Comment en ligne de commande cvs tagger et détagger des versions de fichiers différentes de la version courante HEAD?
$ cvs -H tag Usage: cvs tag [-bcdFflR] [-r rev|-D date] tag [files...] -b Make the tag a "branch" tag, allowing concurrent development. -B Allows -F and -d to disturb branch tags. Use with extreme care. -c Check that working files are unmodified. -d Delete the given tag. -F Move tag if it already exists. -f Force a head revision match if tag/date not found. -l Local directory only, not recursive. -R Process directories recursively. -r rev Existing revision/tag. -D Existing date. (Specify the --help global option for a list of other help options)
Marsh Posté le 04-12-2009 à 16:34:44
