
padding: 0;
font-size: 100%;
cursor: default;
width: auto;
ul.MenuBarActive
z-index: 1150;
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: center;
cursor: pointer;
width: 7.5em;
float: left;
margin: 0;
padding: 0;
font-size: 100%;
z-index: 1150;
cursor: default;
width: 7.5em;
position: absolute;
left: -1000em;
left: 0px;
width: 10em;
position: absolute;
left: auto;
top: 0;
DESIGN INFORMATION: describes color scheme, borders, fonts
display: block;
cursor: pointer;
color: #F90;
font-style: normal;
font-size: 20px;
color: #000;
white-space: 0;
word-spacing: 0em;
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
BROWSER HACKS: the hacks below should not be changed unless you are an expert
position: absolute;
z-index: 1000;
display: inline;
f\loat: left;
