cygwin c++ compiler cannot create executables - C++ - Programmation
Marsh Posté le 28-10-2008 à 22:17:37
| Citation : g++ (GCC) 4.3.0 20080305 (alpha-testing) 1 |
Essaye de mettre à jour cygwin avec une version plus récente de g++, style 4.3.2, parceque "alpha-testing" ça inspire pas confiance
Marsh Posté le 28-10-2008 à 21:50:11
J'ai cygwin sur mon ordinateur personnel avec windows xp, je lance ./configure et il me renvoit C++ compiler cannot create executables.
Pourtant j'arrive à utiliser cette commande avec cygwin pour la même installation au travail. Quelqu'un aurait-il une idée d'où peut provenir le bug et comment le solutionner ?
Ci-dessous le fichier config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.61. Invocation command line was
$ ./configure
## Platform. ##
hostname = BETAPLUS
uname -m = i686
uname -r = 1.5.25(0.156/4/2)
uname -s = CYGWIN_NT-5.1
uname -v = 2008-06-12 19:34
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/X11R6/bin
PATH: /cygdrive/c/texmf/miktex/bin
PATH: /cygdrive/c/WINDOWS/system32
PATH: /cygdrive/c/WINDOWS/System32/Wbem
PATH: /cygdrive/c/Python22
PATH: /cygdrive/c/matlab6p5/bin/win32
PATH: /cygdrive/c/Program Files/Microsoft SQL Server/90/Tools/binn/
PATH: /cygdrive/c/Program Files/QuickTime/QTSystem/
PATH: /usr/bin
PATH: /usr/bin
PATH: /cygdrive/c/Program Files/Microsoft Visual Studio/Common/Tools/WinNT
PATH: /cygdrive/c/Program Files/Microsoft Visual Studio/Common/MSDev98/Bin
PATH: /cygdrive/c/Program Files/Microsoft Visual Studio/VC98/bin
PATH: /cygdrive/c/PROGRA~1/FICHIE~1/MUVEET~1/030625
PATH: /usr/lib/lapack
## Core tests. ##
configure:2072: checking for a BSD-compatible install
configure:2128: result: /usr/bin/install -c
configure:2139: checking whether build environment is sane
configure:2182: result: yes
configure:2197: checking for a thread-safe mkdir -p
configure:2236: result: /usr/bin/mkdir -p
configure:2249: checking for gawk
configure:2265: found /usr/bin/gawk
configure:2276: result: gawk
configure:2287: checking whether make sets $(MAKE)
configure:2308: result: yes
configure:2558: checking for g++
configure:2574: found /usr/bin/g++
configure:2585: result: g++
configure:2616: checking for C++ compiler version
configure:2623: g++ --version >&5
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2626: $? = 0
configure:2633: g++ -v >&5
Using built-in specs.
Target: i686-pc-cygwin
Configured with: /gnu/gcc/release/gcc4-4.3.0-1/src/gcc-4.3.0/configure --srcdir=/gnu/gcc/release/gcc4-4.3.0-1/src/gcc-4.3.0 --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/sbin --localstatedir=/var --sysconfdir=/etc --datadir=/usr/share --infodir=/usr/share/info --mandir=/usr/share/man -v --with-gmp=/usr --with-mpfr=/usr --enable-bootstrap --enable-version-specific-runtime-libs --with-slibdir=/usr/bin --libexecdir=/usr/lib --enable-static --enable-shared --enable-shared-libgcc --enable-__cxa_atexit --with-gnu-ld --with-gnu-as --with-dwarf2 --disable-sjlj-exceptions --enable-languages=ada,c,c++,fortran,java,objc,obj-c++ --disable-symvers --enable-libjava
Thread model: single
gcc version 4.3.0 20080305 (alpha-testing) 1 (GCC)
configure:2636: $? = 0
configure:2643: g++ -V >&5
g++: '-V' option must have argument
configure:2646: $? = 1
configure:2669: checking for C++ compiler default output file name
configure:2696: g++ conftest.cpp >&5
configure:2699: $? = 1
configure:2737: result:
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define MAJOR_VERSION 3
| #define MINOR_VERSION 1
| #define PATCH_VERSION 0
| #define PACKAGE "getfem++"
| #define VERSION "3.1"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:2744: error: C++ compiler cannot create executables
See `config.log' for more details.
## Cache variables. ##
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=
ac_cv_env_FC_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_PYTHON_VERSION_set=
ac_cv_env_PYTHON_VERSION_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/usr/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_make_make_set=yes
## Output variables. ##
ACLOCAL='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run aclocal-1.10'
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run tar'
AR=''
AUTOCONF='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run autoconf'
AUTOHEADER='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run autoheader'
AUTOMAKE='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run automake-1.10'
AWK='gawk'
BLAS_LIBS=''
BUILDDATE=''
BUILDER=''
BUILDMEXRPC_FALSE=''
BUILDMEXRPC_TRUE=''
BUILDMEX_FALSE=''
BUILDMEX_TRUE=''
BUILDPYTHON_FALSE=''
BUILDPYTHON_TRUE=''
CC=''
CCDEPMODE=''
CFLAGS=''
CONFIGURE_ARGS=''
CPP=''
CPPFLAGS=''
CXX='g++'
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='cygpath -w'
DEFS=''
DEPDIR=''
DISTCLEANMESH=''
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
F77=''
FC=''
FCFLAGS=''
FCLIBS=''
FFLAGS=''
GETFEM_SERVER=''
GFSERVERFLAGS=''
GREP=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LDFLAGS=''
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIBTOOL_DEPS=''
LIBTOOL_VERSION_INFO=''
LN_S=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/HP_Propriétaire/getfem++-3.1/missing --run makeinfo'
MATLAB_COM_EXT=''
MATLAB_INC_DIR=''
MATLAB_RELEASE=''
MATLAB_ROOT=''
MEX=''
MPI_CLAGS=''
MPI_LIBS=''
MUMPS_CFLAGS=''
MUMPS_LIBS=''
OBJEXT=''
PACKAGE='getfem++'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PYTHON=''
PYTHON_CPPFLAGS=''
PYTHON_EXEC_PREFIX=''
PYTHON_EXTRA_LDFLAGS=''
PYTHON_EXTRA_LIBS=''
PYTHON_LDFLAGS=''
PYTHON_PLATFORM=''
PYTHON_PREFIX=''
PYTHON_SITE_PKG=''
PYTHON_VERSION=''
QHULL_FALSE=''
QHULL_TRUE=''
RANLIB=''
RPC_INC_DIR=''
RPC_LIB=''
SED=''
SET_MAKE=''
SHELL='/bin/sh'
STDCPP_STATICLIBS=''
STRIP=''
SUPERLU_CPPFLAGS=''
SUPLDFLAGS=''
TOOLBOXDIR=''
USEBLASLITE_FALSE=''
USEBLASLITE_TRUE=''
USE_MINGW_MEX_FALSE=''
USE_MINGW_MEX_TRUE=''
VERSION='3.1'
ac_ct_CC=''
ac_ct_CXX='g++'
ac_ct_F77=''
ac_ct_FC=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include=''
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build=''
build_alias=''
build_cpu=''
build_os=''
build_vendor=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='$(SHELL) /home/HP_Propriétaire/getfem++-3.1/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='/usr/bin/mkdir -p'
oldincludedir='/usr/include'
pdfdir='${docdir}'
pkgpyexecdir=''
pkgpythondir=''
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
pyexecdir=''
pythondir=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
configure: exit 77
