Vous avez des exemples de makefile pour voir ? (quiche inside) - C++ - Programmation
Marsh Posté le 24-01-2003 à 16:35:06
http://cvs.sourceforge.net/cgi-bin [...] cvs-markup
note: automake c'est mieux, mais j'ai jamais pris la peine d'apprendre a m'en servir
Marsh Posté le 24-01-2003 à 16:37:52
| lorill a écrit : note: automake c'est mieux, mais j'ai jamais pris la peine d'apprendre a m'en servir  |
+1
lui et son acolyte autoconf me semblent assez imbuvables
Marsh Posté le 24-01-2003 à 16:46:17
# Makefile.in generated automatically by automake 1.5 from Makefile.am.
# Copyright 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001
# Free Software Foundation, Inc.
# This Makefile.in is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
# PARTICULAR PURPOSE.
# Some rules for building asm files:
SHELL = /bin/sh
srcdir = .
top_srcdir = ../..
prefix = /local
exec_prefix = ${prefix}
bindir = ${exec_prefix}/bin
sbindir = ${exec_prefix}/sbin
libexecdir = ${exec_prefix}/libexec
datadir = ${prefix}/share
sysconfdir = ${prefix}/etc
sharedstatedir = ${prefix}/com
localstatedir = ${prefix}/var
libdir = ${exec_prefix}/lib
infodir = ${prefix}/info
mandir = ${prefix}/man
includedir = ${prefix}/include
oldincludedir = /usr/include
pkgdatadir = $(datadir)/mpeg4ip
pkglibdir = $(libdir)/mpeg4ip
pkgincludedir = $(includedir)/mpeg4ip
top_builddir = ../..
ACLOCAL = aclocal
AUTOCONF = autoconf
AUTOMAKE = automake
AUTOHEADER = autoheader
INSTALL = /usr/bin/install -c
INSTALL_PROGRAM = ${INSTALL}
INSTALL_DATA = ${INSTALL} -m 644
INSTALL_SCRIPT = ${INSTALL}
INSTALL_HEADER = $(INSTALL_DATA)
transform = s,x,x,
NORMAL_INSTALL = :
PRE_INSTALL = :
POST_INSTALL = :
NORMAL_UNINSTALL = :
PRE_UNINSTALL = :
POST_UNINSTALL = :
host_alias = i686-pc-linux-gnu
host_triplet = i686-pc-linux-gnu
AMTAR = tar
AS = gcc
ASFLAGS =
AWK = gawk
BILLS_CPPWARNINGS = -Wall -Wmissing-prototypes -Wmissing-declarations -Wno-char-subscripts -Woverloaded-virtual -Wno-unknown-pragmas -Wno-deprecated
BILLS_CWARNINGS = -Wall -Wmissing-prototypes -Wmissing-declarations -Wno-char-subscripts -Wno-unknown-pragmas
CC = gcc
CCAS = gcc
CCASFLAGS =
CFLAGS = -g -O2 -DUSE_MMX -DMPEG4IP
CXX = c++
CXXFLAGS = -g -O2 -DUSE_MMX -DMPEG4IP
DEPDIR = .deps
DLLTOOL = @DLLTOOL@
ECHO = echo
EXEEXT =
GLIB_CFLAGS = -I/usr/include/glib-1.2 -I/usr/lib/glib/include
GLIB_CONFIG = /usr/bin/glib-config
GLIB_LIBS = -L/usr/lib -lglib
GTK_CFLAGS = -I/usr/include/gtk-1.2 -I/usr/include/glib-1.2 -I/usr/lib/glib/include -I/usr/X11R6/include
GTK_CONFIG = /usr/bin/gtk-config
GTK_LIBS = -L/usr/lib -L/usr/X11R6/lib -lgtk -lgdk -rdynamic -lgmodule -lglib -ldl -lXi -lXext -lX11 -lm
INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s
LIBTOOL = $(SHELL) $(top_builddir)/libtool
LN_S = ln -s
NASM = /usr/bin/nasm
NASMFLAGS = -f elf
OBJC = ???
OBJDUMP = @OBJDUMP@
OBJEXT = o
PACKAGE = mpeg4ip
PLAYER_PLUGIN_DIR = ${exec_prefix}/lib/mp4player_plugin
RANLIB = ranlib
SDL_LIBS = $(top_builddir)/lib/SDL/src/libSDL.la -lpthread
STRIP = strip
USENASM = true
VERSION = 0.9.6
X_CFLAGS =  -I/usr/X11R6/include
X_EXTRA_LIBS =
X_LIBS =  -L/usr/X11R6/lib
X_PRE_LIBS =  -lSM -lICE
am__include = include
am__quote =
install_sh = /udd/bdeniaud/archivage/mpeg4ip2/install-sh
STRIP_FPIC = sh $(top_srcdir)/strip_fPIC.sh
SUFFIXES = .asm
...etc...
install \
 install-am install-binPROGRAMS install-data install-data-am \
 install-data-recursive install-exec install-exec-am \
 install-exec-recursive install-info install-info-am \
 install-info-recursive install-man install-recursive \
 install-strip installcheck installcheck-am installdirs \
 installdirs-am installdirs-recursive maintainer-clean \
 maintainer-clean-generic maintainer-clean-recursive mostlyclean \
 mostlyclean-compile mostlyclean-generic mostlyclean-libtool \
 mostlyclean-recursive tags tags-recursive uninstall \
 uninstall-am uninstall-binPROGRAMS uninstall-info-am \
 uninstall-info-recursive uninstall-recursive
.asm.lo:
 $(LIBTOOL) --mode=compile $(STRIP_FPIC) $(NASM) -f elf $<
# Tell versions [3.59,3.63) of GNU make to not export all variables.
# Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
C bo automake
Marsh Posté le 24-01-2003 à 18:28:05
google ou le manuel de make sur gnu.org
http://www.gnu.org/manual/make/index.html
Marsh Posté le 24-01-2003 à 16:17:58
Histoire que j'adapte pour mon prog ....
merci !!!
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
