var tim = 0 var noScroll = true function mLeft() { if (!noScroll && oMenu.x<sArrowwidth) { oMenu.moveBy(sScrollPx,0) tim = setTimeout("mLeft()",sScrollspeed) } } function mRight() { if (!noScroll && oMenu.x>-(oMenu.scrollWidth-(pageWidth))-sArrowwidth) { oMenu.moveBy(-sScrollPx,0) tim = setTimeout("mRight()",sScrollspeed) } } function noMove() { clearTimeout(tim); noScroll = true; sScrollPx = sScrollPxOriginal; }
function makeObj(obj,nest,menu) { nest = (!nest) ? "":'document.'+nest+'.'; this.elm = bw.ns4?eval(nest+"document.layers." +obj):bw.ie4?document.all[obj]:document.getElementById(obj); this.css = bw.ns4?this.elm:this.elm.style; this.scrollWidth = bw.ns4?this.css.document.width:this.elm.offsetWidth; this.x = bw.ns4?this.css.left:this.elm.offsetLeft; this.y = bw.ns4?this.css.top:this.elm.offsetTop; this.moveBy = b_moveBy; this.moveIt = b_moveIt; this.clipTo = b_clipTo; return this; } var px = bw.ns4||window.opera?"":"px"; function b_moveIt(x,y) { if (x!=null){this.x=x; this.css.left=this.x+px;} if (y!=null){this.y=y; this.css.top=this.y+px;} } function b_moveBy(x,y) {this.x=this.x+x; this.y=this.y+y; this.css.left=this.x+px; this.css.top=this.y+px;} function b_clipTo(t,r,b,l){ if(bw.ns4){this.css.clip.top=t; this.css.clip.right=r; this.css.clip.bottom=b; this.css.clip.left=l;} else this.css.clip="rect("+t+"px "+r+"px "+b+"px "+l+"px)"; }
var sScrollPxOriginal = sScrollPx; function sideInit() { //largeur du menu, généralement = largeur de la page. Sinon pageWidth=largeur désirée //pageWidth = (bw.ns4 || bw.ns6 || window.opera)?innerWidth:document.body.clientWidth; pageWidth=335;
oBg = new makeObj('divBg') oMenu = new makeObj('divMenu','divBg',1) oArrowRight = new makeObj('divArrowRight','divBg')
Marsh Posté le 30-06-2004 à 16:12:44
salut à tous !!!
![:bounce: :bounce:](https://forum-images.hardware.fr/icones/smilies/bounce.gif)
Bon ba en fait tout est dit, g un JAVASCRIPT qui marche très bien sous IE mais qui ne fonctionne pas sous NETSCAPE et le reste.
voici l'adresse du site
http://www.eurosmart.fr
Bref je ne comprends pas d'ou ca vient.
voici le code :
<script language="JavaScript" type="text/javascript">
/* Made by <a href="/dhtmlcentral/thomas_brattli.asp">Thomas Brattli</a> and modified by Michael van Ouwerkerk */
function lib_bwcheck() {
this.ver=navigator.appVersion
this.agent=navigator.userAgent
this.dom=document.getElementById?1:0
this.opera5=this.agent.indexOf("Opera 5" )>-1
this.ie5=(this.ver.indexOf("MSIE 5" )>-1 && this.dom && !this.opera5)?1:0;
this.ie6=(this.ver.indexOf("MSIE 6" )>-1 && this.dom && !this.opera5)?1:0;
this.ie4=(document.all && !this.dom && !this.opera5)?1:0;
this.ie=this.ie4||this.ie5||this.ie6
this.mac=this.agent.indexOf("Mac" )>-1
this.ns6=(this.dom && parseInt(this.ver) >= 5) ?1:0;
this.ns4=(document.layers && !this.dom)?1:0;
this.bw=(this.ie6 || this.ie5 || this.ie4 || this.ns4 || this.ns6 || this.opera5)
return this
var bw=new lib_bwcheck()
sLeft = 0 //distance bord gauche
sTop = 0 //distance bord sup
sMenuheight = 90 //hauteur
sArrowwidth = 34 //largeur flèches
sScrollspeed = 150 //vitesse défilement
sScrollPx = 20 //px par unit temps
sScrollExtra = 20 //vitesse 2 onmousedown
var tim = 0
var noScroll = true
function mLeft() {
function mRight() {
function noMove() {
clearTimeout(tim);
noScroll = true;
return this;
pageWidth=335;
oBg.moveIt(sLeft,sTop)
oMenu.moveIt(sArrowwidth,null)
oArrowRight.css.width = sArrowwidth;
oArrowRight.moveIt(pageWidth-sArrowwidth,null)
if (!bw.ns4) oBg.css.overflow = "hidden";
if (bw.ns6) oMenu.css.position = "relative";
oBg.css.width = pageWidth+px;
oBg.clipTo(0,pageWidth,sMenuheight,0)
oBg.css.visibility = "visible";
if (bw.bw) onload = sideInit;
function cacheBulle() {
infobulle.style.visibility="hidden";
function infoBulle(texte) {
if (document.all) {
infobulle.innerHTML='<b><font size=2 color=#ffffff style=Arial, Verdana, sans-serif>'+texte+'</font></b>';
infobulle.style.visibility="visible";
if (document.layers) {
document.layers["infobulle"].document.open();
document.layers["infobulle"].document.write(texte);
document.layers["infobulle"].document.close();
</script>
et ensuite un pu plus loin g ça
<SCRIPT LANGUAGE="Javascript">
function styleCalque_<?php echo $produit; ?>(idCalque) {
if (document.all) calqueStyle = document.all[idCalque].style;
if (document.layers) calqueStyle = document.layers[idCalque];
if (document.getElementById)
calqueStyle = document.getElementById(idCalque).style;
return calqueStyle;
function deplaceCalque_<?php echo $produit; ?>(idCalque,posX,posY) {
calqueStyle_<?php echo $produit; ?> = styleCalque_<?php echo $produit; ?>(idCalque);
calqueStyle_<?php echo $produit; ?>.left = posX;
calqueStyle_<?php echo $produit; ?>.top = posY;
function cacheBulle_<?php echo $produit; ?>() {
styleCalque_<?php echo $produit; ?>("infobulle_<?php echo $produit; ?>" ).visibility = "hidden";
function infoBulle_<?php echo $produit; ?>(e,texte,classe) {
if (document.all) deplaceCalque_<?php echo $produit; ?>('infobulle_<?php echo $produit; ?>',event.x,event.y);
if ((document.layers) || ((document.getElementById) && (!document.all)))
deplaceCalque_<?php echo $produit; ?>('infobulle_<?php echo $produit; ?>',e.pageX,e.pageY);
base = "<TABLE><TR><TD CLASS='" + classe + "'>";
fin = "</TD></TR></TABLE>";
if (document.all) infobulle_<?php echo $produit; ?>.innerHTML = base + texte + fin;
document.layers["infobulle_<?php echo $produit; ?>"].document.open();
document.layers["infobulle_<?php echo $produit; ?>"].document.write(base + texte + fin);
document.layers["infobulle_<?php echo $produit; ?>"].document.close();
if (document.getElementById) document.getElementById("infobulle_<?php echo $produit; ?>" ).innerHTML = base + texte + fin;
styleCalque_<?php echo $produit; ?>("infobulle_<?php echo $produit; ?>" ).visibility = "visible";
</SCRIPT>
alors sous IE c nikel et sous netscape ca ce casse la gueule.
Comprends pas pouvez vous m'aider SVP
MERCI d'avanace TOM-TOM
Message édité par tomatogo le 30-06-2004 à 16:13:50
