vous connaissez elina fan? - Overclocking, Cooling & Modding
MarshPosté le 08-09-2001 à 02:05:37
paske y font des produit assez marrant ; jai choper un chti 5*5*15 ki ma marque par sa puissance (marche en 5v a 4000/4500 t kan jle passe en 12 ca fait helicoptere) avec armature en metal ..bref ca ma interpele et voila ce ke je trouve : 18*18*65 303CFM 63dB :> ou encore des machins zarb genre :le miniblow et le radial cooler pire le therm-a-pipe...je ne peut ke vous faire un copier coller... ****Indek's Therm-A-Pipe heat pipe is an ideal heat transfer medium for high density micro devices such as notebook computers,or where space is a problem.
Therm-A-Pipe absorbs heat generated by components such as CPUs deep inside the enclosed chassis, then transfers the heat to a convenient location for discharge. With no power-consuming mechanical parts, heat pipe is a silent, light weight, space-saving, and maintenance-free solution.
Therm-A-Pipe is constructed of nickle plated compact copper. Every heat pipe contains a small amount of a purified water under vacuum conditions, and has a wick structure inside to provide the best thermal conduction, quickest thermal response and uniformed thermal distribution.
Therm-A-Pipe can be formed into a variety of shapes and sizes to meet specific heat dissipation requirements, and to fit end users' applications. Practical application of Therm-A-Pipe in micro devices often requires integration with conventional cooling technology such as cooling fans and heat sinks. **** le site //www.indek.com/
Marsh Posté le 08-09-2001 à 02:05:37
//www.indek.com/
and heat sinks.
le site
