help in javascript - HTML/CSS - Programmation
Marsh Posté le 11-05-2013 à 23:41:59
C'est déjà commenté...
Mais rassure toi, ta participation sur ce forum et la pertinence de ta question va attiré ton sauveur
Marsh Posté le 12-05-2013 à 03:24:33
Iz az cookies to the swimming pool.
Marsh Posté le 12-05-2013 à 20:45:20
yes, perheps i do , deserve to die but i also deserve a chance
so i'll take my chance if you can help me that will be great
please
i see that its not shame to ask for help
Marsh Posté le 12-05-2013 à 20:54:15
I think you can ask on the board : http://www.stackoverflow.com
You are on a french board here
Marsh Posté le 12-05-2013 à 21:49:23
ok thanks,
meme si possible de m'expliquer en  français
pas de probleme
Marsh Posté le 11-05-2013 à 18:40:17
var featuredcontentglider={
csszindex: 100,
ajaxloadingmsg: '<b>Fetching Content. Please wait...</b>',
glide:function(config, showpage, isprev){
var selected=parseInt(showpage)
if (selected>=config.$contentdivs.length){ //if no content exists at this index position
alert("No content exists at page "+(selected+1)+"! Loading 1st page instead." )
selected=0
var $target=config.$contentdivs.eq(selected)
//Test for toggler not being initialized yet, or user clicks on the currently selected page):
if (config.$togglerdiv.attr('lastselected')==null || parseInt(config.$togglerdiv.attr('lastselected'))!=selected){
var $selectedlink=config.$toc.eq(selected)
config.$next.attr('loadpage', (selected<config.$contentdivs.length-1)? selected+1+'pg' : 0+'pg')
config.$prev.attr('loadpage', (selected==0)? config.$contentdivs.length-1+'pg' : selected-1+'pg')
var startpoint=(isprev=="previous" )? -config.startpoint : config.startpoint
$target.css(config.leftortop, startpoint).css("zIndex", this.csszindex++) //hide content so it's just out of view before animating it
var endpoint=(config.leftortop=="left" )? {left:0} : {top:0} //animate it into view
$target.animate(endpoint, config.speed)
config.$toc.removeClass('selected')
$selectedlink.addClass('selected')
config.$togglerdiv.attr('lastselected', selected+'pg')
getremotecontent:function(config){
config.$glider.html(this.ajaxloadingmsg)
$.ajax({
url: config.remotecontent,
error:function(ajaxrequest){
config.$glider.html('Error fetching content.<br />Server Response: '+ajaxrequest.responseText)
success:function(content){
config.$glider.html(content)
featuredcontentglider.setuptoggler(config)
aligncontents:function(config){
config.$contentdivs=$("#"+config.gliderid+" ."+config.contentclass)
config.$contentdivs.css(config.leftortop, config.startpoint).css({height: config.$glider.height(), visibility: 'visible'}) //position content divs so they're out of view:
setuptoggler:function(config){
this.aligncontents(config)
config.$togglerdiv.hide()
config.$toc.each(function(index){
$(this).attr('pagenumber', index+'pg')
if (index > (config.$contentdivs.length-1))
$(this).css({display: 'none'}) //hide redundant "toc" links
var $nextandprev=$("#"+config.togglerid+" .next, #"+config.togglerid+" .prev" )
$nextandprev.click(function(event){ //Assign click behavior to 'next' and 'prev' links
featuredcontentglider.glide(config, this.getAttribute('loadpage'), this.getAttribute('buttontype'))
event.preventDefault() //cancel default link action
config.$toc.click(function(event){ //Assign click behavior to 'toc' links
featuredcontentglider.glide(config, this.getAttribute('pagenumber'))
config.$togglerdiv.fadeIn(1000, function(){
featuredcontentglider.glide(config, config.selected)
if (config.autorotate==true){ //auto rotate contents?
config.stepcount=0 //set steps taken
config.totalsteps=config.$contentdivs.length*config.autorotateconfig[1] //Total steps limit: num of contents x num of user specified cycles)
featuredcontentglider.autorotate(config)
config.$togglerdiv.click(function(){
featuredcontentglider.cancelautorotate(config.togglerid)
autorotate:function(config){
var rotatespeed=config.speed+config.autorotateconfig[0]
window[config.togglerid+"timer"]=setInterval(function(){
if (config.totalsteps>0 && config.stepcount>=config.totalsteps){
clearInterval(window[config.togglerid+"timer"])
else{
config.$next.click()
config.stepcount++
}, rotatespeed)
cancelautorotate:function(togglerid){
if (window[togglerid+"timer"])
clearInterval(window[togglerid+"timer"])
getCookie:function(Name){
var re=new RegExp(Name+"=[^;]+", "i" ) //construct RE to search for target name/value pair
if (document.cookie.match(re)) //if cookie found
return document.cookie.match(re)[0].split("=" )[1] //return its value
return null
setCookie:function(name, value){
document.cookie = name+"="+value
init:function(config){
$(document).ready(function(){
config.$glider=$("#"+config.gliderid)
config.$togglerdiv=$("#"+config.togglerid)
config.$toc=config.$togglerdiv.find('.toc')
config.$next=config.$togglerdiv.find('.next')
config.$prev=config.$togglerdiv.find('.prev')
config.$prev.attr('buttontype', 'previous')
var selected=(config.persiststate)? featuredcontentglider.getCookie(config.gliderid) : config.selected
config.selected=(isNaN(parseInt(selected))) ? config.selected : selected //test for cookie value containing null (1st page load) or "undefined" string
config.leftortop=(/up/i.test(config.direction))? "top" : "left" //set which CSS property to manipulate based on "direction"
config.heightorwidth=(/up/i.test(config.direction))? config.$glider.height() : config.$glider.width() //Get glider height or width based on "direction"
config.startpoint=(/^(left|up)/i.test(config.direction))? -config.heightorwidth : config.heightorwidth //set initial position of contents based on "direction"
if (typeof config.remotecontent!="undefined" && config.remotecontent.length>0)
featuredcontentglider.getremotecontent(config)
else
$(window).bind('unload', function(){ //clean up and persist
config.$togglerdiv.unbind('click')
config.$toc.unbind('click')
config.$next.unbind('click')
config.$prev.unbind('click')
if (config.persiststate)
featuredcontentglider.setCookie(config.gliderid, config.$togglerdiv.attr('lastselected'))
config=null
help me understand this code plz
